General Supercharger Thread
  1. Jun 18, 2025 at 9:26 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I wished I had AWD about a month ago. Pulling a 7k+ 32’ trailer loaded with my whole family I had to merge from a dead stop due to ramp construction onto a very busy highway with everyone going 70mph and the roads were drenched. I put it in 4x4 and luckily since I exercise it a lot it actually went in right away but that’s not always the case. I was chirping all 4 merging and the steering wheel got light from loss of traction. If I was in AWD there wouldn’t have been any panic of whether or not the 4x4 would engage in the short time and distance I needed it to.
    HulkSmurf14, ARES35, Mdl and 2 others like this.
  2. Jun 18, 2025 at 9:30 AM
    blenton
    blenton New Member
    This is why. All in the same trip.
    IMG_6960.HEIC.jpg IMG_6918.HEIC.jpg IMG_6905.HEIC.jpg IMG_6896.HEIC.jpg IMG_6964.HEIC.jpg IMG_6928.HEIC.jpg IMG_6899.HEIC.jpg
    Sure, you can click in and out of 4wd 30 times, but it is MUCH easier to simply put it in AWD and let it work.
    The first week I had my SC, I was driving down the freeway on clear but wet roads at a manageable speed with light traffic. It was winter time and we were in the middle of a storm lull - heavy wet snow the night before, more snow to come that evening. Climbing a small hill, the truck downshifted to 5th and revved to all of 2400 RPM, but it was enough torque to break the tires loose and send me sideways at 70 MPH. I kept it on the road but wouldn't have had an issue in AWD.
  3. Jun 18, 2025 at 9:37 AM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Price is it. Adding a torsen diff to the transfer case adds at least $500 parts cost and another part number to the system.
    I am surprised it wasn't offered in Limited trims like GM did around the same time and Ford does now.
    HulkSmurf14, Mdl and blenton[QUOTED] like this.
  4. Jun 18, 2025 at 9:49 AM
    blenton
    blenton New Member
    100% agree about the premium trims not getting the option. What's interesting is the parts counter price for a 2014+ tundra t case is virtually the same as a sequoia AWD t case. Not saying that's what it looks like on a manufacturing level, but interesting none the less. I also understand that they would need a few other bits and bobs unique to an AWD tundra in an assembly line, like a different rear drive line, which drives up manufacturing costs. It is nice, though, that so many parts are shared between the two platforms. Rear brakes, for example, are identical even though the sequoia has a completely different independent rear suspension setup. And the fact that you can literally swap the 4wd body module between them is awesome.
    HulkSmurf14 likes this.
  5. Jun 18, 2025 at 10:05 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    When I have switched to 2WD & forgotten, I hate how the truck feels & have to put it back into 4WD ASAP.
  6. Jun 18, 2025 at 10:07 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I would've just left it in 4WD the whole time and let it eat :rofl:
  7. Jun 18, 2025 at 12:07 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    I want AWD for the same reasons @blenton mentioned. When I retire, the wife's aunt lives in the UP, right on Lake Superior, other family in Oklahoma and Tennessee .Lots of snow and ice. We will be towing the TT up there and many places across the country with unpredictable weather.
    #2 Reason...because I can .........and a lot cheaper than most.
    To each his/her own.
  8. Jun 18, 2025 at 12:11 PM
    e30cabrio
    Motor will be going to the installer today.
  9. Jun 18, 2025 at 12:16 PM
    Bluecobra
    Bluecobra New Member
    2014 Tundra
    Where can I find diff bearings for a 2014? I am putting in the Powertrax and can't find any that will be here before July 3.
  10. Jun 18, 2025 at 12:22 PM
    bflooks
    bflooks New Member
    Metrowest MA
    East Coast Gear Supply (ECGS). Expensive, but they appear to be in stock.
    HulkSmurf14 and blenton like this.
  11. Jun 18, 2025 at 12:22 PM
    blenton
    blenton New Member
    Carrier bearings? Or the full kit? We ordered carrier bearings from Randy’s Ring and Pinion (Randy’s Worldwide is their website IIRC). They are a west coast operation. I tried my local transmission and drivetrain warehouse with no luck, found specs for the bearings and went to the local bearing supply store with the same luck. Toyota specs them slightly different than an off the shelf bearing - like 2mm wider - so most parts houses don’t stock them readily. I think East Coast Gear supply should have them if you are closer to that coast.
