  1. Jun 16, 2025 at 7:14 AM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    Well, it appears I have made my first DIY goof up. Did my Valve Cover gaskets over the weekend, Passenger on Saturday, Driver yesterday. I've got a decent oil leak on the passenger side, but driver looks good. The leak appears to be coming from the bottom rearmost bolt on the cover - at least that area. It happens for a short period of time after running, but stops after 30 min or an hour. That bolt is the only one I couldn't get the torque wrench onto due to a dipstick in the way (Transfer case??) , so I hand tightened it with a ratcheting wrench. I did my best to do the X pattern when tightening the 9 bolts, but maybe it just had uneven pressure. I already went and tightened the bolt down a little more with no success stopping the leak.
    What should I do next? Loosen it all back up and retighten? Take it off, clean up the FIPG, new gasket and FIPG and try again?
    Dakillacore, oscardog86 and Voss like this.
  2. Jun 16, 2025 at 7:16 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Did you reseal the halfmoons at the same time?
  3. Jun 16, 2025 at 7:29 AM
    That dipstick is the transmission. I’m guessing that means that’s never been checked.
  4. Jun 16, 2025 at 7:37 AM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    I did pull them and reseal them with toyota fipg. And I resealed the spots up toward the front as well. Cleaning off the old FIPG was a pain, and I'm wondering if maybe i didn't clean off all the old stuff perfectly enough? I was trying to keep from knocking it into the engine.
    Haha. You got me. To be fair I've only put 20k or 25k on it. But I know. shame shame.
  5. Jun 16, 2025 at 9:43 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
  6. Jun 16, 2025 at 9:44 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Needs a functioning light bulb inside so it looks like a lantern.
  7. Jun 16, 2025 at 9:44 AM
    Do you fill it with fireflies you catch while camping? Looks cool.
  8. Jun 16, 2025 at 9:44 AM
    des2mtn
    SW
    Tonto cover
    I love how we both had similar thoughts right away.
  9. Jun 16, 2025 at 9:50 AM
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    :101010:
    The Black Mamba likes this.
  10. Jun 16, 2025 at 9:59 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I will be painting the catch can
  11. Jun 16, 2025 at 10:03 AM
    des2mtn
    SW
    Tonto cover
    Do the light idea still, then paint it black except for small stars.
  12. Jun 16, 2025 at 10:04 AM
    Nooooo!!!! A glowing red light that dims and brightens with MAF voltage readings is the way!!
  13. Jun 16, 2025 at 11:01 AM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4 - GFC
    Put a Jackolantern over that come spooky season
  14. Jun 16, 2025 at 11:48 AM
    Jokes aside, what is the purpose of that?
  15. Jun 16, 2025 at 12:33 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Prefilter
    Voss, bmf4069, oscardog86 and 4 others like this.
  16. Jun 16, 2025 at 12:34 PM
    Wanna see a one month supply of dirt particles report
  17. Jun 16, 2025 at 12:45 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    I can tell you that the ram head was dusty inside when I took it off. Air filter is still clean
  18. Jun 16, 2025 at 1:15 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Voss, Kalannar97, Dakillacore and 9 others like this.
  19. Jun 16, 2025 at 1:16 PM
    More like @Darkness approved
    Voss, des2mtn, bmf4069 and 9 others like this.
  20. Jun 16, 2025 at 1:30 PM
    TXTundraGuy23
    Dallas
    2004 DC 4.7L 4WD
    I'm gonna loosen it all the way back to finger tight tonight and retighten. See if maybe it got a little canted or something. For the X pattern tightening on the valve cover - is it inside out or outside in?
    oscardog86 likes this.
  21. Jun 16, 2025 at 1:31 PM
    When in doubt, inside out
    bmf4069, BroHon, shifty` and 2 others like this.
  22. Jun 16, 2025 at 1:35 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Voss, bmf4069, Jack McCarthy and 4 others like this.
  23. Jun 16, 2025 at 2:58 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Missed opportunity to paint a black snake
  24. Jun 16, 2025 at 4:53 PM
    manofsteele2003
    manofsteele2003 New Member
    Grant
    24 Sequoia TRD Pro
    Westcott designs 3"/1" lift 295/70/18 Falken Wildpeak RTs Canvasback cargo liner aFe Tow hooks
    Installed a Garmin Mini 2 I had leftover from my 4Runner and new OEM marker lights. I was going to get a black set but the headlights were new OEM so I had to go with stock. It's the little details that make all the difference.
    PXL_20250616_180523849.jpg PXL_20250616_180512361.jpgPXL_20250616_165532016.jpg PXL_20250616_165543556.jpg PXL_20250616_173712154.jpg
  25. Jun 16, 2025 at 6:54 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
    Tap and die set is good tool to have and can help when threads get dirty or galled.
    But in this case think if the threads are stripped so the bolt spins in place that cleaning the threads won't add more material to grab into. Helicoils, rivnuts, or welding then drilling/tapping are ways to restore the threads so they have the material to mate to the bolt.
  26. Jun 17, 2025 at 3:59 AM
  27. Jun 17, 2025 at 3:59 AM
    bfunke
    bfunke Tundra Curmudgeon
    Thread chasers are designed to straighten damaged threads. Taps and dies are designed to cut new threads.
    ToyotaDude, shifty`, des2mtn and 2 others like this.
  28. Jun 17, 2025 at 4:02 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Hmm didn’t necessarily realize they still made the corner markers OEM. How'd you do on cost? My passenger side depo one is leaking just like the one it replaced under warranty. May have to go the OEM route one day. Depo headlights are working great though.
    Dakillacore likes this.
  29. Jun 17, 2025 at 5:39 AM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    Brake fluid flush is next on my list…I haven’t looked at fsm yet to see if this the LSPV, but most pics show it under the truck, and there is no bleeder valve to be seen on it so what is this? Part of ABS?
    haven’t seen anything like it on the forerunner.
    Voss and oscardog86 like this.
  30. Jun 17, 2025 at 5:47 AM
    That’s an ABS module. The LSPV is behind the gas tank on the drivers side above the rear axle. All of the brake lines in the back can be traced from the drums back to it. There’s a lever on the passenger side of the rear axle that actuates a rod that stretches back to the drivers side that also leads to the LSPV.
    BroHon, des2mtn and Redoak[QUOTED] like this.
