2022 Tonneau covers
Discussion in 'Tonneau Covers, Caps and Shells' started by ak407, Jan 22, 2022.
  1. Jan 29, 2024 at 5:54 PM
    #1531
    ShutterFlare
    ShutterFlare New Member
    2024 Tundra 1794
    I went with the Bakflip Revolver X4S. Very happy with my choice so far. It rolls up securely if I need access to the full bed. Been through a few rains, no leaks yet. Took a while to align perfectly, but total install was still under an hour.
    J&ATundra, Mattedfred and ziznack like this.
  2. Feb 25, 2024 at 11:15 AM
    #1532
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Anyone know of a cross bar that works with the backflip mx4. Prefer it to be easy to remove as I only need it when camping. Our bikes will go on a hitch bike rack on the camper.
  3. Mar 6, 2024 at 4:09 PM
    #1533
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    If anyone is interested, like new Retrax PRO cover is available for sale. I added the XR rails with T-slots. I still have the reg non slot rails as well. I’m in the northeast. Not looking to ship, too bulky. If interested, send me PM, make an offer. Only selling because I want to get a paint match cap.
  4. Apr 1, 2024 at 4:36 AM
    #1534
    TFTJ
    TFTJ New Member
    Hey all, I've had the bakflip mx4 for a while now and whenever it rains I get water in the truck bed. Anyone have any remedies? I emailed bak no response yet.
  5. Apr 1, 2024 at 5:29 AM
    #1535
    drewpweinerMD
    drewpweinerMD MPG’s are for your moms Prius.
    Jeremy
    2024 Limited TRD OR
    RB20 Slims, BAK X4s, Fabtech Level, Cooper 35's
    Most tonneau covers are not water proof but claim some weather resistance with some better at it than others. Are you experiencing water intrusion at the tailgate or bulk head? Have you tried using foam gasket?
    ziznack likes this.
  6. Apr 6, 2024 at 5:22 AM
    #1536
    TFTJ
    TFTJ New Member
    Have the foam gasket.
    Isn't the first truck I've had, but the first truck that the cover hasn't kept the water out.
    I have a plastic bed liner cover thing and it's constantly getting water on it. I've tried to shift the tonneau around a little and it doesn't help. Pretty annoying.
  7. Apr 7, 2024 at 5:14 AM
    #1537
    2494
    2494 New Member
    2024 Tundra 1794
    Man that looks nice and gives back the much needed space I lost with my RollnLock
  8. Apr 7, 2024 at 1:05 PM
    #1538
    NoHater
    NoHater New Member
    I picked up the rough country retractable cover. I wanted a retractable cover and didn't want to spend much more than 1k and didn't want to go on a cheap one. Rough country is at least a known brand for their parts. Install was super easy and it stays absolutely dry inside. Only time will tell on the overall quality as it lives through the seasons but I am pleased with the build quality and look of it. The bucket seemed on the smaller side in comparison to others too.
    myfirsttundra1 and Tundraman479 like this.
  9. Apr 17, 2024 at 4:01 PM
    #1539
    TFTJ
    TFTJ New Member
    BAK finally got back to me, said I should buy a rubber gasket and rtv sealant to replace their foam thing, especially in the corners.
    Why they wouldn't just include this in the original package, especially since they know the solution is beyond my understanding.
  10. Apr 18, 2024 at 9:25 AM
    #1540
    geodimeter
    geodimeter New Member
    Doug
    2024 Tundra SR5
    Retrax XR and Yakima HD racks on my 2024 SR5. Had it on there all winter with no issues. Will use it for hauling my tandem kayak on camping trips plus ladders, etc.20231228_130204.jpg
    Beak01 and Carolina Peej like this.
  11. May 29, 2024 at 11:57 AM
    #1541
    meagain
    meagain New Member
    Any updates on this cover? I just purchased the E-Power version and hoping I made the right choice at less than half the Retrax powered version
    vtown76 and Dfrink like this.
  12. Nov 26, 2024 at 8:49 PM
    #1542
    Yota802
    Yota802 New Member
    Still available if anyone is interested.
  13. Nov 27, 2024 at 8:37 PM
    #1543
    celestialroger
    celestialroger New Member
    2025 Celestial Silver Tundra Limited
    Where are you located? I’m in Massachusetts. Interested if it makes sense.
  14. Dec 5, 2024 at 12:46 PM
    #1544
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    I just purchased and installed the manual retract version. Look very nice, install took about 2 hours however, I really took my time. I still need to put the drain tubes in. The fronts look easy enough, still looking for where to run the tubes back by the tailgate as I don’t see any pre-drilled locations there. Hoping someone can share some info here.
