  1. Jun 17, 2025 at 7:57 AM
    Dakillacore
    Georgia
    It may seem a little.....unorthodox, BUT if you want to save some dough and you have some extra clear silicone laying around.....go ahead and hit the inside surrounding edge of the unit. It'll seal up where the seal failed.
    I did this on my cheap-o garbage CARID set that I bought a few months ago.
  2. Jun 17, 2025 at 7:58 AM
    sportbike37
    sportbike37 New Member
    FL
    Also wanted to mention that you have to drop the spare tire to gain access to bleed the LSPV. Others may have done it without dropping the spare tire, but this was not the case for me.
  3. Jun 17, 2025 at 8:40 AM
    I’ve not had any problems bleeding mine in a 2000 AC with the spare in place.
  4. Jun 17, 2025 at 8:42 AM
    Location as viewed from the passenger side in front of the rear axle looking towards driver rear (old picture)
    oscardog86 likes this.
  5. Jun 17, 2025 at 8:47 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Went to drive the truck today after a couple days of on-and-off rain. Looking like I have the cowl leak going on. Water pooling up in the passenger side floor board only, doesn't appear to be coming from anywhere overhead or A pillar, windshield, etc. and more likely coming around the the blower motor area above the footwell.
    Referred to the sticky already https://www.tundras.com/threads/definitive-2000-2006-cab-area-rain-water-leak-thread.70464/. I'll have to go ahead and order the parts referenced in there and get this taken care of.
    Voss, BroHon, Filthyphil and 2 others like this.
  6. Jun 17, 2025 at 9:21 AM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    They were $56 a piece
  7. Jun 17, 2025 at 10:28 AM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Did my valve cover gaskets over the weekend (and redid the passenger side last night). Learned a lot and hopefully all is good now. No more oil leak this morning driving to work, but I do need to go to LAP and clear my check engine light and drop off old oil. I did a long write up with pics on my build thread: https://www.tundras.com/threads/2004-dc-4-7-4wd-build-log.128950/
    bmf4069, BroHon, shifty` and 3 others like this.
  8. Jun 17, 2025 at 12:01 PM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Yeah I probably should have went that route but I was tired of it, I already drilled a hole in it a while back, which also broke off the drill bit inside the light. May just wait for another Toyota parts sale and order up some OEM units and be done with it.
    Hi06silver likes this.
  9. Jun 17, 2025 at 1:05 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Smart. You don't want to wait too long like I did and have to buy a new blower motor.
    Dblock500[QUOTED] and BroHon like this.
  10. Jun 17, 2025 at 4:04 PM
    Adding to @KNABORES ’ already great post here to say: The reasons bleeding the LSPV is important are many. But one big one is, it sits higher up than any other point in the brake system after the cab, so guess where air is gonna go if it enters the system anywhere after the cab, or at the rear bleeders?
    Not to say there aren’t other reasons. It acts as a limiter/pinch point for the rear drums also, and old fluid, crud that builds up in the lines, all that is more likely to get jammed up in a bottleneck like that. You really want clean juice pushed thru it.
    Really, I disagree (despite parroting this method in the past, before bleeding my own truck) with the recommendation to do the farthest wheel (rear passenger first), then LSPV, then rear driver, passenger front, and driver front. It makes more logical sense to me (note, I’m by no way the authority here!) to bleed the LSPV first, to get fresh fluid to the rear of the truck, THEN bleed the passenger rear, then the driver rear. This way, you’re pulling any bullshit out of the lines up to the LSPV, any air from the LSPV, and getting a clean supply to the farthest corner. I can’t think of a reason why this method is inferior in any way.
    If our trucks were 4-way discs with no PV at all, direct-plumbed from the ABS squid to the calipers, YES, I would do passenger rear, driver rear, passenger front, driver front. But given the bleedable LSPV back there, I don’t see the logic in doing the passenger rear before the LSPV.
    Honestly, I’m going to step out on a limb and say something maybe controversial here. I would follow the Professional Hand Model method to apply a paint-safe sealant and reinstall the two offending fasteners, because the new Toyota part simply adds a tiny piece of foam that some members, like @NickB_01TRD (I think?) found will ultimately tear again with time.
