Boost Auto Tow Mirrors
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2020Platinum, Apr 11, 2021.
  1. Jun 13, 2024 at 6:45 PM
    #211
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You can't post that without show us some pics. :thumbsup:
    texasrho83 likes this.
  2. Jun 14, 2024 at 4:38 AM
    #212
    ASUNC
    ASUNC New Member
    Ha!
    I'll get on it this morning!
    Ruggybuggy[QUOTED] likes this.
  3. Jun 14, 2024 at 1:03 PM
    #213
    ASUNC
    ASUNC New Member
    Here’s how it turned out - mid way with one new and one old and with both new, finally the view from the drivers seat.
  4. Jun 14, 2024 at 1:37 PM
    #214
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That looks decent. Where did you buy them from? If you're selling the old power fold mirrors they are worth alot more than you would expect but I would hang onto them untill you know you happy with the new ones.
  5. Jun 14, 2024 at 1:45 PM
    #215
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    If you remove the driver's side kick label there is a wire you can tap into that powers the rear cargo light. The puddle lights will come on from the switch inside or from the unlock and lock on the fob.
  6. Jun 14, 2024 at 5:53 PM
    #216
    ASUNC
    ASUNC New Member
    My old ones are not power fold - these Boost Auto ones required a wiring solution to addd the fold. I guess the non-power fold stock ones are not worth a lot !
    RainMan_PNW likes this.
  7. Jun 14, 2024 at 8:31 PM
    #217
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    The stock mirrors are not worth much. Not worth selling. Hang onto them incase you trade the truck in.
    ASUNC[QUOTED] likes this.
  8. Jun 14, 2024 at 8:58 PM
    #218
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That's what I should have done instead of taking mine to the ecostation.
    RobertD and Ruggybuggy[QUOTED] like this.
  9. Jun 17, 2024 at 7:47 AM
    #219
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    Got mine installed a couple of weeks ago. They are nice and work well. It would be nice if the would extend more perpendicular to the truck.
    The bottom convex mirror sees to much of the truck at its furthest out adjustment IMO
    ASUNC likes this.
  10. Jun 17, 2024 at 8:06 AM
    #220
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I get just the back quarter panel from about the rear tire in mine. It’s perfect to me
    RobertD and Cpl_Punishment like this.
  11. Jun 18, 2024 at 8:35 AM
    #221
    Avi8or
    Avi8or New Member
    Johann
    MO
    Im sure has a lot to do with seat position. I’m fairly tall, so the farther back one goes, the more this affect is increased. I can see the entire side of the bed, the rear doors and the front door handle. Not a show stopper, just would be a nice to have.
    Also still getting used to the larger upper mirror not being convex. The lower mirror gives a nice wide view, but is difficult to tell if the car is clear.
    My resin rear bumper caps are due today so will get to installing the BSM this weekend so will help remedy that with another data point.
  12. Jul 1, 2024 at 7:45 AM
    #222
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    little thread revive here... 4th of july sale though 7/9... code USA24 and you get 25% off site wide!
    JDR76 and WFD473 like this.
  13. Jul 13, 2024 at 7:41 AM
    #223
    carn_dogg
    Pat
    Eastern Shore MD
    Ok so I got my mirrors. They look great. I have a 2013 tundra platinum, so apparently don’t have pin 17 on my mirror harness for running lights. I ended up wiring in another pin so the front lights on the mirror act as DRL’s. Works great. Wired the back up lights to an aux switch that I already had in the truck.
    The mirror are massive. I like the look of them from the front with the DRL and sequential blinker, but I gotta say that’s about it. I towed my car trailer today with them and found the zoom on the pass side terrible (I’m sure it takes some getting used to) and the lower piece on the mirror is hard to use given the top part is zoomed in. Have to almost use the bottom one as a standard mirror and the top piece as a specific picture at the trailer or rear tail of truck. Drivers side isn’t too bad but still a little off.
    Power feature works well as I had the feature OEM. Mirror memory works fine.
    I just removed them from the truck and will leave them in the box unless I tow the camper that we are getting soon. Even then, might just leave OEM mirrors. I wanted to like the boost auto ones so badly and ended up convincing myself that I needed them and would like the look.
    the OEM ones are far superior in most ways.
    might end up selling these, as boost auto won’t accept a return since they’ve been mounted. Anyone looking for:
    07-13 tundra mirrors
    Chrome
    Power fold
    Smoked lense
    Sequential turn with running 2.0
    Start up sequence
    Defrost on top and bottom
    High power backup led
    let me know!
  14. Nov 21, 2024 at 1:46 PM
    #224
    ASUNC
    ASUNC New Member
    I have a problem with my BSM. I had a slight fender bender and just got the truck out of the shop today and I have a BSM and RCTA malfunction. The shop said they didn't mess with anything near the sensors or mirrors and I can't really dispute that.
