General Supercharger Thread
  1. Jun 21, 2025 at 5:18 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    She's up and running no more coupler/bearing noise. Did an oil change used 9 qts of Mobil1 European 0w-40. Fresh red antifreeze with water wetter. Still need to finish up pump and throttle body braided lines for the water/methanol. Ordered up a water pump as that started whining. Need to clean up wiring and hose routing when I get the rest of the shipment. The larger gap on the plugs seem good to go. Will do some logging runs and see where it's at.
  2. Jun 21, 2025 at 5:22 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Now they're just fucking with me.
    Tripleconpanna likes this.
  3. Jun 21, 2025 at 5:53 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    From that angle of the cab, it looks like an old roadster, or a pt cruiser lol. But looks like it would be a sick build on a short frame, without the bed.
    reywcms[QUOTED] and e30cabrio like this.
  4. Jun 21, 2025 at 6:51 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I bet you’re not even getting in to boost because of the bypass valve. I need like 45-50% (40 degrees of throttle angle) throttle to get any boost at all. Try tow/haul mode and don’t be a ladyboy.
  5. Jun 21, 2025 at 7:03 PM
    Backroadgee
    Backroadgee Well Known Member
    west
    Missouri
    SDHQ BAJA ADD PRO SKID PLATES
    Clean install!
    armyoffoo[QUOTED] likes this.
  6. Jun 21, 2025 at 7:32 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    lol yes you haven’t laid into it
  7. Jun 21, 2025 at 11:01 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    It just feels like it isnt creating boost at all no matter the RPM range.
    I'll try turning off the traction control.
    I'm going to bring it back to the installer after trying your suggestion and take the manager for a ride.
    It's really obvious it's not creating boost,It's no faster than when I brought it in.
    Kinda wish I hadnt changed the exhaust right about now so I could listen for the whine.
    I'm going to open the hood and give it some throttle and see if I can hear it sitting in the driveway.
    Like I said though,you could most definitely hear it in my Tacoma but then it had the stock exhaust.
    Need to take and run it on the dyno as well and see what if any increase in HP.
  8. Jun 21, 2025 at 11:02 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Maybe a little.....:rolleyes:
    mustang67408 and HulkSmurf14 like this.
  9. Jun 21, 2025 at 11:18 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Comparing the amount of whine between different setups doesn't really tell you anything. the 2650 is pretty quiet, especially with the stock pulley
  10. Jun 21, 2025 at 11:18 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    While I'd love to just romp on it I'm being a little conservative on the skinny pedal per instruction from the installer.
    But again,when they installed the TRD unit in my Tacoma which is made by Magnuson it was obvious from the get go that it had been SuperCharged.
  11. Jun 21, 2025 at 11:24 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    It's no so much that as it the is lack of acceleration.
    Like I said this isnt my first SuperCharged Truck so I had a good idea what to expect.
    And I expected a lot more!!
  12. Jun 21, 2025 at 11:44 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    After a trip to the Dyno...if it warrants it,I'll be contacting Magnuson directly.
  13. Jun 22, 2025 at 5:28 AM
    centex
    centex New Member
    You’re also driving a vehicle that’s twice the weight. Turn on tow/haul and drop the hammer on the throttle.
  14. Jun 22, 2025 at 6:12 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    If you get it right
    expect ~5sec 0-60
    you really need to build it out to get under 5
    I only have the 2650 + smaller pulley + injectors
    intake and exhaust is stock
    that’ll get ya ~ 500 whp
    I’ve done 5.1 on a dragy. And that’s moving
  15. Jun 22, 2025 at 7:30 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    It was twice the weight before the SCer.......
    I figure I'll let them know now that I believe there's a problem and they'll probably want me to bring it in which is fine I have nothing but time.
    I'll do some driving again today just to see if I'm overreacting,and do the driveway listen and go from there.
  16. Jun 22, 2025 at 7:34 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    It shouldnt be laggy due to mileage.
    It only has something like 20k miles on it since I bought it right after I retired.
  17. Jun 22, 2025 at 7:40 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    I'll wait on that until after I find out if the SCer is putting out what it should be. (after installing the boost gauge)
    Dont want to start throwing parts at it until I have a baseline.
    If it's not my first step is going to be taking it back to the installer.
  18. Jun 22, 2025 at 7:43 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    As far as installing the boost gauge.....
    I remember with my Tacoma it was a pain in the Ass trying to get the tube from the gauge to the SCer without kinking it.
    How's the install on the Tundra?
  19. Jun 22, 2025 at 7:54 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Not difficult at all
    Tundra Texan[QUOTED] likes this.
  20. Jun 22, 2025 at 7:55 AM
    AZTundra
    Paul
    Phoenix, AZ
    Short hose run from the back corner of the blower to the map sensor. I mounted my map sensor to the left of the brake booster.
  21. Jun 22, 2025 at 8:00 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    The line that came with my boost gauge for the Tacoma was an opaque white line with very little flex.
    You couldnt make a sharp turn with it or it'd kink and pretty much ruin the line.
    At least this line looks to be a little more used friendly.
  22. Jun 22, 2025 at 8:35 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Have someone blip the throttle while you're looking at the bypass valve to make sure that it's moving correctly. It should be open normally and then snap closed with a blip.
    Mdl, mustang67408 and Tundra Texan like this.
  23. Jun 22, 2025 at 8:56 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    So what are y'all using the second gauge mount for on the pillar mount?
    Obviously one is going to be for boost.
    Air Fuel mixture?
  24. Jun 22, 2025 at 8:57 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    My second one is for air bag pressures
    Tundra Texan[QUOTED] and Wynnded like this.
  25. Jun 22, 2025 at 9:00 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Suspension I assume?
    mustang67408[QUOTED] likes this.
  26. Jun 22, 2025 at 9:01 AM
    AZTundra
    Paul
    Phoenix, AZ
    I went with a single gauge. The Innovate PSB-1 will monitor both AFR and boost on one display.
  27. Jun 22, 2025 at 9:01 AM
    mustang67408
    Victor
    Yes sir
  28. Jun 22, 2025 at 9:02 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Hmmmm...now your giving me options.
    HulkSmurf14 and mustang67408 like this.
  29. Jun 22, 2025 at 9:13 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Boost and AFR.
  30. Jun 22, 2025 at 9:23 AM
    e30cabrio
    I have 2 multigauges, left is left bank AFR, Peak Boost & boost 2x because I didn't need to add another ethenol or fuel temp/pressure sensor. Right is right bank afr, ethanol content, fuel pressure & fuel temperature.
    https://vimeo.com/1079198159?share=copy
