  1. Jun 14, 2025 at 9:30 PM
  2. Jun 14, 2025 at 9:32 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    phabej[QUOTED] likes this.
  3. Jun 14, 2025 at 9:34 PM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    Didn’t realize 2.5 gen was that much bigger than first gen
    Tennessee Fuel Hauler, ATV25 and BR73 like this.
  4. Jun 14, 2025 at 9:51 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I’ve got a mitchmade unit which is different than what he posted. But it seems yes that would be needed.
  5. Jun 14, 2025 at 10:35 PM
    Boneskull420
    Boneskull420 New Member
    Tn
    2018 tundra crewmax magnetic gray trd offroad
    Ironman 4x4 foamcell pro 3.5in lift Complete custom stereo with 2 12's under rear seat S&B/stillen Frankenstein cold air intake True dual exhaust with Carven Tr mufflers Rough country hood bulge led strip Running board led's
    I do have a 3.5in lift on mine and the fender flares with the wider tires but on the same note I think when the 07 came out they said the double cab had the same interior space and the 06 crew cab so that would make the 07-21 crewmax that much bigger.
    Leedaar[QUOTED] and bulldog93 like this.
  6. Jun 15, 2025 at 6:58 AM
    jackienguyener
    jackienguyener OKToyota
    Jackie
    2016 Tundra 1794
    Yes. But honestly, I don’t think you’d need it. I bought the $120 kit for the CSB spacers and didn’t end up using them. You should be able to reuse what you already have
    HulkSmurf14 likes this.
  7. Jun 15, 2025 at 7:05 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    Good morning
    Question: When replacing your upper control arms, are you properly torqueing down the bolt/nut? Or are you just doing the ugga ugga method? If you are properly torqueing, how are you getting the socket/wrench on the nut for the driver's side? There's no room to fit a socket on the nut. I'm able to get the socket/wrench easily on the bolt head but is that providing the proper torque spec needed?
    Any tips? Recommend tool? TIA
    bulldog93 likes this.
  8. Jun 15, 2025 at 7:08 AM
    centex
    centex New Member
    I’ve always just torqued from where I can get the wrench on.
  9. Jun 15, 2025 at 7:17 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    If the bolt can spin freely then your torque should be relatively the same when applied to the nut or the bolt. Is not exact, but it’s within the range of ugga duggas.
    Otherwise, you could get a crowfoot wrench - technically it adds distance so the torque wrench value will be lower than what is actually applied, but not by that much in this application. You could calculate that difference if you wanted to get fancy but I wouldn’t sweat it
  10. Jun 15, 2025 at 7:22 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    They have to be on torque wrench at 90 degree angle. Probably can find single longer ones in size you need.
    ATV25, Leedaar, HulkSmurf14 and 4 others like this.
  11. Jun 15, 2025 at 7:23 AM
    TacomaTRD4x402
    Southern California
    Appreciate the quick responses! :thumbsup:
    I got the torque wrench on the bolt and it felt like I was overtightening so I backed off and left it loose for now. I also thought of using crowfoot to see if I can get on the nut side. Unfortunately I don't have a 22 crowfoot nor do I have another vehicle so I ended up ordering it on Amazon. Should be here today!
    https://www.amazon.com/dp/B0D59QQTJ9
  12. Jun 15, 2025 at 7:26 AM
    TacomaTRD4x402
    Southern California
    Nice! That looks like it would also work
    Tunrod[QUOTED] likes this.
  13. Jun 15, 2025 at 7:27 AM
    RainMan_PNW
    Casey
    Clark County, WA
    If anything, I would expect turning the bolt would under tighten slightly due to the (potential) added resistance of the bolt turning.
  14. Jun 15, 2025 at 7:32 AM
    TacomaTRD4x402
    Southern California
    That reassuring to hear. Thank you. Last thing I want is to snap that bolt. I felt like I was about to.
  15. Jun 15, 2025 at 7:33 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I was always taught if using adapters 90 degree angle no calculations require however this may help if you go on straight.
    https://belknaptools.com/extensions-calculator/
  16. Jun 15, 2025 at 7:38 AM
    TacomaTRD4x402
    Southern California
    Super helpful. Thanks :thumbsup:
    I've also always used extensions at 90° so this will be helpful if I can't get the 90° angle with the crowfoot.
  17. Jun 15, 2025 at 9:30 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Hit the trail yesterday with the steepest climb and descent we have around.
