General Supercharger Thread
  1. Jun 7, 2025 at 8:37 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    HulkSmurf14 likes this.
  2. Jun 7, 2025 at 8:43 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    That's what I have in the bumper, this is under the lid on the SC body.
  3. Jun 7, 2025 at 8:46 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
  4. Jun 7, 2025 at 8:57 PM
    e30cabrio
    Boo
    Mdl likes this.
  5. Jun 7, 2025 at 9:37 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @e30cabrio Only one size for the 1900 SC. You'd have to upgrade to the 2650 to get a larger SC intercooler brick. But the outside intercooler can be as big as you can fit.
    Any radiator shop should be able to fix it if it's leaking. If you can find one...
  6. Jun 7, 2025 at 9:52 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    For the price of the tank...you'd think it would be bit better. You could always tig weld a aluminum filler neck with low psi cap. Hmm. Selling it:rolleyes:
    I got that cheap .66gal tank to fit. It's not much but at leat it's better than the 16 oz tank. Holds 3x's the amount with a pressure cap. And I didn't have to monkey a bunch of crap to make it fit.
    ARES35, armyoffoo[QUOTED] and j_supra like this.
  7. Jun 8, 2025 at 7:30 AM
    e30cabrio
    Here's what I have, it seems like it is the seal between the intercooler and body. Can I use RTV until the new seal comes?
  8. Jun 8, 2025 at 7:37 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Whats this recessed area?
    armyoffoo and ARES35 like this.
  9. Jun 8, 2025 at 7:39 AM
    ARES35
    ARES35 New member for life
    Mile high
    I wouldn't see why a small bead of permatex wouldn't work but it's going to be a bitch to remove all small peices once it sets.
  10. Jun 8, 2025 at 7:44 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    BLOODBATH! J/K...you could use RTV, but I'd be concerned with using too much, and having issues with excess possibly coming off and going through the engine, and you'd likely have difficulty removing the IC in the future if needed. Can't you just drive the BMW until you receive the seal and o rings?
    mustang67408, HulkSmurf14 and ARES35 like this.
  11. Jun 8, 2025 at 7:46 AM
    e30cabrio
    The recess must be an installation flaw, no idea, I'm going to give it a light dusting of Right Stuff where the depression & leak appears to be & if my Amazon zillion O ring kit has these sizes will put them in. I paid more for shipping to get the seals from JonB than the seals (26/32) so will have them soon.
    The Bronco is still in the shop & thanks to Progressive taking 25 days to approve the work, I had to return the rental yesterday. We only have the Sequoia & BMW right now & my wife needs the Sequoia to go to her office in the morning.
  12. Jun 8, 2025 at 7:47 AM
    e30cabrio
    Yup, I can but my Wife needs the Sequoia, damn Progressive & lending our other cars to kids :(
  13. Jun 8, 2025 at 7:54 AM
    MRweeka
    MRweeka Validator
    Savvon
    Atlanta, Georgia
    2023 Tundra
    SDHQ Mounts Rough country Seats
    The Sequoia and Tundra T-Cases are of two totally different manufacture. I think the Sequoia is an Aisin and the Tundra has a Borg-Warner. That results in some electrical hurdles as well.
  14. Jun 8, 2025 at 8:04 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The 2008-2021 Aisin Sequoia T-case will fit into 2007-2013 Aisin equipped Tundras. Tundras were equipped with the Borg-Warner T-case from 2014-2021.
    Mdl, HulkSmurf14 and ARES35 like this.
  15. Jun 8, 2025 at 8:11 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    So the brick is okay and it's one of the o-rings in the top plate that are suspect? The large rectangular seal is just for air-to-air compartmentalization right? Hot air entering and cooled air entering the engine, correct? The rectangular seal, the o-rings and the brick are getting replaced to cover all the bases, am I understanding correctly?
    e30cabrio likes this.
  16. Jun 8, 2025 at 8:26 AM
    e30cabrio
    I ordered the O-ring and seal kit yesterday. Just opened it up this morning. The brick has no leaks or damage. I replaced the O-rings with temporary ones and lightly RTV'd the rectangular seal where the depression is and above 7-5-3.
    Ambient is 95, how long should I let it set before firing it up?
    HulkSmurf14 and Wynnded like this.
  17. Jun 8, 2025 at 8:27 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    What does the RTV say for cure time? I'd go by that.
  18. Jun 8, 2025 at 8:28 AM
    e30cabrio
    Rtfm? Novel approach!
    HulkSmurf14, Wynnded and armyoffoo like this.
  19. Jun 8, 2025 at 8:33 AM
    e30cabrio
    Could not find the Right Stuff, used Toyota FIPG. Says where it came from but not curing time.
  20. Jun 8, 2025 at 8:34 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    1-2 hours before starting engine, fully cured in 15-16 hours, good choice going with that!
  21. Jun 8, 2025 at 8:37 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
  22. Jun 8, 2025 at 8:38 AM
    e30cabrio
    I don't have to go anywhere today & if I do I'll take the BMW, hopefully leaving it overnight will help. Does the fact it will likely be 110+ help?
    mustang67408 and HulkSmurf14 like this.
  23. Jun 8, 2025 at 8:46 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Give it two hours and try it out so no surprises in the morning, should be fine. Don't think the temp will affect it, I'd melt in that heat though...
  24. Jun 8, 2025 at 8:47 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Maybe, but on what scale who knows.
    e30cabrio[QUOTED] likes this.
  25. Jun 8, 2025 at 8:59 AM
    e30cabrio
    Here is how it sits, have not put the coolant back, drained out almost a gallon.
    Viktor's hole is to the right of the filler, the sort of white area.
    Definitely going to be chilly again.
    armyoffoo, mustang67408 and Wynnded like this.
  26. Jun 8, 2025 at 10:04 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'd be more suspect of the inlet/outlet o-rings leaking if the IC brick is good.
    armyoffoo and e30cabrio[QUOTED] like this.
  27. Jun 8, 2025 at 10:13 AM
    e30cabrio
    I replaced them with Amazon knock offs & will replace all of it with the JonB parts when they come, hopefully Wednesday, didn't realize it did not include that big seal.
    Is it me or is the picture just a representation? the smaller O-Ring looks too small.
    HulkSmurf14 and armyoffoo like this.
  28. Jun 8, 2025 at 10:27 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Could bevthe pic? I've never replaced that IC seal. On mine it's almost like it's molded in or something as itsvjust an air seal and to hold it in place. Usually replace the inlet/outlet ic bolt and lid seal.
    armyoffoo likes this.
  29. Jun 8, 2025 at 11:04 AM
    mustang67408
    Victor
    Hot dry place in Nevada
  30. Jun 8, 2025 at 11:32 AM
    e30cabrio
    The adventure continues. Waited 2:30, put the coolant in, turned the key, it made super odd noises, stopped cranking and now acts like it has insufficient voltage (sounds like the VR is clicking) it has 12.4 volts, connected a charger with 40 & 200 amp boost, same thing. Ran the codes, it had PO335 crankshaft position sensor, it & all the sensors are under 6 months old, OEM Toyota & there has never been any starting issues. After I cleared it 335 did not come back but the same thing happened, clicks like it does not have sufficient voltage.
    I pulled the battery & have it charging at 40 amps. I'm at a loss.
