General Supercharger Thread
  1. Jun 22, 2025 at 9:38 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Still Like That Sound!!
  2. Jun 22, 2025 at 9:55 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Dammit!!
    More options!!
    You can get the pillar mount with one to three gauge mounts!!
    Kinda leaning towards the single.
    Or maybe the double.
    Just wondering if I really need more gauges other than the Boost Numbers.
    mustang67408 likes this.
  3. Jun 22, 2025 at 9:56 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    AFR is the most important thing to know.
  4. Jun 22, 2025 at 10:01 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    That's the one I just ordered for my 2010, with 2 pods
    Tundra Texan[QUOTED] likes this.
  5. Jun 22, 2025 at 10:01 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Hows the Air Fuel gauge connected?
    I guess the better question would be where does it connect?
  6. Jun 22, 2025 at 10:08 AM
    blenton
    blenton New Member
    He’s not saying the mileage is causing the lag - it’s the throttle mapping associated with the model year.
    ~2014 they changed throttle mapping significantly for a less aggressive and jumpy throttle. My ‘13 always felt peppier, snappier off the line, like it had and extra 60 or 70 horse compared to my ‘21. Midrange power feels dull in the ‘21. But it’s the exact same truck down to the cab and bed configuration. In fact, they ‘21 is a little lighter. You have to floor it in the ‘21 or fell like it’s making real power.
    They build your tune off of the factory file, which means your throttle map can remain intact. Custom tuners like @JustDSM and @snivilous can change the throttle feel and shifting for a more lively response.
    Small changes to that map can make big differences in driveability and feel. I’ve tinkered with my Whippled ‘13 to the point that it feels jumpy and excitable, making it difficult to manage and modulate in traffic. Then I ran it down to the point that the truck felt labored even up in to the midrange - like it wasn’t making power. Then I found the sweet spot in the middle where it jumps forward when I feed it, but behaves like stock when I drive like an old man.
    I would suggest- as others have - that you look there first. On a second note, I did have a faulty bypass actuator out of the gate, but it have other symptoms and still ran like a beat when you fed it the pedal.
  7. Jun 22, 2025 at 10:09 AM
    mustang67408
    Victor
    There's a map sensor, which I mounted to the left of the brake booster. Then ran the wires into the cab.
    The vacuum line is "T'd" into the line to the fuel pressure regulator for boost reference.
  8. Jun 22, 2025 at 10:20 AM
    centex
    centex New Member
    I use the innovative scg-1 which is air fuel and boost. Overkill for you since it can also do boost control but still a good all in one gauge.
  9. Jun 22, 2025 at 10:21 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Nice!!
    The Magnuson did come with an RTD/TDN module for remote tuning.
    Going to have to learn myself the ins and outs of the device.
    Any info would be appreciated.
    Back in the TRD SCer days there was nothing like this new fancy stuff.
    You got it tuned and that was it!!
  10. Jun 22, 2025 at 10:27 AM
    e30cabrio
    Bosch 4.9 O2 sensor welded to the exhaust downpipe.
    Mine are Innovate ECB & ECF-1. B for boost & F for fuel
  11. Jun 22, 2025 at 10:30 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    So i'm going to have to weld a sensor port/mount to the downpipe?
    I do have that ability here in the garage.
  12. Jun 22, 2025 at 10:36 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    So in conclusion...
    Boost and air fuel are going to be my main info...
    Is there a need for the three gauge mount option?
  13. Jun 22, 2025 at 10:49 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Unless you want fuel pressure, Intake Air Temp etc.
  14. Jun 22, 2025 at 10:52 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    At what point does it really matter?
    Wouldnt think those would change for the most part.
    Hell,all this new crap has already got my head spinning but I like it!!!
  15. Jun 22, 2025 at 10:52 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You can data log with it and get remote tuned. But you'll need a hpt mpvi3 to do your own tuning.
  16. Jun 22, 2025 at 10:54 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Yeah....NO!!
    I dont know jack about tuning so i'll leave it to those who do.
    Guaranteed I'd F something up!!!
  17. Jun 22, 2025 at 10:54 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I went 10 years with just the AEM afr/boost gauge. I have a fuel pressure gauge for the Walbro 450 in case there are issues.
  18. Jun 22, 2025 at 10:58 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Would love to have a disposable Tundra I could F around with the tune but I'm pretty sure the Wife would complain....
  19. Jun 22, 2025 at 11:51 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Did you happen to do the SAIS filter mod on the Tacoma? On it that pump is located on the top of the engine, and the Taco definitely has more whine noise when that mod is done.
  20. Jun 22, 2025 at 12:22 PM
    mustang67408
    Victor
    This is where mine is. The down pipe on the passenger side for the AF sensor PSB1 gauge
  21. Jun 22, 2025 at 12:28 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Nope...just the blower install.
  22. Jun 22, 2025 at 1:18 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Give @JustDSM at OTT a call, that alone will wake the truck up a lot and make it run safer, and get rid of the lackadaisical throttle mapping, and he'll flash it for you or send you the file to use with the RTD device.
  23. Jun 22, 2025 at 1:27 PM
    centex
    centex New Member
    This is your best option right here.
  24. Jun 22, 2025 at 1:41 PM
    JustDSM
    JustDSM New Member
    Justin
    Thanks Sniv!
    Send an email into info@overlandtailor.com and let John know you're from Tundras.com and need a tune for your Maggy setup that uses a RTD. He'll get you sorted with a complete set of files for your truck.
  25. Jun 22, 2025 at 1:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Just did a few runs and she really seems to boogy. Pulls strong! I may be able to add 1 or 2 degrees of timing in some areas. I'm spraying full on at 7psi with the direct port. No signs of quenching the larger gapped plugs with the direct port combined with the throttle body nozzle for the rotor cooling. MAF is maxing out right at 6000rpms with 84.5% on the 750cc injector duty cycle. Will mess with fuel trims once timing and PE are dialed in.
    I'm going to enlarge the inlet opening on the fender. I cracked my air filter box and was able to get about 14.4psi. Make a mold to fiberglass it in place on one end to still have flex. And hood vent...eventually.
    Tundra Texan, reywcms, Jego and 7 others like this.
  26. Jun 22, 2025 at 1:57 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Those IDCs are promising! Such a cool journey you're on. Appreciate you and @snivilous working through it in the name of science.
    Oh! And it's a new day with new discussions. You might want to ping Jesse (again?) and mention your MAF limitations.
  27. Jun 22, 2025 at 2:14 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I had it on but was having issues. He gave a few pointers to help but returned it. I'll check it out again as i solved the misfire issue from back then. I'm dumping a little extra fuel at 5600rpm on up with PE. Afr's are showing its doing its job. Kinda backwards but I'm not at that rpm too often, maybe a little bit.
  28. Jun 22, 2025 at 2:52 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thanks @snivilous for pointing out my MAF and others were in absolute load instead of air load. Will do some log runs later to see if it changes the MAF..IDC/ KCL. etc before changing it up.
  29. Jun 22, 2025 at 3:44 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Just an FYI for those looking at the Mitch Made billet carrier bearing at Slew House. Concerning solid or soft mounts combined with solid engine/trans mounts. I ordered the soft one and will get it on when it arrives. Thanks @reywcms for posting about it.
  30. Jun 22, 2025 at 4:55 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @snivilous Thanks for pointing out on my logging was in absolute load instead of airload. Might have added timing where it's not needed.
    My MAF Max's out at 6400rpm but injector duty cycle was at 89%. All others are good and timing stays as it is.
    j_supra, HulkSmurf14, reywcms and 2 others like this.