    Any ideas on troubleshooting this problem, or should I just call Boost a call and see what they say. I know that some have had a mirror glass problem, but neither of the BSM lights in the mirrors are working so it seems it may not be my problem.
    Thx
  15. Nov 21, 2024 at 1:52 PM
    #225
    RobertD
    Robert
    DFW, Texas
    Calling Boost couldn't hurt. Have you disconnected your battery and let everything reset? Who knows what the shop did, and it could just be a simple trip. I'd start with a battery reset and see if the problem persists.
  16. Nov 21, 2024 at 1:57 PM
    #226
    ASUNC
    ASUNC New Member
    Of course I should give that a shot first!
    Thx!
    RobertD[QUOTED] likes this.
  17. Nov 21, 2024 at 2:01 PM
    #227
    RobertD
    Robert
    DFW, Texas
    Its a simple and free solution that often times either solves it or tells us its not simple :rofl:
    If that doesn't fix your problem, you are outside of my knowledge depth. But we have others who can hopefully chime in.
  18. Nov 21, 2024 at 8:31 PM
    #228
    RainMan_PNW
    Casey
    Clark County, WA
    You know that the BSM/RCTA sensors are in your rear bumper, right? If the shop was fixing your bumper, I’d be checking all the wiring in the bumper from the sensors to the harness connections near the trailer hitch. You’ll see errors like that if there’s a shorted or faulty connection between the sensors, the CANBUS system, and the instrument panel.
    ASUNC[QUOTED] and RobertD like this.
  19. Nov 22, 2024 at 2:03 AM
    #229
    ASUNC
    ASUNC New Member
    Yes, I am aware the sensors are in the bumper. I’ll try to check those connections today. Thx
  20. Jun 14, 2025 at 4:46 PM
    #230
    Austintaco
    Austintaco New Member
    Patrick
    Austin, TX
    2021 Lunar Rock TRD Pro, 2003 Tacoma DC TRD, 1984 SR5 4runner with 1uz, 85 Supra
    285/75/18 Duratraks, 5.29’s and Powertrax in the rear, Eibach Pro lift coils, JBA UCAs, RAS and CB Plus 3, AT transmission cooler, RAGO dash plate, Boost Tow mirrors
    Since this is the biggest thread on the Boost mirrors, I figured this is where to ask this question. I’m so close, but……..
    @RainMan_PNW I am bringing up this thread from the dead, but you seem to be the man when it comes to all things wiring. I’m stuck. I’m referencing this post because of your instructions on lifting tab #1. Where is it?! Neither The plug with the pigtails from my Amazon switch nor the factory plug have anything other than the tab to remove it from the male side. Am I missing something? I bought depinning tools and connectors but all of my crimps sucked so I want to cleanly remove some pigtails and connect to the boost wires and insert into blanks 9 and 10. Anyone else get stuck on one of these connectors?
  21. Jun 14, 2025 at 6:13 PM
    #231
    Austintaco
    Patrick
    Austin, TX
    I figured out the issue. The factory connector has the tab to allow depinning, the aftermarket with the pigtails does not. I had ordered a variety of terminals to do the pinning and depinning, but without a proper crimping tool, I mangled my first few attempts. Now I see why I could not get the Amazon switch pigtails out easily, no tab. That also kills my idea to use those crimped pigtails to connect to the boost retract wires. I’ll have to crimp on the proper ends.
    I just ordered a crimping tool, but does anyone know the correct terminals for the factory connector for the power mirror switch? The kit I had ordered has a package labled “F050-SMTS” does that sound right?
  22. Jun 14, 2025 at 8:43 PM
    #232
    RainMan_PNW
    Casey
    Clark County, WA
    From this post: https://www.tundras.com/threads/rainmans-2021-lunar-rock-trd-pro-build.77317/page-10#post-2163301
    Finally, connector J130 uses a 1.3 non-waterproof connector. You need two FEMALE for the power fold motor controls.
    1.3 non-waterproof Female terminal (82998-12420) - https://www.hi-1000ec.com/product/1300 ORhttps://www.corsa-technic.com/item.php?item_id=1326
  23. Jun 15, 2025 at 5:43 AM
    #233
    Austintaco
    Patrick
    Austin, TX
    Thank you for confirming. I knew you had posted up the size previously, but I couldn’t find it. Man, I’m still scratching my head as to how the Amazon connector gets their terminals in place without a release.
  24. Jun 15, 2025 at 7:04 AM
    #234
    RainMan_PNW
    Casey
    Clark County, WA
    There’s a release - just not a double lock. There’s a few different styles of releases as I’ve worked through using different connectors
    Austintaco[QUOTED] likes this.
