Steering wheel vibration
Discussion in '1st Gen Tundras (2000-2006)' started by 406canoeguy, Jun 10, 2025.
  1. Jun 10, 2025 at 5:16 PM
    406canoeguy
    406canoeguy [OP] New Member
    2000 4.7 V8 4WD SR5
    So I have steering wheel vibration at 45-55 mph and above 65mph. Seems to stay about the same whether I’m on the throttle or when I let off.
    I’ve replaced the LBJ, and inner and outer tie rods. Truck has recently been aligned, and had a balance when I swapped winter tires over a month ago.
    PO replaced the entire driveshaft before I bought it and suggested balancing that, which I do plan on bringing by my local driveshaft-specialty shop this week. However, I’ve been seeing that is usually felt in the seat. The truck does have strut spacers and rear lift blocks which I intend to remove, just waiting on parts. PO installed them.
  2. Jun 10, 2025 at 5:26 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    How old are the shocks. Does it still vibrate on long fast corners? Left & right? What about braking? Do you feel any vibration in the brake pedal?
    shifty` likes this.
  3. Jun 10, 2025 at 5:27 PM
    406canoeguy
    2000 4.7 V8 4WD SR5
    The shocks are 10 yrs old according to his spreadsheet he gave me. Replaced front and rear in 2015, 60k miles ago. There is no noticeable change/difference when braking, nor turning. No vibration felt in the brake pedal either, just the steering wheel
  4. Jun 10, 2025 at 5:29 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Give it the wiggle test?
  5. Jun 11, 2025 at 4:18 AM
    04DC-DSM
    04DC-DSM New Member
    2004 V8 DC 4WD
    You're on the right track by resetting the suspension back to stock.
    Calipers and rotors in decent condition? Center support bearing in decent condition?
  6. Jun 11, 2025 at 6:38 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    To clarify,
    you had the same vibration with the winter tire and the summer tires?
