Adding an outlet to my bed.
Discussion in '3rd Gen Tundras (2022+)' started by Mexican Papi, Jun 15, 2025.
  1. Jun 15, 2025 at 1:47 PM
    Mexican Papi
    Mexican Papi [OP] New Member
    2023 Tundra SR5
    Tonneau Cover for now.
    Hey guys, I’m looking to add an outlet to the back of my bed in a 2023 tundra SR5 does anyone have any videos or recommendations on how to make this happen? I already have some LED lights in the back of the bed that are hooked up with a wire running through my battery. I would like the outlet to power up battery chargers for my tools like a drill. Maybe used to power up a light if we go camping.
  2. Jun 15, 2025 at 2:18 PM
    ansel123
    ansel123 New Member
    Sr5 2024
    Several
    How handy are you? Its not a simple fix
  3. Jun 15, 2025 at 2:20 PM
    Mexican Papi
    2023 Tundra SR5
    I would say I’m pretty handy.
  4. Jun 15, 2025 at 2:25 PM
    ansel123
    ansel123 New Member
    Sr5 2024
    Several
    Ok this is what i had done at a shop. I bought a 12v plug off the internet, surprisingly hard to find for this application. They had to run a wire all along the bottom of the frame to the battery. They had to pull off the truck bed lining on one side then cut into it to mount the plug. Now having said that im not sure it will run power tools i don't think even the standard inverter from toyota will do that but someone else knows more then me about that
  5. Jun 15, 2025 at 2:27 PM
    vmkeith
    vmkeith Slow is smooth, smooth is fast
    Vince
    Clark County, Wa
    2014 Super White Tundra SR5 CrewMax 4x4
    Rhino Lining Cooper Discoverer ATP II LT275/70R18 TRD Pro dual exhaust with TRD exhaust tips Lund 5" Cab Length Oval Curved Tube Steps RealTruck TruXedo Pro X15 Tonneau Cover RealTruck Elevate FS Bed Rack Rhino-Rack Carriers Diode Dynamics SS3 LED Fog Light Kit Auxito LED Headlight Bulbs Rydonair 7" antenna
    I'm not sure how to go about doing something like this, however, I have seen a lot of overlanding rigs that have many different power requirements and setups. I'd recommend looking into overlanding builds. There are some really good builds out there for many different vehicles, but quite a few are Toyota specific.
  6. Jun 15, 2025 at 2:29 PM
    Mexican Papi
    2023 Tundra SR5
    What do you use your plug for?
  7. Jun 15, 2025 at 2:30 PM
    ansel123
    ansel123 New Member
    Sr5 2024
    Several
    I use it for my setpower fridge works perfectly. I did buy a jackery battery so its not hooked directly to my truck battery all the time
  8. Jun 15, 2025 at 4:23 PM
    mtucker
    mtucker New Member
    Escondido CA.
    2008 Double Cab
    Listed in my build thread
    Question: It isn't clear to me if you want AC in the back of your bed or if 12VDC is OK. If you want to plug in a drill or battery charger, it would be nice to have AC. For 120VAC......I did this in a different (2.0) generation Tundra. I used this AC outlet https://www.amazon.com/dp/B09L7Q95HZ There was enough room between my bed liner and bed to mount it. If you want to run tools, you probably want to get a 1000W inverter. 1000W is close to 100A at 12VDC so you will need to run about 4AWG wire to the inverter. It is best to mount the inverter in the cab so it doesn't have to see any moisture/weather. The inverter output is high voltage so you don't need really thick wire into your bed. I ran some 14/2 UF-B wire (rated for direct burial and outside use) from my 1000W Renogy sinewave inverter. I can run my pole chainsaw no problem.
  9. Jun 15, 2025 at 7:58 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Had an outlet in the bed of one of my Trucks.
    Cant remember which one it was.
    It did come in handy at times,mainly to run a blender to make Margaritas.
    Narco likes this.
