  1. Jun 19, 2025 at 5:10 PM
    Went out in the heat and tried out that Milwaukee m18 variable speed die grinder. Pretty good for a battery operated device.
    Unfortunately not as good as a quality compressor. I may need to take the angle grinder and some abrasive pads to the steel ramps to get them 100% free of rust. A wire wheel can only dig in so much. May try the cup next but past experience tells me it doesn’t do as well as the wire wheel.
    oscardog86 and bmf4069 like this.
  2. Jun 19, 2025 at 6:54 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Bought some stuff drain and fill.plugsthat don't suck the 10mm Allen is soaking atm. Hope that helps it come the fuck out tomorrow without heat.
    Voss, G_unit3000, des2mtn and 7 others like this.
  3. Jun 19, 2025 at 8:33 PM
    Mine says 245s as well, but I always had 265s with patricks on it. Weren't 245s only on steelies?
  4. Jun 19, 2025 at 8:37 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Pretty sure. The steelies are 7” & the patricks are 7.5”.
  5. Jun 20, 2025 at 3:59 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Not sure of that, I'm just a newb here :rofl:. But I can say this, when I was shopping for my tires, putting in my year and specs (2000/sr5/4.7/4x4) it ONLY gave me 245s as an option "standard". By switching just the drive from 4x4 to 2WD gave me the 265s option.
    That had me wondering if they (Discount Tire) would even install 265s on mine because their fine print said something like "we will only install tires that were designed for your specific vehicle". I ordered and paid for them online.... so I just put in 2WD so I could get the 265s.
    On a side note, since I got the tires I've had an opportunity to check my mpg on a 60 mile round trip to town. About 30 miles of dirt roads 25-30-35mph, and 30 miles of paved, 50-55mph. Using +3.7% for the 265s, I actually got 14.8mpg!!!
    I know its not all due to the tires but amazing anyway... OH, and she's kicked a P0430 on the return trip both times hahaha. Mind Blown:eek2:
  6. Jun 20, 2025 at 4:02 AM
    That's weird. Must be a new thing. I had discount put my 255x85r16s on, but I just took them the wheels to do it.
    BroHon[QUOTED] and oscardog86 like this.
  7. Jun 20, 2025 at 5:46 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Discount put the same on mine, 255 85 16s. They had no hangups about installing on my truck either.
  8. Jun 20, 2025 at 6:04 AM
    I absolutely hate that. BJs warehouse is the exact same way and refuse to install any size tire other than what’s on the door jamb.
    YET, if you got a limited tundra it came with starfish alloys as part of the standard configuration so the door jamb is updated with 265 tires. SMH
    BroHon[QUOTED] likes this.
  9. Jun 20, 2025 at 6:10 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I've had them install 33x12.5s on both the YJ and the TJ, but that was years ago. I will say that when I had the Ram 1500, they refused to install only 2 tires stating that the 2 I wanted to replace didn't match the other 2 (brand and model) so I was able to haggle and bought 4 for the price of 2. Again, years ago. I do my own tires now and have for the last 10 years, but I'm the exception as the majority of you do not have access to a tire machine.
    shifty`, BroHon and 455h0le_dachshund like this.
  10. Jun 20, 2025 at 6:26 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    It happened to a friend of mine at Walmart too. They refused to install the tires he wanted even though they were an upgrade over factory specs.
  11. Jun 20, 2025 at 6:27 AM
    Happened to me at Walmart also. Refused to put a different size on the vehicle that wasn’t what was either on there now, or on the door jamb.
    BroHon likes this.
  12. Jun 20, 2025 at 6:46 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    There are some tools that make those easy, if they're stuck. This got mine out in about 10 seconds, after multiple tries with allen key, heat, cold chisel.
    FirstGenVol, BroHon, Voss and 6 others like this.
  13. Jun 20, 2025 at 6:57 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    If you get to this menu when you add your vehicle, you should be able to add an 'optional' custom size. I ordered my last set of tires online through DT because they had a rebate.