  12. Jun 18, 2025 at 12:35 PM
    snivilous
    SW UT
    Placing an order with the machine shop in a week or two, if there's any custom parts people want, let me know!
  13. Jun 18, 2025 at 12:50 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Billet shock tower brace lol
  14. Jun 18, 2025 at 1:04 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
  15. Jun 18, 2025 at 1:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    https://www.summitracing.com/parts/ntn-nbdrk382mk
    Well it does come on July 3rd but the price is right. Koyo bearings. I used it for my rear Speedmaster lsd install.
  16. Jun 18, 2025 at 1:14 PM
    blenton
    blenton New Member
    I'm still waiting for my broken one to get fixed and sent back to me. :oops:
  17. Jun 18, 2025 at 1:18 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Making progress. Bearings were toast and coupler had slop compared to new.
    Screenshot_20250618_131629.jpg 20250618_113127.jpg Screenshot_20250618_131656.jpg
    j_supra, Wynnded, HulkSmurf14 and 9 others like this.
  18. Jun 18, 2025 at 1:46 PM
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra RCSB
    Hidden Winch Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    95mm throttle body and a pulley for the Whipple I don't have yet...
  19. Jun 18, 2025 at 1:49 PM
    snivilous
    SW UT
    Probably be ordering RevC of the throttle body, still trying to get it to play nice with the stock ECU. The Whipple pulley I could, but I think all the Whipple pulleys are cross compatible so I would just buy one from them :D
  20. Jun 18, 2025 at 1:54 PM
    Bluecobra
    2014 Tundra
    Found them at East Coast Gear. Pricey, but needed. Thanks for the info.
  21. Jun 18, 2025 at 2:06 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I thought it was standard to just he-man that beast off the engine.
  22. Jun 18, 2025 at 2:27 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    What size pulley I've got spares lol
  23. Jun 18, 2025 at 2:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My back can't take it anymore. I put it by myself and that was pushing it. Think thats when I broke my radiator overflow nipple. As you get older we are supposed to be wiser...:D
  24. Jun 18, 2025 at 2:59 PM
    e30cabrio
    Motor done, being delivered to the shop, AAA took the Sequoia there now.
    Never expected less than 72 hours after they got my core that it would be done.
  25. Jun 18, 2025 at 3:05 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    That's impressive turn-around time!
    e30cabrio likes this.
  26. Jun 18, 2025 at 3:08 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    So what did you end up having done? Stock pistons, upgraded rods and hardware etc?
  27. Jun 18, 2025 at 3:12 PM
    LILTRD
    LILTRD New Member
    2013 Tundra RCSB
    That's what I've got to figure out. I'm at sea level and not sure which pulley size is appropriate for staying in the "safe" range, if you have insight with the different sizes you've used, us new Whipple guys would surely appreciate it.
  28. Jun 18, 2025 at 3:19 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I'm also at sea level- I went a few steps down but typically one step is 1psi but I found the 2 steps down was about the same as the first so I kept moving down in size. Ultimately I ended up at 10-10.5psi (3.25 pulley) before the updated intake and exhaust which now nets me around 8.5-9.0ish. I would say 1 step down is plenty safe..
  29. Jun 18, 2025 at 3:31 PM
    e30cabrio
    Stock+ (they said they are better aluminum) pistons & rods, going down 1mm on the pulley to stay at or under 10lbs, adding e85 & Aquamist. I'm already .000000001mm from living in it without spending another 5+k on forged internals.
    From the piston picture I found this, don't know for certain if it's the same.
    https://www.amazon.com/DNJ-PRK978-2007-2019-Naturally-Aspirated/dp/B09KFWX85L?th=1
    Wife is already like just drive the Camry & junk the tree so just doing this is pushing it.
  30. Jun 18, 2025 at 3:50 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Maybe I missed something but why would you need to be in four wheel drive so much?
    In fact I had to of missed something!!!
