SEQUOIA GRILL GUARD
Discussion in '1st Gen Tundras (2000-2006)' started by BusBoss, Jun 11, 2025.
  1. Jun 11, 2025 at 9:17 PM
    BusBoss
    BusBoss [OP] New Member
    Hi! This is my first post. I am about to buy a a 2005 Tundra. Will a grill guard from a 2002 Sequoia fit?Screenshot_20250611_211150_Facebook.jpg
  2. Jun 12, 2025 at 3:13 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
  3. Jun 12, 2025 at 4:18 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Ah the good ole damage multiplier!
  4. Jun 12, 2025 at 7:54 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    Unless it's free, you might be putting the cart before the horse there guy. I'm 100% certain that 2005 is going to need things more important than a grille damage multiplier.
  5. Jun 13, 2025 at 5:04 AM
    Dakillacore
    Dakillacore Brake now, you Mickey Mouse-piece of shit!
    Georgia
    This isn't a direct answer to your question, but it is probably some useful information.
    Brush guards are used for helping moving brush out of the way and to protect against low-speed impacts. There is a wide range misconception that they are good for accidents, which is incorrect. I will list out the reasons below:
    1) During a high-speed / high-impact accident the crash energy is no longer transferred around the vehicle in the crumble zones. Instead, the crash energy is isolated to the brush guard. This is bad news for the Tundra as the brush guard mounts to the frame. If the crash energy is no longer traveling through the designed crush zones then the only place that the majority of it has to go is to the frame directly. The frame will be bent and will require replacement. This equals to the Tundra becoming a total loss through insurance and sometimes it could have been prevented by not having a brush guard.
    *Frames can only be repaired by cold-straightening. Heat is not allowed to repair frames as this causes the ultra-high strength steel to become brittle and promotes corrosion.
    2) The energy transfer bypass that occurs on your vehicle also affects the vehicle that you hit. Instead of the panels that are designed to crush to help absorb kinetic energy, you now have a steel javelin strapped to the front of the Truck. This can cause a lot more damage and injury than a normal accident.
    If you're traveling off road trails often then it may be worth your while, but if it's a pavement princess (like mine) then I would pass up on it.
    Sirfive and shifty` like this.
  6. Jun 13, 2025 at 3:18 PM
    May depend on cab type as to how it fits and/or looks. There are a number of differences between cab types. Did you care to share what cab type? I'd expect it to fit a double cab, maybe not access/regular cabs.
    And before you fuck yourself on a new purchase, have you see our buyer-warnings thread?
  7. Jun 13, 2025 at 8:57 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Yea, you’re way better off just hitting the deer.
