Diamondback Tonneau Cover
Discussion in 'Tonneau Covers, Caps and Shells' started by jeffw6236, Aug 7, 2017.
  1. May 19, 2025 at 9:01 PM
    #1171
    AF555
    AF555 New Member
    Michael
    2025 Tundra 1794 - Smoked Mesquite
    Looking at buying the DiamondBack HD tonneau cover for my 25' Tundra 1794.
    For those that own the HD, can anyone tell me what the added height at the tailgate is with the cover on?
    I’m guessing + 3-4” but trying to find out exactly if I can (DB site doesn’t seem to list the height) as I am putting in some shelving in my garage but will need to of course place the shelf higher than what the truck bed and cover are.
    Thanks all!
    EDIT/UPDATE to my own question: per a DiamondBack customer experience manager: Thanks for reaching out! The DiamondBack has a 2" profile.
  2. May 24, 2025 at 11:12 AM
    #1172
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    I measure over 4” from the bed rail, including the latch/lock assembly.
    the thickness of the metal cover may be 2”, but once you add the gasket and latch, it’s well over 2”.
    NewImprovedRon and AF555[QUOTED] like this.
  3. May 24, 2025 at 11:32 AM
    #1173
    Lemoyne40
    Lemoyne40 New Member
    Central PA
    As Bulldog 6 is saying... It is just under 4" with the latch. You wont find a better cover. 4 years now on my PRO.... not 1 issue.
    MadMaxCanon, NewImprovedRon and AF555 like this.
  4. May 24, 2025 at 1:03 PM
    #1174
    AF555
    AF555 New Member
    Michael
    Thank you both! Appreciate the help and the measurement pic!
    I put in a floating shelf across the back of my garage wall where the Tundra will be parked (backed in) and made sure to leave some extra wiggle room just in case.
    thanks again all!
    Bulldog6 and NewImprovedRon like this.
  5. Jun 4, 2025 at 8:22 AM
    #1175
    SWWheeler
    SWWheeler New Member
    I'm purchasing a Diamondback cover for my 22 tundra and will be installing a rack that attaches to the cleats. I'm having the factory install the cleats and am wondering if anyone can tell me the distance between the side cleats front to back. Total distance as well as the distance between each cleat. Thanks in advance!
  6. Jun 4, 2025 at 6:27 PM
    #1176
    Ray D
    Ray D New Member
    Ray
    Winnipeg, MB
    2023 Tundra Hybrid Limited L TRD OR 4X4
    Is your truck bed 5.5’ or 6.5’?
  7. Jun 4, 2025 at 7:19 PM
    #1177
    SWWheeler
    5.5’. I guess that would help! ‍
  8. Jun 18, 2025 at 5:22 PM
    #1178
    2016QuicksandPro
    2016QuicksandPro New Member
    Tom
    2016 Quicksand Tundra Double Cab TRD Pro
    Hello Forum,
    I have a 2016 Tundra Quicksand TRD Pro and just picked up a used Diamondback SE for a Gen 2.5 Tundra.
    It was cheap ($450), but needs some TLC.
    I believe it was originally shiny aluminum, then painted flat black.
    I plan on using Raptor bed liner to coat it (after proper prep...).
    Anyone know how the standard Black Raptor bed liner will match my TRD Pro Black trim?
    Per the Raptor website, the gloss level of Black Raptor is approximately 10 gloss units, or a satin finish.
    Anyone color match their Diamondback Bed Cover?
    If so, can you post or send me a picture of the Cover on your Tundra.
    It would add about $100 to the project cost, but if it's going to look awesome color matched, then it would be $100 well spent.
    Thank you.
    Tom
  9. Jun 19, 2025 at 2:19 AM
    #1179
    Bergy24
    Bergy24 New Member
    I cant help with the Raptor bed liner question.
    I think the color matched comes down to personal preference, however the raptor lining may be more durable than just a painted cover.
    I attached a couple examples of color matched tonneau covers that may be able to help you make your decision.
  10. Jun 19, 2025 at 7:24 AM
    #1180
    2016QuicksandPro
    Tom
    Thank you for the pics.
    I forgot that those 1 piece fiberglass covers are typically color matched.
    I'm thinking black would look better...
    Bergy24[QUOTED] likes this.
