Extremely Cheap! 5.29 gears. Motive gears OK?
Discussion in 'Performance and Tuning' started by Silver17, Oct 5, 2024.
  1. Jun 11, 2025 at 6:51 AM
    #721
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Truck is finally under the knife. Let’s see if these Amazon gears and eBay Powertrax are any good!
    Jego, Mdl, memario1214 and 5 others like this.
  2. Jun 11, 2025 at 8:04 AM
    #722
    Silver17
    Silver17 [OP] Used, but returned and sold as new member
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’m just waiting for you to tell me it’s not worth it and I can sell my whole gear package and buy more power parts. :D
    Actually though, I hope you enjoy them after the long wait and dealing with some clowns to finally get them installed! Maybe one day I can join the club…
    If @Mdl cant get a flat 4 second 0-60 with his than I’m not sure I’m interested. o_O
    Jego, reywcms, Mdl and 1 other person like this.
  3. Jun 11, 2025 at 8:08 AM
    #723
    bflooks
    bflooks New Member
    Metrowest MA
    4.0s or bust is the new standards we're adhering to?? :(
    Jego and Silver17[OP] like this.
  4. Jun 11, 2025 at 8:10 AM
    #724
    Silver17
    Eastern PA
    Heck yeah, everybody and their mother is doing 4.5s. Need to set a new standard.
    Jego, reywcms and bflooks[QUOTED] like this.
  5. Jun 11, 2025 at 8:18 AM
    #725
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm working on it...:thumbsup:
    The gears are holding up. They've been up to the 100's, been under stress getting sideways and pulled a few tons of gravel. Gets me to the store and back, I have no complaints with the cheap gears.
  6. Jun 11, 2025 at 9:16 AM
    #726
    ZPhilip
    Philip
    West Chester, PA
    Well the excitement was short lived. I had the Motive gears polished locally and apparently they removed too much material during the process. The pinion bearings have excessive play on the pinion shaft. The rear just slid on by hand, no press required. The front was even worse. They also said the shape of the rear gear pattern wasn’t nice.
    Looking to overnight some gear sets from ECGS now.
    So anyone want to buy some cool paperweights?
    Terndrerrr likes this.
  7. Jun 11, 2025 at 9:19 AM
    #727
    blenton
    blenton New Member
    Ouch. I may have a set of unused gears sitting on the shelf from the beginning of this thread. Happy to send them your way if you want to roll the dice on another set of not-polished-extremely-cheap-5.29-gears..
    Mdl likes this.
  8. Jun 11, 2025 at 9:19 AM
    #728
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Oh man. That sucks! Any recourse from the polisher? Zuk mentioned some motive gear patterns that were off.
  9. Jun 11, 2025 at 9:31 AM
    #729
    ZPhilip
    Philip
    West Chester, PA
    Appreciate the offer but the shop doesn’t want to use Motives now, and I need them ASAP. Truck is torn apart and I’m just gonna have them get whatever brand gears they have done successfully on other Toyotas.
    Mdl likes this.
  10. Jun 11, 2025 at 9:55 AM
    #730
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Damn that sucks
    Mdl likes this.
  11. Jun 11, 2025 at 10:17 AM
    #731
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I forgot who but Zuk mentioned company that sells gears ready to go, 2nd was revolution gears. That's too bad that happened.
  12. Jun 11, 2025 at 10:52 AM
    #732
    Silver17
    Eastern PA
    Having installed several, what say you @texoma on a slip fit for the pinion bearings after polishing? I am reading different opinions. Some do it on purpose and say the pinion nut will tighten the race down. Others say it must be press fit?
  13. Jun 11, 2025 at 11:09 AM
    #733
    bflooks
    bflooks New Member
    Metrowest MA
    Seems similar to the tolerances of the PowerTrax around the time of my install. Same parent company. Too bad there was a third party in the middle of it all since I assume that voids any potential warranty claim
    Mdl likes this.
  14. Jun 11, 2025 at 11:29 AM
    #734
    Silver17
    Eastern PA
    If the polishing place truly over polished them then they should at least refund their polishing services IMO. That costs more than the gears themselves in my case. I think paid 175ish dollars for the set of gears. Some say they’re not supposed to polish the bearing contact area.
    Mdl likes this.
  15. Jun 11, 2025 at 11:47 AM
    #735
    ZPhilip
    Philip
    West Chester, PA
    I’m sure I can bitch loud enough and get the $300 back from the polishing. I might need to since I just had to pay over $1500 for new gears, rear install kit, and overnight shipping.
    Mdl[QUOTED] and bflooks like this.
  16. Jun 11, 2025 at 12:16 PM
    #736
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I wouldn't rely on the pressure from the pinion nut. Your allowing the chance of having the inner race just spin on the shaft. I've seen different tolerances where there was higher pressure required to press on bearings.
  17. Jun 11, 2025 at 12:48 PM
    #737
    blenton
    blenton New Member
    For giggles I pulled out my motive gear pinion to mic it, then compared it to the Nitro gear set next to it. I compared the larger bearing diameter but suppose I could check the smaller bearing as well.
    Motive - 1.763”
    Nitro - 1.768”
    Maybe 5 thou is enough to loosen up a press fit, but I wouldn’t think so..?
  18. Jun 11, 2025 at 1:01 PM
    #738
    KH1414
    KH1414 New Member
    Kenny
    2019 SR5 TSS
    Alpharex tails, RC nerf steps, TRD Pro rear sway, Klearz 3rd brake smoked lense
    What’s the cost gonna be now, since you had to buy new hardware? Labor and gear total?
    Thanks
  19. Jun 11, 2025 at 1:32 PM
    #739
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    If my 20ton press doesn’t creek and make me work out to press on the bearings, then they’re too loose. You can always use some green loctite on it to be safe, but loose, no good.
    Silver17[QUOTED][OP], Mdl and ZPhilip like this.
  20. Jun 11, 2025 at 1:44 PM
    #740
    ZPhilip
    Philip
    West Chester, PA
    Too much to add up.
    Mdl likes this.
  21. Jun 11, 2025 at 1:45 PM
    #741
    Silver17
    Eastern PA
    Granted these aren’t really outside mics, just shitty Chinese calipers we are using, but my rear motive measures 1.771”
    Mdl likes this.
  22. Jun 11, 2025 at 1:45 PM
    #742
    ZPhilip
    Philip
    West Chester, PA
    I’ll be measuring and posting pictures of the “over polished” ones once I get it all back.
    Mdl likes this.
  23. Jun 11, 2025 at 1:54 PM
    #743
    Silver17
    Eastern PA
    Just measured my nitro kit Koyo bearing race diameter and it’s 1.7370 vs the pinion 1.7710.
    1.7710-1.7370 =0.034 interference. Sounds like a tight interference fit to me. Pinion is definitely larger than the bearing. By that measurement almost too large I’d think. Like I said though, using shitty calipers.
    I’ll have to check the fronts then too, not sure if I’ll have time this evening or not. Getting ready to go camping.
  24. Jun 11, 2025 at 1:58 PM
    #744
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My bearings were a bitch to press on with the 12 ton. Thought my jack was going to explode. Need bigger press!
    Silver17[QUOTED][OP] likes this.
  25. Jun 11, 2025 at 4:04 PM
    #745
    KH1414
    KH1414 New Member
    Kenny
    2019 SR5 TSS
    Damn, was afraid of that. Gonna have to figure out if I wanna spend the $
  26. Jun 12, 2025 at 3:42 PM
    #746
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Those are revolution gears, their polisher is down I think, they may have fixed it.
