180 Vacuum Line 2000 Tundra
Discussion in '1st Gen Tundras (2000-2006)' started by bfunke, Aug 25, 2024.
  1. Aug 25, 2024 at 6:35 PM
    bfunke
    bfunke [OP] Tundra Curmudgeon
    The little 180 degree vacuum hose on the evap cannister of my truck turned brittle and cracked. The part is not available separately and the cannister assembly is crazy expensive. After some searching I found a solution using a section of 5/16 mandrel formed 5/16 project hose I found on Scamazon.
    Amazon.com: 5/16" Mandrel-Formed Molded Rubber Fuel Line Hose Elbow 45° 90° 135° 180°degree bend-5/16 molded hose(45 90 180 135 degree bend turn angle) : Automotive
  2. Feb 17, 2025 at 2:34 PM
    RacerX1962
    RacerX1962 New Member
    '02 Tundra Limited
    Lifted 1" , 3/4" wheel spacers
    Hi, Great- question answered.
    Seems like every diagram shows everything but that one. Smog mechanic pointed out was spitting at ends.
    I cut the cracks off and was able to slide back on for temp fix, hose clamped ends with mini nylon ties, w/ many others too
    in case they crack. This should be inspected by anyone with a 4.7. Ordering the one at Amazon noted. Thanks!
    FiatRunner likes this.
  3. Jun 12, 2025 at 3:50 AM
    Tagging this for later. Mine looks rough too.
    The Black Mamba likes this.
  4. Jun 12, 2025 at 5:14 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    As well as the 5VZ. I have replaced mine also. Exact same canister.
