Timing belt snapped at right after startup.
Discussion in '1st Gen Tundras (2000-2006)' started by Screaminglarry, Jun 8, 2025.
  1. Jun 8, 2025 at 12:19 PM
    Screaminglarry
    Screaminglarry [OP] New Member
    Anthony
    2006 gold tundra double cab sr5
    Title says it all, I have the aisin kit to replace everything and I'm just gonna do it and hope for the best. Only had this thing 4 months and already to deep in. The question I have is how do I get the crank shaft to ATDC and the cam shafts at their appropriate places and lined up without the belt already on and not mess stuff up inside? I've watched the videos and looked for it on here and other places but nothing ever says what to do if you don't start with a belt on. The manual however says to not turn the crankshaft pulley without the belt engaged.
  2. Jun 8, 2025 at 12:53 PM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    There are a couple of ways to go about it.
    First i would get a bore scope, and check top of pistons for valve strike.
    If there is a strike id start pulling heads off.
    If no valve strikes, safest bet would be to remove cams, and go from there turning what you need as you need to just like assembling motor.
    That would be safer way I can think of.
    Dook55 and gosolo like this.
  3. Jun 8, 2025 at 1:18 PM
    Screaminglarry
    Anthony
    I appreciate the response, I haven't seen that yet anywhere and it makes sense. But I'm so far out of my depth here and have barely an idea of what that means. I can't afford to put it in the shop and I definitely cant go that far in disassembly. And out of money ATM for more tools. Should I just move it down the road or is there a way that is less safe but could work potentially way? I'm in a trailer park and they are already upset at some of the liquids I didn't manage to catch.
  4. Jun 8, 2025 at 1:19 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    and I'm sitting here dragging my feet on a timing belt change, but mine is just old and the water pump blew, so I don't have a choice. I would do what @Redoak stated. Borescope are fairly cheap on Amazon and harbor freight. I got mine on HF for $45 a year ago. Has been clutch tbh, helped me on my underground water leak and still works good.
  5. Jun 8, 2025 at 1:36 PM
    shifty` Oh, I have felt Cobain's sarcoma
    Sorry about your luck, did you know the timing belt was old/unserviced/bad?
    This site should help, I think.
    https://www.toyoheadquarters.com/threads/toyota-2uz-fe-timing-belt-marks-4-7l.335/
    Keep us posted!
    aredub, G_unit3000 and Redoak like this.
  6. Jun 8, 2025 at 1:36 PM
    Redoak
    Redoak New Member
    Dave
    none
    If they are already complaining where you live, I’d definitely go with bore scope first.
    Coworker went with a cheap belt it broke at 40-50k miles on start up, and bore scope showed it busted some his piston.
    That way you would have a better idea of whether or not putting belt kit on is going to be waste of time, and money before you get more involved in it.
    If there is any sign of anything touching piston I personally wouldn’t put belt on unless pulled heads and had them reworked.
    those Valves bend easily (saw a couple of those early double overhead cams over rapped, or belt break back in late 90’s.)
    G_unit3000 likes this.
  7. Jun 8, 2025 at 1:41 PM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    Have you pulled the two plastic covers for the can pulleys to see how far off it is?
    Are you willing/needing to gamble on destroying what might be a salvage engine? No judgement if that's the case, just don't do anything hasty.
  8. Jun 8, 2025 at 1:59 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Pull sparkplugs.
    Rotate cams and crank by hand gently until it lines up.
    Start with the crank if it comes to a stop, back up a hair and rotate the cams a bit until the crank moves into easily into position.
    Repeat with the cams, move crank back or forth as necessary to clear.
    PNW15, j_supra, BroHon and 3 others like this.
  9. Jun 8, 2025 at 2:31 PM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    After installing belt, turn engine over by hand several times listening for expensive noises
    Retired...finally likes this.
  10. Jun 8, 2025 at 5:41 PM
    Screaminglarry
    Anthony
    Well I got stuck on a compressor bolt I'm gonna round off with out some more stuff. I was just gonna throw the parts on and see what happens.Tbh I don't think it's the job for me, I need something now cause work is out of town a bit and I can't wait. I'm thinking I'll try to sell it and see if anyone bites maybe someone else can fix it. Sad day
  11. Jun 8, 2025 at 6:28 PM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    Bummer, maybe a motorcycle for backup transportation, depending on your particular situation. I've always had a MC I could commute or get to the store on, just in case.
