DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. May 20, 2025 at 1:52 PM
    #3781
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Someday I’ll be a member. :fingerscrossed:
  2. May 20, 2025 at 4:43 PM
    #3782
    rcsbguy
    rcsbguy New Member
    Update: “37s” fit and clear normal street driving. I still need an alignment, but I’m not touching cab mount in any area, even on dips. I will pull suspension and set bumps appropriately.
    Wheels: Method 703 +35MM in 17x8.5”
    Tires: KO2 37x12.50r17
    Update after driving and flexing it out: No rub anywhere. Still need to pull suspension to set bumps.
  3. May 20, 2025 at 4:54 PM
    #3783
    COTundra23
    COTundra23 New Member
    man that looks so good! Congrats. I’m shocked it doesn’t rub the BMC but I guess between the kings and 35mm offset, that’s a secret recipe?
  4. May 20, 2025 at 5:04 PM
    #3784
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  5. May 20, 2025 at 5:05 PM
    #3785
    rcsbguy
    rcsbguy New Member
    I need to cycle with all the suspension out. The lift doesn’t help at all with clearing the tire.
    No stock front bumper means I can max out my rear LCA cam tab and gain the most clearance without rubbing anything. The +35mm offset helps keep the swing of the tire close to original factory settings. And the 37” KO2s run very small, which takes a lot of the pain out of fitting bigger tires.
    COTundra23[QUOTED] likes this.
  6. May 23, 2025 at 1:25 PM
    #3786
    CO.Tundra
    CO.Tundra New Member
    Taylor
    2019 White Tundra
    Coach Builder 1” shim, +2 Shackles. 285/75r18 AT3
    Fresh as of this morning. Method 703 +35, 37x12.5r17 Cooper AT3 XLTs load D. JBA uppers, Pro coilovers with Eibach springs. Deaver mini pack and CB +3’s. Will trim after alignment, has a small BMC. Minimal rubbing prior to alignment. About 1lb lighter than 285/75r17 Toyo AT3’s and pro wheels, dead quiet too. IMG_3039.jpg
  7. May 23, 2025 at 6:27 PM
    #3787
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    That looks amazing, perfectly proportional.
  8. Jun 5, 2025 at 8:32 PM
    #3788
    bwillis625
    bwillis625 New Member
    2019 Cement Crewmax TRD Off Road
    What size tire are you running with the new wheels? Lift? BMC? You’re the first Tundra I’ve seen with the Nomad Convoys +25. Looks really good!
  9. Jun 7, 2025 at 4:44 AM
    #3789
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    Thanks! These are the Falken Wildpeak AT4w, in 37/12.50r17. I have around 3” of lift front and rear and a deep BMC. I was running a set of Ironman UCA’s, but recently discovered that my upper ball joints were shot after around 75k miles. I haven’t been happy with my alignment with the Ironman UCA’s for quite sometime, so this seemed like a good opportunity to ditch them for a new set from Dirt King. Despite a couple different engineers telling me that I wouldn’t notice any difference, the Dirt King UCA’s corrected my alignment issues and the front end feels much better. Next on the to-do list is polyurethane steering rack bushings.
  10. Jun 7, 2025 at 5:03 AM
    #3790
    COTundra23
    love those nomad wheels. What rear bumper is that?
  11. Jun 7, 2025 at 5:09 AM
    #3791
    sea_weathered
    Pacific Ocean
    Thanks! It’s a Rough Country bumper. Definitely not the most boozhy bumper on the market, but it matches well with the look of my camper and gives me a tad more ground clearance on the corners.
  12. Jun 7, 2025 at 5:18 AM
    #3792
    COTundra23
    for RC… that’s pretty darn clean!
    sea_weathered[QUOTED] likes this.
  13. Jun 7, 2025 at 6:45 AM
    #3793
    bwillis625
    Right on! I put a search in for “Nomad Convoy wheels” didn’t realize the thread was titled Dirty Sevens. Should have known you were on 37’s. Was just excited to see a Tundra with the +25 offset. I think that’s the perfect offset for Tundras. Most retailers say they won’t fit ie Discount Tire, Customwheeloffsets.com to name a couple, but Nomad customer service said they would and seeing your truck is confirmation Thanks again for the info!
    COTundra23 likes this.
