General Supercharger Thread
  1. Jun 8, 2025 at 11:56 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    Low battery voltage causes crank sensor codes all the time. Sounds like it got a bad cell..
    It didn't hydrolock by any chance?
  2. Jun 8, 2025 at 12:05 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Does the IC resi still have the same amount of coolant in it now versus when you refilled it and tried to turn it over? If not, you may need to pull the back two plugs and either jab the borescope in there to see if one of them filled with coolant somehow, or drain the coolant and pull the cover to try to see if the o-rings allowed coolant passage into the cylinders. Maybe the o-rings didn't do the trick and allowed coolant to run past when you refilled. Just to clarify, it actually turned over briefly before stopping?
    mustang67408 likes this.
  3. Jun 8, 2025 at 12:05 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    It was driven into the driveway when I came home, I was able to start it and turn it around afterwards. The cylinder picture was after the last time it ran.
    I just tried again, did the same clicking thing, battery has 12.6v before putting 200 amps on it.
    I tried to remote start, all the accessories run (SC coolant pump etc) but nothing else happens.
    Now turning the key only lights the cluster, no click.
    The video I found for the cps was 2wd, between my skid plate and front axles I can't see the damn sensor.
    It's 112, I'm taking a break.
    mustang67408 and Mdl like this.
  4. Jun 8, 2025 at 12:07 PM
    e30cabrio
    Yes it did turn over. I'll pull #7 after cooling down.
  5. Jun 8, 2025 at 12:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Not sure if you can reach it. Make sure the starter trigger wire is fully seated. I'm able to get my hand in there after removing the starter heat shield. Just a thought as mine came loose and I had to re-insert it.
    Man...good luck!
  6. Jun 8, 2025 at 1:06 PM
    e30cabrio
    So that's an affirmative, there was 1/4 of a gallon in 8,7,5 & 3 combined. The starter no longer does anything (I suction pumped 99.9% of the fluid out) Is there a fuse or relay for the starter? Can't find one.
    I'll have to pull the skidplate to try & manually crank the motor to see if it is fucked.
    7, still working on getting that out.
    5
  7. Jun 8, 2025 at 1:09 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    F*%K! That blows, I hope the motor is still good.
  8. Jun 8, 2025 at 1:35 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Holy shit! Remember to pull the plugs when trying to turn it over to maybe help purge the coolant out. May as well do them all I would guess. I'm unlikely to be of any use in troubleshooting the starter...
    e30cabrio[QUOTED] likes this.
  9. Jun 8, 2025 at 1:44 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    @e30cabrio, I found this (for Tundras): https://imgvehicle.com/toyota/tundra-ii/fuse-box
    Locations 13 & 40
    Mdl and e30cabrio like this.
  10. Jun 8, 2025 at 1:45 PM
    e30cabrio
    I found the fuses & relay. The 7.5 under the dash was blown, none of the rest were, no function with a new 7.5. Plugs are out, starter does nothing. It's also under 6 months old :(. I'm a dumbass. Should have waited for the O-Rings :(
  11. Jun 8, 2025 at 1:50 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    e30cabrio likes this.
  12. Jun 8, 2025 at 1:52 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Did you attach the lid to intercooler then install/slide IC into the SC? It should go in as a unit. If not the IC can be set too deep and not seal. If the o-rings are same diameter and thickness there shouldn't be an issue.
    e30cabrio[QUOTED] and Wynnded like this.
  13. Jun 8, 2025 at 3:34 PM
    e30cabrio
    I did, thanks.
    The battery is behaving oddly, it is a year old quality AGM, it gets 13.9-14.3 volts when running, lives at 12.5+. Right now it has 12.3, ignition off. Ignition on, DRLs on & the SC Pump running it's at 12.
    No starter & no starter when bypassing the relay with a test probe. The odd thing is the voltage drop when trying to start it.
  14. Jun 8, 2025 at 3:36 PM
    centex
    centex New Member
    Solenoid on the starter die?
  15. Jun 8, 2025 at 3:49 PM
    e30cabrio
    If anything is dead, I killed it :( but I really hope not.
    It's still 109, I'm burnt. I'll pull the skidplate & see if I can crank the motor & go from there. If I killed the motor, I need to find the builder I found AFTER the junk yard motor was going in & see what he will charge me if I give him 2 cores on a new motor.
    Wynnded and Mdl like this.
  16. Jun 8, 2025 at 4:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Not sure if you tried yet. If the trigger wire is not engaged it will go through a start cycle but no crank. It was a difficult find out but cured my no start.
    Found this on tundrasolutions a few months ago that helped. Not sure if it's your issue.
    mustang67408 and Wynnded like this.
  17. Jun 8, 2025 at 4:24 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Can you swap the bimmer's battery in to see if that does anything?
  18. Jun 8, 2025 at 4:26 PM
    e30cabrio
    Thanks. Where is the trigger wire?
    Mdl likes this.
  19. Jun 8, 2025 at 4:34 PM
    e30cabrio
    I can but doubt it would be better than a 200 amp start plus the 900 amp AGM, even if the AGM is misbehaving.
    I'm going to wait for tomorrow to see if it's locked up.
    Mdl and Wynnded[QUOTED] like this.
  20. Jun 8, 2025 at 4:37 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Ah, missed that tidbit.
    Mdl and e30cabrio[QUOTED] like this.
  21. Jun 8, 2025 at 6:23 PM
    bflooks
    bflooks New Member
    Metrowest MA
    This is all triggering some anxiety over here. Check your oil while you're waiting. Fingers crossed for you
  22. Jun 8, 2025 at 6:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Forward on starter about 11 o'clock. It's has a little tab that sometimes unseats. If you can loosen the heat shield you can jam your hand in there and see if its seated.
    I'm hoping it is something simple and not a serious issue!
  23. Jun 8, 2025 at 6:28 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    They aren't functional. If you look at the Tundra with the fender removed there is no air flow between the engine bay and the fender space unless you cut a hole between the two.
    armyoffoo and Jego[QUOTED] like this.
  24. Jun 8, 2025 at 6:35 PM
    Saltyhero13
    Exactly, these are decorative without additional mods.
    The mold them on demand hence the "soon".
    armyoffoo[QUOTED] and Jego like this.
  25. Jun 8, 2025 at 6:51 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    You have more bad luck than anyone I've ever met o_O
  26. Jun 8, 2025 at 6:55 PM
    e30cabrio
    Oil looks ok.
  27. Jun 8, 2025 at 7:01 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Fingers and toes crossed you can turn it over by hand.
    e30cabrio and Wynnded like this.
  28. Jun 8, 2025 at 7:05 PM
    blenton
    blenton New Member
    No joke…
    @e30cabrio , you don’t like to drink things out of straws, do you..?
  29. Jun 8, 2025 at 7:24 PM
    mustang67408
    Victor
    You don't have an aftermarket alarm that's tied into the starter circuit?
    Those things do weird stuff when they loose voltage.
    If it has OEM alarm, have you tried resetting it.. unlock/lock/unlock drivers door. They do weird stuff with low voltage too.
    Praying the engine isn't locked...
  30. Jun 8, 2025 at 7:28 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Replaced the 16 oz reservoir with a 84 oz one. It's not much but gives an additional 68 oz of coolant. Just trying to keep the SC cool.
    Modded the inlet/outlet to accommodate the 3/4 barb fittings and made a bracket. Don't like having 90 deg fittings but will do until I get a different setup.
    ARES35, e30cabrio, Wynnded and 6 others like this.