  14. Jun 20, 2025 at 7:14 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    Woof! Mine wasn't near that bad. After a lil heat and tapping the 10mm Allen socket in, jack up front for more leverage/ room it came out. I thought for sure it was gonna strip, bleed me and shit would go flying. Fuck those plugs!
    MT-Tundra[QUOTED] likes this.
  15. Jun 20, 2025 at 7:30 AM
    Neo
    Neo New Member
    Alabama
    The factory door sticker on my 02 AC LTD 4x4 4.7 L says 26/29 F/R. I have never owned a vehicle with such low factory tire pressure specs. I don't do much hauling, so I try to keep the pressures at 30/30 just for my sanity.
  16. Jun 20, 2025 at 7:44 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    DT website is a pain in the ass. But you can't beat their cert program if you like to party...
  17. Jun 20, 2025 at 7:50 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Fancy
  18. Jun 20, 2025 at 7:52 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I order my tires through the Subaru Tire Center (filled by TR / DT) and I get cert, roadside and towing :D. They will even cover trailers @KNABORES
  19. Jun 20, 2025 at 8:24 AM
    Sweet. My camper has Goodyear trail terrains on it. Be nice for someone else to deal with flats. I’ve not had one on a trip with it, so hopefully never need it.
  20. Jun 20, 2025 at 8:37 AM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    Oh, so that's what that bolt is supposed to look like (this was the better of the two bolts connecting the hitch to the reinforcement)
  21. Jun 20, 2025 at 8:42 AM
    Jeezus man
    bmf4069, khooiii, sportbike37 and 4 others like this.
  22. Jun 20, 2025 at 8:49 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Double fancy
  23. Jun 20, 2025 at 9:12 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    whats the rating on that ‘hitch’? & is the receiver a separate part?
  24. Jun 20, 2025 at 9:44 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Today is front struts day. The first 2 pics below are from the driver's side. Note the broken spring. According to the repair records back in 2016 a dealer replaced both front left & right CV axles, upper & lower ball joints, lower control arms, sway bar links, and the driver's side outer tie rod. I'm going to go out on a limb and and say methinks there was a LBJ failure and I think maybe the spring was cracked then but went unnoticed. What is just as troubling, however, is the strut. That baby has chunks missing.
    Here's the new stuff on the pass side.
  25. Jun 20, 2025 at 9:50 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Tripleconpanna, BroHon, Voss and 5 others like this.
  26. Jun 20, 2025 at 9:55 AM
    I can’t believe I’ve seen a more delapitated shock than that. You were driving on it and the broken spring?!?
    bmf4069, oscardog86 and des2mtn like this.
  27. Jun 20, 2025 at 9:59 AM
    des2mtn
    SW
    Tonto cover
    Wonder if there's even any oil or anything inside that thing still
  28. Jun 20, 2025 at 10:01 AM
    @CC80guy could easily lose a filling or two going over a bad pothole.
  29. Jun 20, 2025 at 10:08 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
  30. Jun 20, 2025 at 12:15 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Finally fixed my trailer plug that I bashed off over a stump. I’m not really doing much towing but I replaced the old 7 prong with a 4 prong. Didn’t know it would be a 4 prong when I ordered it, but it works out because that’s probably the only trailer I’d end up towing anyway. It’s nice and discreet. I like it. See below before and after.
    Also cleared my p0430 code by driving around so that’s good. Gonna add some cataclean at the end of this tank of gas for good measure. Weird that it happened in conjunction with the valve cover gasket swap…
    And tightened my suspensionmaxx sway bar links. A lot. The popping noise when going over bumps or turning in the rain has continued since I put on my lift. Last few days it has been doing it in the dry too. So I tightened them down like a normal bushing situation. I remember the instructions saying not to tighten them too much, so I did that, but it seems weirdly loose. Whatever. If I have to buy new bushings in a year cause I screwed these up, I’m fine with it.
    Wiped off some oil and grease underneath from all the mods and maintenance I’ve done lately. And I’ll probably do the engine bay later today. I think I’m just gonna go hose and dish soap and brushes.
    bmf4069, Voss, BroHon and 5 others like this.