    If you do choose to order fasteners for feet of the plastic breaking, as it is old, and they do break, let me tell you:
    • Only order two, remove their foams, and use a paint safe sealant to seal them in without foams
    • Order at least half a dozen of both the black snaps and their white sockets, because you are almost assuredly going to break two or three of each when you pop the cowl.
    • Be prepared to spend 1-2 hours on the job, if working leisurely, you will probably find a lot of buildup and bullshit under the cowl that needs cleaning.
    Honestly, I hit up a 25% off sale and got new OEM housings. Hindsight being 20/20 as it tends to be, I wouldn’t do it again. This is one of those times where you’ll get as much life out of two CAPA certified housings as a single pair of OEM, and still pay less for the CAPA aftermarket’s.
    bmf4069, Sirfive, oscardog86 and 3 others like this.
  11. Jun 17, 2025 at 4:30 PM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    One reason is if you live in the rust belt. When in the rust belt, never try to remove/loosen something you don't have to.
    In related news, ban road salt.
  12. Jun 17, 2025 at 4:32 PM
    You can probably break that apart with a hammer.
  13. Jun 17, 2025 at 4:33 PM
    To be fair….
    The OEM tow package support is notorious for rusting all to fuck, even happens in California trucks.
    04TundraTRD likes this.
  14. Jun 17, 2025 at 6:18 PM
    Dblock500
    DMV
    Thank you, I will heed this advice and was already planning on just ordering exrta clips. have a knack for always breaking any type of clip/push pin that ever needs removed
    Bought2Pull likes this.
  15. Jun 17, 2025 at 8:10 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    Coincidentally, today I almost asked a few of the very questions about required number of cowl fasteners and other related fasteners that you just answered here but rather than wait for a reply I just ordered. I am considering using some butyl rubber rope/tape without foil backing that I already have laying around to make butyl rubber gaskets to replace the foam gaskets. So rather than tape over like PHM, the butyl rubber would be under the head of the fastener. Do you think this will work?
    I ordered 8 of the cowl fasteners because the diagram suggested I needed that many. Sounds like this may have been overkill.
    BubbaW likes this.
  16. Jun 17, 2025 at 8:14 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Not a mechanic by any means but could one drill that hole out, completely removing the threads, then re-thread for a larger bolt?
  17. Jun 17, 2025 at 8:20 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Well today I did something truly substantial to my Tundra......I tore off a piece of blue painter's tape and stuck it to the driver's side of the windshield where the glass touches the roof. I couldn't find a marker but when I do I'll mark "Next oil change at: 204,000 miles."
    That's about all the free time today I had!
  18. Jun 17, 2025 at 8:42 PM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    That looks like it got completely full of water and then froze... a few times over. :eek2:
    I'm with you in the battle :fistbump:
    04TundraTRD, bmf4069, shifty` and 6 others like this.
  19. Jun 17, 2025 at 8:45 PM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Mine is fairly rusted also but is holding fast so far.....
    I might try to remove it at some point, after I source a replacement. :)
  20. Jun 17, 2025 at 8:50 PM
    That tow hitch doesn’t surprise me one bit.
    Salted snow always gets caked up behind the rear bumper and rarely gets washed due to its hidden nature and not being in the direct path of an underwash spray at the car wash.
    I’m guilty of not crouching over to get the crap in behind the rear bumper myself.
    Bought2Pull and KNABORES like this.
  21. Jun 17, 2025 at 10:47 PM
    Hutcheson
    Hutcheson New Member
    Caleb
    2004 DC Limited
    Had a bit of free time before heading to work this morning, banged out the LBJs. Nice driving the truck now not having to worry about driving over my own wheel haha.
    Attempted to install the Timbren bumpstops this evening and couldn’t even get the nuts off the U-bolts as they’re completely seized. Soaking them overnight and I’ll try again tomorrow.
    bmf4069, Voss, des2mtn and 12 others like this.
  22. Jun 18, 2025 at 4:01 AM
    NickB_01TRD
    KY
    It was me, the new parts are junk. @Dblock500 it doesn't hurt to order more clips. I had some that were broke and some that wouldn't really tighten up and I wish the first time I pulled it that I had just replaced all of them. I now have enough to replace the rest but I'll wait till I have a reason to pull the cowl again and I'll replace.
    I'm always worried mine looks like this though I would think they would have said something during my frame replacement if it looked this bad. I probably need to pull my bumper and take a look at it since I tow fairly often.