  14. Jun 7, 2025 at 7:08 AM
    #3794
    sea_weathered
    Pacific Ocean
    That’s odd. I had absolutely no problems getting them to fit. They were even easier to clear the weights from brake calipers than Methods I previously was running
  15. Jun 10, 2025 at 7:52 AM
    #3795
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Questions, Im getting ready to install all my suspension goodies and 37. Are you guys using the oem TPMS or aftermarket?
  16. Jun 10, 2025 at 9:04 AM
    #3796
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Factory alloy wheel TPMS will work in aftermarket alloy wheels.
    If your factory wheels are steel then you’d need new TPMS sensors for aftermarket alloy wheels.
    Dave8699[QUOTED] likes this.
  17. Jun 10, 2025 at 10:17 AM
    #3797
    Dave8699
    Dave8699 Trackrat
    NJ
    Yea im going from the 1794 alloy to Icon so I should be good.
    eccracer104[QUOTED] likes this.
  18. Jun 13, 2025 at 4:44 AM
    #3798
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    You guys are a terrible influence, fifth matching wheel, Hypertech Speedo Calibrator, and 37x12.5R17 Kanati Mud Hogs Ordered. If anyone is looking, I got 5 from Walmart for $1,369 delivered to the store, which I just couldn't pass up.
  19. Jun 14, 2025 at 4:21 PM
    #3799
    martiartisan
    martiartisan New Member
    Kansas / Oregon
    2020 Cavalry Blue Tundra DC
    Adv fiberglass, king suspension, cbi armor, RLD Cap
    Looks great. I need to do a cab mount relocation soon! What tire pressure are you running in your nittos?
  20. Jun 14, 2025 at 4:23 PM
    #3800
    Dave8699
    Dave8699 Trackrat
    NJ
    Dropped off my stock Tundra to get all my goodies installed. Very long list of a collection I been stacking. Cant wait
    WinterWarlock21 and martiartisan like this.
  21. Jun 14, 2025 at 4:34 PM
    #3801
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    I try to run 38ish up front and 35ish in the rear unless I’m towing or hauling (rarely ever do). I figured once the tires warm up it would be a little firmer. But truth be told I don’t know what they are at right now lol I do prefer them firmer than most I can tell you that.
  22. Jun 14, 2025 at 5:17 PM
    #3802
    martiartisan
    Kansas / Oregon
    Awesome. I’ve been bouncing around with different pressures trying to find the best fit pair with my suspension and changing loads
  23. Jun 14, 2025 at 5:32 PM
    #3803
    JRS
    JRS New Member
    2012 DCLB
    I've got the same wheel setup and run 43/28. I chalked when I first setup and realized with the Ridge Grapplers that the contact patch should be about three tread blocks. Then, when I load up differently between the bed or trailers, I've got a good visualization to shoot for.
  24. Jun 15, 2025 at 6:52 AM
    #3804
    martiartisan
    Kansas / Oregon
    Ill give this a try!
  25. Jun 16, 2025 at 9:30 AM
    #3805
    COTundra23
    Finally came across someone on facebook who is running 37s on the BBS wheels.
    13.5 too…
    Helo, 300BLK, TNThunder and 4 others like this.
  26. Jun 17, 2025 at 8:49 AM
    #3806
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Wow that looks awesome. IMO any gen Pro wheels look better than 90% of aftermarket wheels, they just need the right tires.
  27. Jun 17, 2025 at 1:49 PM
    #3807
    COTundra23
    Tend to agree.. and while I’m a whore for new shoes, I always keep coming back to the pro BBS wheels. That’s even after running rock warriors!
  28. Jun 17, 2025 at 7:27 PM
    #3808
    NoMoreGreen
    NoMoreGreen New Member
    Robert
    2020 Tundra
    I have method 701 18x9s +25 backspacing.
    Bmc
    icon billet UCA
    icon 2.5 remote resi shocks. Otherwise stock.
    Im needing new tires. 37x12.50 will fit right?
    (5.29s for gears)
  29. Jun 17, 2025 at 7:32 PM
    #3809
    SAGE63
    San Diego County
    ah yeah... might need to lose the swaybar. If you off road hard and fast you will lose er self clear the fender liner... also fold the pinch weld
  30. Jun 22, 2025 at 4:35 AM
    #3810
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Got everything mounted yesterday and clearanced last night. Long story short I had to replace pretty much the entire front end, so I was able to get a dead on factory alignment. Excited to get out and see how the truck performs!
    Edit: Wheel and Tire Specs
    Icon Six Speed 17” Wheels
    Kanati Mud Hog 37x12.5R17