  15. Feb 3, 2025 at 6:40 AM
    #1545
    Shyro25
    Shyro25 New Member
    24 Tundra SR5
    Hi, may I ask what adapter you found? I have the RC bed cover and I do not want to drill too. Thank you
  16. Feb 3, 2025 at 6:48 AM
    #1546
    Breathing Borla
    Northern Illinois
    I did drill out the existing holes just a touch, its beyond easy, check this post out
    1371
  17. Mar 2, 2025 at 12:08 PM
    #1547
    cody.tx
    cody.tx New Member
    installed the TourTop Bed Cover from Rugged Bound Supply today - pretty awesome system!
    no drilling required, no c-clamps for install, chassis beam attaches to front of bed using existing holes from the rail system, lift strut brackets attach direct to side rails, brackets for the locking clamps attached behind the stock tie-downs
    can be easily removed in about 10-15 min by popping the struts off and 8 screws holding the cover to the chassis beam
    T channels across the top to attach whatever you like, and supports 550lb payload.
    lockable and completely water tight (have not tested this yet)
  18. Mar 3, 2025 at 10:19 AM
    #1548
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Update on my SyneticUSA MR cover. I've had it on for a couple months now. Lots of rain. This cover is great. Keeps 95% of water out of the bed. I get a few drops near the corners of the tailgate. Cover works great, looks good, and was only $1000 bucks all in. I had a few questions during the install, got a person on the phone right away to help me. Service was great. I removed the metal canister cover and installed my fork mount bike racks. Plan to leave the cover open when carrying bikes, although I could put a cross bar near the tailgate in the t-slots to elevate the bikes and be able to keep the cover closed. Plan to add a rack this spring, likely the Elevate rack. That will be a bit of a custom job. I'll update when that's completed. Thought I'd give a shout out to this cover company.
    Beak01 and vtown76 like this.
  19. Mar 7, 2025 at 4:39 PM
    #1549
    vtown76
    vtown76 New Member
    Nice! How big is the canister? I was considering the roll and lock because it’s supposed to take up the least bed space, but it’s pricy and people seem to hate the center strap getting in the way.
  20. Mar 7, 2025 at 9:03 PM
    #1550
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    It’s a bit smaller than the Retrax from what I understand, due to a smaller slat and slightly less weight capacity. I don’t plan on putting myself and a bunch of friends on it closed so not worried, . The MR still has a center strap, although if you watch the videos on the website you’ll see you can operate it without the strap.
    vtown76[QUOTED] likes this.
  21. Jun 14, 2025 at 9:43 PM
    #1551
    TFTJ
    TFTJ New Member
    Just keeping a record for my own purposes and for others if they want to do the same research.
    Decent rain this last week where I was, the BAKflip leaked like the Titanic. This is after I used half a tube to fill the goods everywhere I could find.
    This is utterly unacceptable for what I need a hard cover for.
    I had an RC on a previous truck that was nearly waterproof. Might need to go with that again.
  22. Jun 16, 2025 at 3:32 PM
    #1552
    Dfrink
    Dfrink New Member
    SR5 CM 4wd
    Finally got the rack installed. This setup turned out EXACTLY how I wanted it. I was able to score a SyneticUSA used rack (still in the box with plastic wrap, never even opened) from a guy on marketplace ($400!!) who bought it and ended up selling his truck. The rack installed perfect. In order to keep the bike fork mount viable, I had to put the front rack all the way up against the cab so the bike handlebars didn't hit the rack. Since the canister cover on this rack covers the t-tracks I had to drill out two larger holes on each side and then use the t track bolts for double duty of mounting the rack and keeping the canister cover on. It's actually easier to remove now then it was with the original canister hardware. Really happy with how this setup turned out.
    Beak01 likes this.
  23. Jun 29, 2025 at 5:52 PM
    #1553
    kilodelta97
    kilodelta97 2023 Platinum Crewmax
    Aroostook County, ME
    Black 2023 Platinum
    I recently installed a Retrax Pro XR on my 6.5 bed. Love it so far. I'm wondering if anyone has any storage solutions for a large case that will fit underneath the cannister? I want one large trunk/case that will fit completely under the cannister so If i have to use the rest of the bed, the footprint isn't further diminished by the gear I keep in the bed permanently. So far the best solution is an extra-deep pelican style rifle case, but I was wondering if anyone had other suggestions.
    Dfrink likes this.