    What's your plan to replace? Isn't this part getting hard to find?
    Dblock500 and G_unit3000 like this.
  23. Jun 18, 2025 at 4:04 AM
    NickB_01TRD
    KY
    Missed this part on my last post. I have CAPA certified Depos, just can't seem to get my hands on a passenger side corner light that lasts more than 6 months without leaking. I just might get OEM corners, because so far the headlights have been fine.
    shifty`[QUOTED] likes this.
  24. Jun 18, 2025 at 4:24 AM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    I was thinking along similar lines.
    is there enough room to use a helicoil?
    We kept them cause we had to use them occasionally on older truck exhaust bolt holes.
    Aluminum heads sometimes also.
    Pretty simple to use/install. Just need the tap for, and little plastic install “bolt.”
    Put some permanent loctite on in when installing. Just make sure the loctite is completely dry before installing the bolt or it’s not going to come back out.
    Never had any come backs on them.
    I’d get one with the tang break
    https://www.boellhoff.com/us-en/products/special-fasteners/helicoil-thread-inserts-for-metals/
  25. Jun 18, 2025 at 6:42 AM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    My frame was done in 2010 and the truck hasn't seen salt since 2014, so I assume most of this damage was already done.
    The part for my truck is 52043-0C010 and it was still available. Oddly, it doesn't match what the parts diagram shows for a truck with the factory hitch - mine looks like the upper one rather than the lower.
    I wouldn't pull the bumper cover unless you're already planning to replace. The four bolts on the bottom came out ok (surprisingly), but I broke just about every other bolt.
    Not sure how much extra support it really provides since there's only the two bolts going down into the receiver (90119-A0003), maybe mostly to help support tongue weight? In any case I'm not interested in finding out.
  26. Jun 18, 2025 at 6:50 AM
    Dblock500
    DMV
    Yeah I'll order 8 of the clips too and just replace them all but only 2 of the passenger side foam fasteners causing the leak--that's the total number that's on there right? Its always hard to tell with these half-helpful Toyota diagrams smh. I haven't ever opened the cowl yet, but I suspect that would work if it is a thinner rope. I have some butyl tape laying around too when I was sealing up my camper but I believe that was 1/4 inch or maybe half? I also have some clear waterproof sealant from my 3rd brake light that I was just going to use to re-enforce the outside seal of the foam gasket clips like you and shifty mentioned (aka the PHM method apparently)
    Where'd you order from? I'll order from my local dealer just so I can get it next day but pay the premium they charge for any little part (soo irritating how expensive this dealer is with ANYTHING)--My recent orders from Serra have been taking forever to be shipped out.
  27. Jun 18, 2025 at 7:40 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I did my own, LBJ's, had my own thread on it. Ended up buying an OTC kit. Did on my back, in the grass, truck up on 6x6 blocks, with hand tools. SUCKED
    Damaged one tie rod end (threads) but replaced it. Could not get other old one off....stealership did that one.
    Good to do one's own work, as much as one can! Congrats.
    Hutcheson[QUOTED] likes this.
  28. Jun 18, 2025 at 7:55 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Don't mind me :rofl:
    bmf4069, Voss, Filthyphil and 3 others like this.
  29. Jun 18, 2025 at 8:08 AM
    Yeah, but then you gotta remember which bolt is different out of the 5. I’m too old for that shit.
    Butyl sounds like a great idea. You’d really only need a 3/4” x 3/4” square that was 20-30 mils thick (really, 1mm thickness would work) and ideally something that’s sticky on both sides. The product you’re showing is too thick, unless you rolled it out, the clip won’t snap into place. The clips for the cowl screws have two tensioned arms that grab the cowl, pulling the fastener into the foam to seal the hole. Find a pic of the clip and you’ll see what I mean.
    Best bet is to find another truck with tow pkg and swap it over. A couple of freebies have popped up on here over the years.
    Sometimes delays are caused by them needing to order parts, to get them in-hand, to be able to ship out.
    That said, part numbers and quantities; I think, are in the definitive leak thread (sticky), as is a very clear picture from @BubbaW showing the two problem clips you want to target.
    G_unit3000[QUOTED] likes this.
  30. Jun 18, 2025 at 8:47 AM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Voss likes this.
