What speakers do you have?
Discussion in 'Audio & Video' started by Black Beauty 5.7, Oct 27, 2023.
  1. Oct 27, 2023 at 2:01 PM
    Black Beauty 5.7
    Black Beauty 5.7 [OP] New Member
    Cannon
    2007 Black 5.7L Tundra SR5
    250,000 miles and always adding more :)
    Just want to see what everyone recommends in terms of speakers and what their setups look like. If you have an aftermarket system it'd be greatly appreciated to reply with your setups specs and your thoughts and opinions on the decision you've made. I find it annoying having to look through every forum to see who has what so I thought why not have one dedicated for it!
    Also, let us know where you bought everything from!
  2. Nov 12, 2023 at 1:48 PM
    JohnDeere55
    JohnDeere55 New Member
    Sandown, NH
    2023 Tundra Limited
    Fwiw, while I just took delivery of a 2023 Tundra Limited with the JBL 12-speaker system, this is what I did with my 2018 Tacoma that also had the JBL system, albeit with less power and only (I think) 6 speakers and a sub ... I quickly realized that, even though it was Toyota's top-end audio system, the sound quality was far less than expected, and I don't consider myself an audiophile. When I pulled the door panels I was shocked with what I found; the speakers were crap, just pitiful, and JBL should be ashamed for allowing their brand to be attached to them. Having used JBL speakers for the past 45 years, both indoors and in vehicles, and wanting to keep the system all-JBL, I ordered high-end JBL speakers and a Fosgate sub from Crutchfield. I also inserted a small dedicated amp for the sub. I felt the JBL head-end was decent, so kept it. The front door JBL speakers came with a separate surface mount tweeter, so I mounted them in the upper-right/left quadrant of the doors in parallel with the dash tweeters. The difference in sound quality was night and day, and I'm not exaggerating one bit. While I've had the Tundra for only a few days, my assessment of the system is the same as with the Tacoma, and I expect to make the very same changes. That said, when I plugged in the Tundra specs on the Crutchfield site, the response was ... "We haven't researched your vehicle's audio system." Wtf ... The Gen 3 Tundra has been out for 2+ years now ! The chat agent pointed out that they have a program where, if you're willing to do some research/work, and feed data back to them, they'll give you a gift card for up to (<= keyword) $350. Oh, and a hat, too. I'll participate to a degree, not because of the bennies but because I want to know what components are compatible with the Tundra.
  3. Nov 12, 2023 at 2:47 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Everything depends on your budget.
    This is mid setup:
    Aftermarket head unit ~ $600-1200
    5ch amp $300-500
    Either: 2 sets of components or 1 set of comoponents (front) and 1 set of coax (rear) $300-600
    10" or 12" sub with box (either single or dual) $500-100
    Wiring ~$100
    Sound deadening ~$75
    That will be a pretty nice setup.
    I'm currently running AudioFrog 3-ways in the front and JL Audio C5-650's in the rear with 2 JL 10tw3-d4's in a ported box with dual JL Hd900/5 amps and a Helix DSP Pro Mk2 and a Kenwood 1037s.
  4. Nov 12, 2023 at 3:00 PM
    JohnDeere55
    Sandown, NH
    2023 Tundra Limited
    For sure it depends on budget but, even more so what you have for a head-end (i.e. JBL vs. non-JBL) and what level of quality you'd be satisfied with. Once I replaced the speakers and sub w/amp, it was def a system I was quite happy with for the 5 years I owned the Tacoma, and for far less than the figures you're estimating above ...
  5. Nov 12, 2023 at 5:29 PM
    Iamsecond
    Iamsecond New Member
    Kevin
    2019 Limited Tundra
    2019 tundra limited crewmax with stock jbl system completely taken out.
    Installed:
    Kenwood dnr1007xr
    Minidsp 8x12 Dirac live
    2 sundown sdx 100.4
    1 sundown sdx 1200.1
    Stereo integrity m25 tweets in dash
    Stereo integrity tm8 8inch front door
    2 stereo integrity bm12 mk behind back seat
    Sealed box from tech12volts
    Nvx deadening throughout cab.
    mam going to move tweets to a pillar and install stereo integrity m3 carbon mids in dash just for kicks and giggles. Don’t need it but might as well. Or install the infinity 203s mids in the dash. Can’t decide.
    Just for info:
    stereo integrity is having a huge sale on their components and subs right now.
    Beckusmc and JohnDeere55 like this.
  6. Nov 12, 2023 at 8:14 PM
    jimg
    jimg New Member
    2016 Tundra Limited 4x4
    2016 crewmax limited
    bought from stereo integrity direct
    stereo integrity m25 tweeters.
    Stereo integrity M3 carbon
    Stereo integrity tm65
    subs. 2 Rockford fosgate 8 inch from the local shop in town
    jvc z1000w headunit. Local shop
    amps crutchfield
    Amp. 1. Sony Xm gs4.
    Amp. 2. Sony Xm gs4
    Amp 3. Sony xmgs100
    Love the Sony amps. They do more than rated power, and are dead quite
    dsp zapco z8
    I feel I could have spent a lot more $$$$. And gained very little over what equipment listed above
  7. Nov 13, 2023 at 6:34 AM
    JohnnyMoxon69
    JohnnyMoxon69 New Member
    2011 Tundra Limited Crewmax
    2011 CM Tundra (JBL)
    Kenwood 1037s (Best Buy deal)
    JL C1 650s (JRT)
    AudioFrogs gs 25s (JRT)
    JBL 8 channel upgraded amp (JRT)
    JBL 10" sub (Locally, but seems to be from JRT)
    I do want to move to dual 10" subs.
  8. Nov 29, 2023 at 5:35 PM
    Sully6
    Sully6 New Member
    Ken
    2020 cement trd off ry
    2020 non jbl
    Kenwood 1037s
    Jl audio c1 components in front doors
    Jl c1 in rear doors
    Jl 5 channel 900.5 amp
    Double cab custom box from James
    2 10inch infinity shallow subs
    Sound deadening all doors
    For the money lil over 2k which in the audio world isn't much it's a great system James is helpful n knowledgeable the man returned my email with a phone call at 1130pm to make sure I was all set and is helping me warranty a sub which is blew (my fault)
    WFD473 likes this.
  9. Dec 1, 2023 at 2:44 PM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    2024 Tundra SR5 (non-hybrid)
    Highs and mids
    JL Audio vxi-800/8i
    Focal Flax EVO PS165 F3E 6.5 3 ways up front
    Focal Flax EVO PC165 FE 6.5 coax in the rear
    Subs
    JL Audio RD1000/1
    JL Audio 10in TW3
    MTI acoustics stage 3 box
    sound treatment on all doors, rear cab, and under seat enclosure tubIMG_4121.jpg IMG_4123.jpg IMG_4120.jpg
  10. Dec 3, 2023 at 5:36 AM
    Danimal86
    Daniel
    Sacramento, CA
    clean!
    Beckusmc and Goobax[QUOTED] like this.
  11. Feb 10, 2025 at 8:20 AM
    BMTTundra
    BMTTundra New Member
    Mitch
    2025 Tundra Rally
    How does it sound? I'm assuming the speakers are just like any other down firing box... did you have to cut any holes or anything to allow the air/sound to flow better out of the storage compartment?
  12. Feb 10, 2025 at 9:51 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    what did they charge ?
  13. Feb 10, 2025 at 11:53 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I’m very happy with my set up. No cutting of anything, not necessary
    BMTTundra[QUOTED] likes this.
