General Supercharger Thread
  1. Jun 9, 2025 at 3:24 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    I would look at the geometry behind the fender to inform your decision otherwise you'll end up with decorative nonfunctional vents. Even modded out like your mock up I don't think those will move as much air as some of the other things that have been suggested. The hood spacer is probably the cheapest and reverse-able.
    The thumbnails on these videos show a little bit of what I am talking about; you'll probably need to go lower on the fender.
    https://youtu.be/KwAyn6pWJiU?si=J_0fIVsefpyJK0-9
    https://youtu.be/DhvWgIbiMIY?si=hfAMytNHs7FAAkhQ
    Jego[QUOTED] and reywcms like this.
  2. Jun 9, 2025 at 3:56 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Finished up my hoses and filled with 9qts oil, details are below:
    Modified GX460 1UR 4.6 V8 oil filter bracket
    Vibrant 10AN PTFE hose - 41.5" - ~7oz capacity
    Earls 419 Oil Cooler - 0.4qt capacity
    Improved Racing Thermostatic Oil Filter Housing (160* open)
    Wix 51085 filter
    Haltech pressure sensor with remote mount line
    engine oil adapter (Vibrant 10AN hose end 90* with 8AN ORB end) out to oil filter housing (Fragola Swivel 10AN 90*) - 7.5"
    oil filter housing (Vibrant 10AN hose end 90*) out to oil cooler bottom port (Vibrant 10AN hose end 45*) - 10.5"
    oil cooler top port (10AN Male to Female Sensor adapter, Vibrant 10AN hose end90*) back to oil filter housing (Vibrant 10AN hose end 45*) - 17.5"
    oil filter housing (Fragola Swivel 10AN 90*) to engine oil adapter (Vibrant 10AN hose end90*, 10AN to 8AN ORB Sensor adapter, Vibrant 10AN hose end 90*) - 6"
    **Extended horn wiring for mounting to cooler bracket, and cut out some bits from the side of my fan shroud to make room for hoses coming through from the oil cooler
  3. Jun 9, 2025 at 3:58 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Bravo! Thanks for notating the lengths of hose!
    e30cabrio and armyoffoo like this.
  4. Jun 9, 2025 at 4:00 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Clean install!
    e30cabrio and armyoffoo[QUOTED] like this.
  5. Jun 9, 2025 at 4:25 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Those fender pics reminded me….. For those with large supercharger coolant reservoirs, dual batteries, etc, that might need a normal sized windshield washer reservoir, the Land Cruiser 200 rezi will fit behind the fender on the Tundra. Here are the old mock up photos, some small brackets to pick up the mounting points will hold it in place.
    9F689FCE-AF1F-45F0-A60A-76415A6C703F.jpg 573B27C6-FAF2-43EC-8030-229568D0804F.jpg
  6. Jun 9, 2025 at 4:26 PM
    HulkSmurf14
    2014 Tundra Limited
    Badass!! I like that better as an option
  7. Jun 9, 2025 at 4:27 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    What's the capacity on that? Might be a good option for a water/meth container...
  8. Jun 9, 2025 at 4:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Water/methanol storage...
  9. Jun 9, 2025 at 4:27 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice thinking...exactly!
    Will solve my tank issue for the larger reservoir!
    Abell207 and Jego like this.
  10. Jun 9, 2025 at 4:29 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    It’s roughly 1 gallon.
    Abell207, e30cabrio, bflooks and 3 others like this.
  11. Jun 9, 2025 at 4:33 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    It also has multiple pump mounting locations and a fluid level sensor.
    e30cabrio, Jego, Mdl and 1 other person like this.
  12. Jun 9, 2025 at 5:02 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Ok. 1.5 to 2gal would be great.
  13. Jun 9, 2025 at 5:10 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Toyota says 4.8 liters or 1.26 gallons. A custom tank for that spot could easily hit 2 gal.
    Mdl and armyoffoo like this.
  14. Jun 9, 2025 at 5:33 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Good catch. I'll keep it in mind when I get to that point.
  15. Jun 9, 2025 at 5:34 PM
    centex
    centex New Member
    Is that the passenger or driver side? I’m assuming you have to take the outer fender off to mount it in there?
  16. Jun 9, 2025 at 5:40 PM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    I was thinking the same thing. I don't know if that tank is below the intake level, but at least it's lower than the truck bed.
  17. Jun 9, 2025 at 6:15 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    What year range are we searching for?
    Thanks
    e30cabrio likes this.
  18. Jun 9, 2025 at 6:17 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Drivers side mount. Think it's called the headlamp cleaner jar. Part 85315-60350
    armyoffoo and bflooks like this.
  19. Jun 9, 2025 at 6:28 PM
    koditten
    Kirk
    Midland of the Mitten
    The fuck it is!
    To swap out starters is a six hour job...even if you have a lift.
    I just did it. The right axle has to be removed for room to drop the starter. Heat shields, tranny coolant lines are only part of the issue to remove the starter.
    On the plus side, the replacement starter is physically smaller, so install is slightly easier...slightly.
  20. Jun 9, 2025 at 6:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I just pull the passenger header/mid pipe and it comes out throught the fender wheel opening. Hardest part is getting the header back in. Replaced it 4 times since 2012. One was an aftermarket failure.
  21. Jun 9, 2025 at 7:16 PM
    koditten
    Kirk
    With Michigan salt, we never risk removing more fasteners than we need...could turn into a total engine removal quite quick.
    e30cabrio and Mdl[QUOTED] like this.
  22. Jun 9, 2025 at 7:19 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nothing like finishing grocery shopping and you go to start and click...no start. Then the dread sets in with what's involved not that you need a tow and your ice cream is melting!:mad:
  23. Jun 9, 2025 at 7:21 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
  24. Jun 9, 2025 at 7:27 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
  25. Jun 9, 2025 at 7:36 PM
    centex
    centex New Member
    Would work fine with the turbo then. Maybe one day if I run into an issue with the tank in the bed.
    Jego likes this.
  26. Jun 9, 2025 at 7:51 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    Yes, it mounts drivers side. The 85315-60350 is the bare tank, comes with little else for $117 retail. The 85355-60180 is $129 retail and comes with the level sensor, two washer pumps (front and rear), and the wire harness. It’s a MUCH better value, those washer pumps and sensor are relatively expensive when purchased individually. The filler neck is also required 85301-60060.
    @centex My recollection is that it pushes up into place w/o removing the fender. I pulled the fender to inspect for actual area available and have easy access to the mounting points.
  27. Jun 9, 2025 at 8:14 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    Yup, that's the way I do them. Not to bad at all.
    Can be done in a couple of hours or less if all goes well .
    If the exhaust fights you from corrosion, yup, it'll take quite a bit more time.. But there's very little corrosion here...
    Mdl[QUOTED] likes this.
  28. Jun 9, 2025 at 8:20 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    As always Thank you for the complete breakdown! Money saver getting the whole kit.
    Jowett[QUOTED] and HulkSmurf14 like this.
  29. Jun 9, 2025 at 8:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Update that with @Jowett post...
  30. Jun 9, 2025 at 8:23 PM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    Any secret squirrel sites/suppliers for the best price on WS? Gonna do drain and fill when I install my trans cooler and then I plan to do it again in about 6 months when I install a Valve Body. Best I've found so far is ordering 12qts from Walmart.com. If I do any other qty, the price per quart goes up, lol.
    Any way, best deal I found was 112.73 shipped to California. So that's ~9.40 per quart.
