  1. Jun 18, 2025 at 4:26 PM
    So I finally found out why my right front tire may have been wearing prematurely on the outside edge.
    8 lbs too low on the right while all other tires were at 28 lbs, this one was at 20 lbs.
    Weird coincidence or sabotage? I’m thinking the latter. I don’t know how one tire can get that low over the others unless there was a miniscule leak.
    I’m willing to bet it won’t come back now.
  2. Jun 18, 2025 at 5:22 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    28lbs is low too. I think the door calls for 32 or 35lbs
  3. Jun 18, 2025 at 5:29 PM
    I usually do 35, but I believe they call for 28 lbs. I have to check the door jamb.
    BroHon likes this.
  4. Jun 18, 2025 at 5:32 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I know this is one of those subjective topics, and different tires blah blah blah, but I always run 35-40 on pavement and 15-20 off pavement.
  5. Jun 18, 2025 at 5:39 PM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    A Ford was stuck on a trail when I went up to Big Bear this winter and he was running 60! I thought my gauge was broken when I went to deflate his tires
  6. Jun 18, 2025 at 6:09 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
  7. Jun 18, 2025 at 6:20 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Reminds me of the time me and Casey met RTT Land Cruiser guy on the trail one night, At HF. He was drunk AF, stuck in mud, with tires fully inflated.
    Voss[QUOTED] and oscardog86 like this.
  8. Jun 18, 2025 at 7:23 PM
    Hutcheson
    Hutcheson New Member
    Caleb
    2004 DC Limited
    It can certainly be a bit of a pain depending on how rusty everything is! I try my best to do everything myself, saves so much on labour costs and I get to learn a thing or two.
    Redoak likes this.
  9. Jun 18, 2025 at 8:40 PM
    MT-Tundra
    Montana
    Very temporarily
    This thing came with tripod style camper jacks, and they're sketchy af. I've been looking on FB marketplace for used corner jacks but they're either too expensive or too far away. I need a different way to lift this though.
  10. Jun 18, 2025 at 9:00 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Got a big tree? Couple straps and a pulley
    oscardog86 likes this.
  11. Jun 18, 2025 at 9:52 PM
  12. Jun 19, 2025 at 1:27 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    Yeah, so i've never looked at it. I'm surprised it's so low for the fronts :eek: Seems like that would wear worse?
    mine/but I'm running 265s
  13. Jun 19, 2025 at 1:48 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    The 06 4x4
    I was way off. Lol
    The 03 T3 has two stickers
  14. Jun 19, 2025 at 2:20 AM
    What’s the difference between 106S, 111S & 110S? Your 06 doesn’t even look factory made with that tire graphic.
    BroHon likes this.
  15. Jun 19, 2025 at 3:23 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I’ve done enough state inspections to know that it a legit sticker
  16. Jun 19, 2025 at 3:51 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Fuck if I know. Probably just codes the factory used for the corresponding tires
  17. Jun 19, 2025 at 4:01 AM
    Why the hell is it in French? lol
    I didn’t think they built Tundras in Quebec.
    455h0le_dachshund likes this.
  18. Jun 19, 2025 at 4:04 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    So @FrenchToasty can read it
  19. Jun 19, 2025 at 4:05 AM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    I think those are load ratings of some sort.
    LT tires require more pressure than standard load/p-metric, different sizes require different pressure for the same loads...
  20. Jun 19, 2025 at 4:14 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
  21. Jun 19, 2025 at 4:16 AM
    Dakillacore
    Georgia
  22. Jun 19, 2025 at 4:20 AM
    Dakillacore
    Georgia
    The letters at the end of the numbers like "S" is the speed rating.
  23. Jun 19, 2025 at 4:32 AM
    BroHon
    Bro
    2000 SR5 AC 4x4 4.7
    :monocle:
    I guess it would depend on position of the load.... but if centered over the wheel I wonder if it would still be 100lbs.
    A Weighmaster would know this equation
  24. Jun 19, 2025 at 4:49 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Key Factors That Influence Load Distribution:
    1. Vehicle Wheelbase: Longer wheelbases distribute weight more evenly.
    2. Load Position: If the 100 lbs is directly over the rear axle, nearly 100% goes to the rear.
    3. Suspension Type and Chassis Flex: Some small amount of weight might transfer to the front due to chassis flex or suspension geometry, but it’s minimal.
    4. Incline or Decline: Parked on a hill? That affects distribution slightly.
    General Rule of Thumb:
    • If 100 lbs is placed directly over the rear axle:≈ 100 lbs to the rear, 0 lbs to the front.
    • If 100 lbs is placed behind the rear axle (like in a truck bed or trailer tongue):It adds leverage, so the rear may take on more than 100 lbs, and some weight may actually be lifted off the front axle, reducing its load.
    • If it’s placed forward of the rear axle (like inside the cargo area of an SUV):It could be something like 90 lbs rear, 10 lbs front, depending on position.
    Example Calculation (Estimate):
    Let’s say a vehicle has a 120-inch wheelbase (10 feet), and you place 100 lbs 30 inches behind the rear axle:
    • This creates a cantilever effect, increasing the load on the rear axle and unloading the front slightly.
    In that case:
    • Rear may absorb 110–120 lbs
    • Front may lose 10–20 lbs of load
    In Summary:
    • Directly over rear axle: ~100% rear
    • Behind rear axle: >100% rear (some front weight lifted)
    • Forward of rear axle: ~90% rear, ~10% front
  25. Jun 19, 2025 at 5:01 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  26. Jun 19, 2025 at 6:30 AM
    MT-Tundra
    Montana
    Nope, not gonna work. :)
    I'll find corner jacks eventually. Everything seems to be near Boise for some reason. I did that trip to buy the truck, but it doesn't feel worth it for anything less than a truck. 5 1/2 hours.
  27. Jun 19, 2025 at 7:47 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    I’ve been running 44psi since my tire rotation.
  28. Jun 19, 2025 at 8:12 AM
    Dakillacore
    Georgia
    We had a new guy at the shop years ago and we asked him to put air in the customers tire. This guy comes back with the car and each tire is at 70/80 PSI. We tried to teach him throughout his year with us but he just could not retain a lot of the information.
    I hope he's doing better now.
  29. Jun 19, 2025 at 8:38 AM
    I’ve heard about people who struggle to get their tires up to 100% on the dash.
    Voss, Dakillacore[QUOTED] and des2mtn like this.
  30. Jun 19, 2025 at 3:52 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Reminds me of one time at work a.customers Honda had like 80 psi in one tire and the other three were all low. Maybe they thought if you over filled one, the other three would self adjust wirelessly
    Tripleconpanna and Voss like this.
