Side mirror replace mirror or assembly
Discussion in '1st Gen Tundras (2000-2006)' started by woodamsc, Jun 7, 2025.
  1. Jun 7, 2025 at 2:26 PM
    woodamsc
    woodamsc [OP] New Member
    New Hampshire
    2003 Tundra v8 4.7l 4wd sr5
    Some jabroni knocked mine off, couldn’t find the mirror on the ground. Are all the plastic doohickys in place to stick a new mirror on or do I need a whole new assembly?
  2. Jun 7, 2025 at 2:51 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Watch this a few times and see if you can tell if everything you need is still there.
    https://youtu.be/MJFMcmR5iGA?si=x-1HHNlVW78SgnvI
    Looks a little like your left-to-right adjusting pin is broken and gone.
    You can see you still have the up and down pin.
    What the mirror panel looks like.
    The mirror 'snaps' in place in the middle, and the adjustment pins go into the little 'sockets'.
    G_unit3000 likes this.
  3. Jun 7, 2025 at 2:57 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
  4. Jun 7, 2025 at 3:14 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    Based upon the condition of the internals of your side mirror and that you are in NH, my recommendation would be to just replace and get new ones. Make certain you select the defrost version and this is an opportunity to dechrome if that is your thing
    1lowlife likes this.
  5. Jun 7, 2025 at 3:22 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    motorcyclist? Did you deserve it?
    j/k i’ve read that mid 00’s dodge mirrors fit close enough to count & fold out for tow mode in case you’re looking to suck dicks or tow a trailer.
    TX-TRD1stGEN and FrenchToasty like this.
  6. Jun 7, 2025 at 3:43 PM
    The OEM glass comes with new standoffs, if I recall right? I replaced my glass after a drive by incident. Posted pics of the OEM instructions and helpful install instructions on here, two or three times. It’s a bit tedious, but fairly doable. Make sure you get the specific part number for your truck. My AC had heated mirrors, so I had to buy heated glass.
  7. Jun 7, 2025 at 3:55 PM
  8. Jun 7, 2025 at 4:38 PM
    woodamsc
    New Hampshire
    Sick, I'll take a chance on buying the glass then.
    Thanks all
    This whole thing might get me to check the heated mirror fuse. I've got the button but it doesn't light up. It's possible PO moved wires around inside so I never bothered looking into it
  9. Jun 7, 2025 at 4:57 PM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I don't see the wiring for heated mirrors.
    If you pull the door panel and check the mirror plug and you'll see what's up.
    R8 and R9 connectors, pin 2 power and pin 6 ground..
    Surely if you have the switch, you'd have heated mirrors..:confused:
    BubbaW likes this.
  10. Jun 7, 2025 at 5:48 PM
    It’s entirely possible a previous owner replaced the glass with non heater, or replaced the housing entirely. Or maybe a fuse. Dunno!
  11. Jun 7, 2025 at 5:55 PM
    woodamsc
    New Hampshire
    Yeah…I was a little confused on the lack of wiring too. My whole truck is a work of “art”
    Remember I’m the one with fog lights but the wrong turn stalk so…anything is possible :D
    Love her tho
  12. Jun 14, 2025 at 6:07 PM
    woodamsc
    New Hampshire
    Dang this forum has been busy.
    I replaced this but learned that when you order a mirror, you literally just get the mirror. No backing plate or anything, literally the reflective part and that’s it.
    Ended up replacing the whole assembly as it was just easier.
    Cheers all
    G_unit3000 and Sirfive like this.
  13. Jun 14, 2025 at 6:59 PM
    Mine came with the full backing plate. It was OEM. I got it from the dealer. Others have done the same on here, and got the full glass, backing plate, etc. but maybe it’s because mine was heated? Edit: Nope. The one shown above also came with backing plate and standoffs, and it’s clearly the full mirror. Where the hell dis you buy yours?!
    I want to say it was @des2mtn or maybe @RUSTYNUTS (pretty sure it was des) who showed how to heat the mirror glass to remove just the broken glass and slap new glass in. You can also buy more-convex (aftermarket) glass to swap in.
  14. Jul 4, 2025 at 6:30 PM
    woodamsc
    New Hampshire
    Mine was from rock auto. I can't remember exact brand, but I was confused as hell when I opened the package because it included sticky tape to stick the mirror on top of the old mirror........which I didn't have.
    It was meant to just be placed on top of cracked mirrors or engage with an existing backing plate.
    It was like $10 so I was only mad about the time wasted lol
  15. Jul 6, 2025 at 8:29 AM
    Definitely cheaper than my heated glas sub-assembly with new plastic backing, posts, lube, etc. in OEM box, passenger side back in 2020ish, without any discounts (this was before I knew about the Parts Program):