  18. Jun 15, 2025 at 9:53 AM
    RainMan_PNW
    Casey
    Clark County, WA
    As an engineer…that isn’t 100% accurate, but it is close enough for the degree of precision needed for this sort of application.
    Torque is a measurement of force applied at a specific distance from the center of rotation. A Foot-Pound is one pound of force applied exactly one foot away from the center of the bolt.
    Your torque wrench is made to pop/break over at the set torque based on that setting and a specific distance from the center of the anvil to the setting point in the wrench. If you “choke up” on the wrench, it won’t change the applied torque because the internal setting is built into the wrench (it will make it harder for you to apply the needed force though).
    Adding anything to the anvil that changes the center of the rotation will change the applied torque. It’s a straight line from the pre-determined point in the wrench and the center of rotation.
    If we assume the point in the handle is exactly 1 foot from the center of the anvil, and you add an offset (crowfoot or one of the box-end versions) that is exactly 3” long from the center of the anvil square to the center of the hex, then you would measure the new applied length from the point in the handle to the new hex:
    If straight forward, the distance is 15”
    If straight backward, the distance is 9”
    If 90*, the distance is 12-3/8”
    The amount of actual torque applied (above or under the value of the wrench) is the difference between the wrench’s calibrated length and the actual length above - 125% for scenario 1, 75% for scenario 2, and 103% for scenario 3.
    ATV25, Xcumminsguy, RobertD and 2 others like this.
  19. Jun 15, 2025 at 1:37 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Father’s Day camping trip. Good time with the family.
    Tunrod, GAknight, 1794TX and 14 others like this.
  20. Jun 15, 2025 at 2:03 PM
    Boneskull420
    Tn
    Good times indeed!
    OHwendTrd[QUOTED] and BR73 like this.
  21. Jun 15, 2025 at 2:32 PM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Spent the weekend at the family cabin collecting fire wood for the winter. Then drove to Mt Rainier for Father’s Day.
    sofaking, Mdl, HulkSmurf14 and 16 others like this.
  22. Jun 15, 2025 at 2:50 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Installed diode SS3 Pro with SDHQ mounts and bonobo 360 swivel mounts. The click adjustability with the swivel mounts is great. I’m not sure if I like how high it puts the pods. Debating if I’ll keep them mounted that way. Shout out to @memario1214 for the hookup.
  23. Jun 15, 2025 at 3:15 PM
    TacomaTRD4x402
    Southern California
    Got bored n did this with a spare set of dash trims I got from a part out sometime ago. I've gone back and forth with painting these things but I wanted a bit more texture so this is what came of it..
    Will install later this week as I've got a list of mods I'm currently working on.
  24. Jun 15, 2025 at 3:45 PM
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    You go bro! :thumbsup:
    Boneskull420 and CaptRussia253 like this.
  25. Jun 15, 2025 at 4:20 PM
    TacomaTRD4x402
    Southern California
    Crowsfoot finally got delivered and it definitely helped. My torque wrench has a big head so it doesn't sit flush on the nut with the bolt pushing through so I had to use an extension bar to get it to sit flush on the nut. Plus it ran right through the hardlines perfectly. Not sure how much that affects proper torque but I doubt it's not a big issue.
    RobertD, bulldog93, BR73 and 2 others like this.
  26. Jun 15, 2025 at 4:50 PM
    therealjonwick
    JR
    2019 OR
    I used crows feet also. I think I also may have torqued at the bolt side. These bolts are way overtightened. I went to 150ftlbs with some blue locker and nylock nuts. No issues so far.
  27. Jun 15, 2025 at 5:56 PM
    TacomaTRD4x402
    Southern California
    Totally agree! Felt like I was gonna snap the damn thing! :eek2:
    French Avocado likes this.
  28. Jun 15, 2025 at 6:15 PM
    therealjonwick
    JR
    2019 OR
    Pretty sure Tacomas and 4Runners use same bolts and only torque to 85ft/lbs. strange.
  29. Jun 15, 2025 at 7:53 PM
    SwitchThrottle
    2021 Barcelona CrewMax
    Did someone say firewood?
  30. Jun 15, 2025 at 9:41 PM
    Boneskull420
    Tn
    I don't know about someone saying anything about firewood but my 1st thaught is I see one heck of a 4th of July bonfire in the near future!:nuclear:
    BR73 likes this.
