The "Cracked Seat Panel" MEGA Thread
Discussion in '3rd Gen Tundras (2022+)' started by TundraSurveyor, Jul 14, 2022.
  1. May 28, 2025 at 4:51 AM
    #571
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    You would think after all the panels they have replaced, they could figure out how to make one that doesn't break. I am on my 3rd driver seat panel and my 2nd passenger seat panel.
    MEGA VOL likes this.
  2. May 28, 2025 at 5:36 AM
    #572
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    My thoughts are the panels are not flexible enough. They need to be made of a softer material to flex when exiting the vehicle. The problem would be that the switches would need to probably drop a slight bit for this to happen.
  3. May 28, 2025 at 5:46 AM
    #573
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    Knocking on wood. 1 year in my 24 SR5 original seat panels on both seats. Slide in and out like normal.
    Tundrastruck91 and TundraDan723 like this.
  4. May 28, 2025 at 8:35 AM
    #574
    Linuxrules
    Linuxrules New Member
    2024 Tundra
    Dropped mine off this morning and the service person didn't hassle me. Admittedly I did come on a bit strong out of the gate expecting hassle: "I expect this to be covered under warranty since it's happened to thousands (who knows, made up the amount) of owners and there is even a TSB for it". think the tsb is 22-23's and mine is a 24 but whatever.
    him: "if we have the part in stock we will get it done".
    Either working under the "take care of the customer" or possibly just seen so many of them by now?
    Will post back if they actually replace it. Anyhoo it's the Mega thread so it must go on...
    Tundra Sam likes this.
  5. May 28, 2025 at 11:27 AM
    #575
    Linuxrules
    2024 Tundra
    Done and no hassle, replaced with the "updated part"... think that's giant air quotes but still, it's fixed for now.
  6. Jun 9, 2025 at 11:34 AM
    #576
    mrlittlejohn
    Michael
    I had mine replaced for the first time. I bought my truck used last year but have an 84 month B to B warranty.
    The replacement panel installed, I believe will never crack. It is very rigid. Nothing like I recall the old one being. I can’t flex this one at all.
    Anyone else have a more rigid panel installed?
  7. Jun 9, 2025 at 11:42 AM
    #577
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    Yes, I'm about to have my second more rigid panel replaced...it DID last longer than the 2 first iterations did, before breaking, though.
    mrlittlejohn[QUOTED] likes this.
  8. Jun 11, 2025 at 4:06 AM
    #578
    jt13077
    jt13077 New Member
    Upstate NY
    2024 TRD Sport crew CSM
    Mine just cracked yesterday, 2024 with 22k. Calling dealer this morning, hoping they fix it under warranty.
  9. Jun 11, 2025 at 4:32 AM
    #579
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    As long as you are under 36K miles there should be no problem.
    jt13077[QUOTED] likes this.
  10. Jun 11, 2025 at 4:38 AM
    #580
    Gonefishingdave
    Dave
    Central New York
    Has anyone heard of this problem in 2025 MY?
    You would think a couple would have been reported by now if still an issue.
  11. Jun 11, 2025 at 4:51 AM
    #581
    DCRB4X4
    DCRB4X4 New Member
    BLACK 2015 DCRB SR5 4X4
    5100's front, spacer rear
    I "updated" mine with a thru-bolt and a nut. Seems pretty solid now.
  12. Jun 11, 2025 at 6:13 AM
    #582
    Xfun
    Xfun New Member
    Martin
    TUNDRA DOUBLE CAB SR5 TRD OFF ROAD
    Stock
    Do you have pictures? Thank you
    mrlittlejohn likes this.
  13. Jun 11, 2025 at 11:47 AM
    #583
    DCRB4X4
    DCRB4X4 New Member
    No unfortunately. There is a small screw that is installed towards the front from underneath the seat. That is where mine broke. I took the other screw out.(accessible from the rear) Flip it down and drill a hole from the inside using the broken part as a guide. Put a suitable machine screw and nut on when you reinstall it. If you are OCD you can get a little cover for the screw head at Lowes or Home Depot in the hardware section.
    I am short and slide across it every time I get out and so far it is holding up.
  14. Jun 14, 2025 at 7:33 PM
    #584
    Pine_Cone67
    Pine_Cone67 New Member
    2024 Tundra Limited
    Junior from The Yota Channel just posted an instructional video on this specific issue:
    Tundra Sam and Tundrastruck91 like this.
  15. Jun 14, 2025 at 8:18 PM
    #585
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    That looks so easy, if mine ever cracks, will just get part and do myself.
  16. Jun 15, 2025 at 9:00 AM
    #586
    brian.hammarsten
    brian.hammarsten New Member
    2022 Tundra Plat
    none
    Does anyone know of a company making an aftermarket seat panel that holds up longer? My 2022 is cracked and I just used some zip ties and a thin "bungee" chord to hold it in pace and be flexible. It looks ok and I can still access the seat controls at least
  17. Jun 18, 2025 at 8:48 AM
    #587
    Tundra Sam
    Tundra Sam New Member
    Sam
    Canada
    2023 Tundra TRD
    Mostly Stock
    Cracked mine today 2025 TRD with 25K km on it .... taking it to the dealer tomorrow.
    Dealer said: Yes its covered under warranty ... (silver lining after all)
    jt13077 and mrlittlejohn like this.
  18. Jun 18, 2025 at 8:53 AM
    #588
    Tundra Sam
    Sam
    Canada
    2023 Tundra TRD
    Mostly Stock
    Need to start thinking my egress posture.... many are saying use the darn grab handle & slider ... instead of sliding.
    kirkb likes this.
  19. Jun 18, 2025 at 9:15 AM
    #589
    donia
    donia New Member
    Miss’ippi
    My last one looked exactly like yours. The first two weren't completely broken away this bad, just a couple of stress splits in the same area as this. I can kind'a see my first couple breaking from me being a fatboy. I've lost around 75lbs since then and the last 2 have been replaced with the "new and improved" panel that still breaks at 225lbs.
  20. Jun 18, 2025 at 9:24 AM
    #590
    Tundra Sam
    Sam
    Canada
    2023 Tundra TRD
    Mostly Stock
    Guess I didn't take into account I am 6'1 Canadian at 240lbs .... thought I was buying a Truck & it would be a little more solid ?
  21. Jun 18, 2025 at 1:08 PM
    #591
    jt13077
    jt13077 New Member
    Upstate NY
    That’s how mine broke, I put duct tape on the plastic to keep from ruining the seat until the dealer can get it in!
    kirkb and Tundra Sam[QUOTED] like this.
  22. Jun 19, 2025 at 1:04 PM
    #592
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
  23. Jun 19, 2025 at 6:43 PM
    #593
    Gonefishingdave
    Dave
    Central New York