    Corndog123 and G_unit3000 like this.
  12. Jun 8, 2025 at 7:09 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    Definitely a bummer. I hope that you can figure this out. As everyone has stated, it's certainly possible that installing a new timing belt would fix it. If you don't mind me asking, how many miles on the odometer?
    PNW15 likes this.
  13. Jun 9, 2025 at 3:28 AM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    The Black Mamba and PNW15 like this.
  14. Jun 9, 2025 at 3:37 PM
    Screaminglarry
    Anthony
    Well a friend at work who's a diesel mechanic on the side thinks we should be all good to get it back up so I'm gonna go ahead with it this weekend. Here are some pics for the crank and cam positions. The cam on the right side if looking at the engine has a small divit you can barely see on the image. It's at the bottom of the flange part of the cam. I think those are the indicators for position. IMG_20250609_172624838_AE.jpg IMG_20250609_172707599_AE.jpg IMG_20250609_172652708_AE.jpg
  15. Jun 9, 2025 at 3:42 PM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    Maybe someone with a vvti truck can comment, but this is what the non vvti cam mark looks like
  16. Jun 9, 2025 at 4:05 PM
    Screaminglarry
    Anthony
    Well that made me think and I saw a pic somewhere on here, mine is a vvti.
  17. Jun 9, 2025 at 4:22 PM
    Redoak
    Redoak New Member
    Dave
    none
  18. Jun 9, 2025 at 5:02 PM
    Screaminglarry
    Anthony
    Hmmmmm, it may not be that far out of time if I am reading the video right. But I am definitely no mechanic so....
  19. Jun 9, 2025 at 5:16 PM
    Yeah, and VVTi has had more cases of engine magically turning into a boat anchor after TB snapping than the non-VVTi. The non-VVTi are far less convoluted.
  20. Jun 9, 2025 at 5:18 PM
    Screaminglarry
    Anthony
    This has added a few lbs to my sadness cup.
  21. Jun 9, 2025 at 5:26 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    This kinda goes to show that you can't trust a visual inspection of the timing belt to determine if it needs replacement. I've seen photos/videos from people who cracked open the timing cover, and the belt is absolutely riddled with visible cracks. And they were still driving the truck. "Yeah, looks like I ought to start planning on replacing it..."
    Yours, at least in that photo, looks fine. To me. I mean except for the fact that it's broken...
  22. Jun 9, 2025 at 5:39 PM
    Redoak
    Redoak New Member
    Dave
    none
    I’d like to see other side of that belt.
    Wonder if someone put an aftermarket belt on.
    How many miles is on the truck?
    G_unit3000 and pirates712 like this.
  23. Jun 9, 2025 at 5:40 PM
    pirates712
    Rochester NY
    2000 V8 AC 4x4
    I would be shocked if that's a mitsuboshi or Toyota belt
  24. Jun 9, 2025 at 5:42 PM
    MT-Tundra
    Montana
    That would help explain it. We'd have to see more photos to know if it's full of cracks, but it looks fine in that photo.
  25. Jun 9, 2025 at 5:45 PM
    Redoak
    Redoak New Member
    Dave
    none
    Under side of my old one looks good.
    Far as I can see by records I’ve been able to find its original with 186k miles on it.
  26. Jun 9, 2025 at 5:49 PM
    Timing can look right and be 180° off.
  27. Jun 9, 2025 at 6:00 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    When i broke the drive belt on my buell it didnt have any cracks. It didnt break under full throttle or high rpm engine braking. Broke while steady cruising.
  28. Jun 9, 2025 at 6:01 PM
    Screaminglarry
    Anthony
    This is it.
  29. Jun 9, 2025 at 6:19 PM
    MT-Tundra
    Montana
    Wow. I'm no expert, I only know what I've seen here and on youtube. With OEM Toyota belts, they're often full of cracks, and still holding together. With that Gates, there's very little cracking, but a few legit rips. Crazy. +1 for OEM.
  30. Jun 9, 2025 at 6:19 PM
    chunk
    chunk New Member
    I've always thought TB's to be kind of silly, although chains with high mileage can stretch, they rarely break and don't require a major maintenance service to be performed on a time / mileage schedule. I miss my old Ford sixes with gear driven camshafts. Yeah and 3 pedals too. It is what it is I guess.
    Retired...finally, Redoak and Sirfive like this.
