3rd Brake light sealant
Discussion in '1st Gen Tundras (2000-2006)' started by DBombs, Dec 27, 2024.
  1. Dec 27, 2024 at 9:49 AM
    DBombs
    DBombs [OP] I Like Old Trucks
    NE Atlanta
    2006 Tundra DC SR5 V8 4x4 TRD
    Preferred sealants for the 3rd brake light?
    Want to install a new LED housing and will need to put new sealant. Seems straight forward, thought maybe others will have an opinion to offer.
    I’d prefer to not buy on Amazon, here’s one I’m looking at.
    https://www.amazon.com/gp/aw/d/B00P0WMQQ4?ref=ppx_pop_mob_b_asin_title
    Summit Racing has some more expensive ones, though I don’t love the look of them. Not sure if you can assume better quality with higher price
  2. Dec 27, 2024 at 11:46 AM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    DK has done this. I looked through his build thread but didn't see anything on it.
    khooiii likes this.
  3. Dec 27, 2024 at 12:09 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    I’m going to be doing this soon. Mine has clear coat overspray on it and looks crusty.
  4. Dec 27, 2024 at 1:36 PM
    I'd skip the LED aftermarket housing if it were me, but that's just me. Too many horror stories across multiple trucks. Maybe the quality has improved but somehow I doubt it. I'd just swap out the halogens with quality (Sylvania ZEVO) lifetime warrantied LED bulbs.
    The 3rd brake light is two pieces: Part 1 is underlying housing that holds the bulb connectors, wiring, and the foam seal that's glued to the cab. Part 2 is the clear/red lens cover. If the cover plate is gnarly on yours, you can replace with OEM, it's like $15. Verify your part, but the part number for my 2006 access cab is 81571-0C010 and the rubber seal between that and the housing is 81572-0C010. If you did want to buy the whole OEM assembly (both parts I list above), 81570-0C010. Again - verify compatibility before buying.
    Don't use sealant on the rear high mount. The OEM uses closed cell foam with a very obnoxious tar-like adhesive on both sides and is highly effective. IF you do pull the OEM assembly, it'll take some time to remove the the residual crap without damaging your paint. And you should remove it. A lot of people are using the VIPMOTOZ, which appears to be rebranded under a few different names now, but read the reviews carefully before picking. This is what you're looking for. You really only need it if (A) your current seal is breach/leaking, or (B) your new assembly doesn't come with it (OEM assembly 100% comes with a new foam gasket - I bought one because I'm 80% certain Toyota will discontinue the part soon)
    G_unit3000, ToyotaDude and abcinv like this.
  5. Dec 27, 2024 at 4:41 PM
    DBombs
    NE Atlanta
    Thank you. Great info. Will update any useful tips once complete
    G_unit3000 likes this.
  6. Dec 28, 2024 at 8:27 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I have the evil mfg housing for a pair of Baja designs s2's. I have a generic weatherstrip due to the design of my high mount.
  7. Jan 2, 2025 at 5:19 PM
    DBombs
    NE Atlanta
    Update in the event the info may help someone else.
    I have dry fit two different LED replacements. While I prefer the cosmetics on both, neither housing fits and seals as flush as the original. I can see them being a long term liability and the foam seal will be more exposed due to the imperfect fit.
    I’m going to stick with @shifty’s advice and stick with OEM housing. Don’t like the cosmetics as much but none of these LED housings fit/seal good enough.
    On the bright side, I will be getting a new foam seal behind the OEM housing. The original foam was looking its age.
    JasonC. and shifty` like this.
  8. Jan 2, 2025 at 6:32 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    I replaced the foam seal yesterday and previously replaced the 3 bulbs with LEDs in the OE third brake light . It went well but the original foam was degrading and failing as well as a gooey tarry mess. I didn't want to use any solvents that would ruin the clear coat so I just scraped most of the old foam and tar off with a plastic trim tool. I'll attach a few photos.
    My advice, be careful to detach all of the old foam before pulling out the third brake light assembly. Mine was still difficult to pull out and felt like it might break. The foam seal I got off Amazon ( one of the ones shifty highlighted above) was very sticky on both sides so you probably only get one crack at getting it to seat and seal properly. It fits well now. I noticed that the plastic housing above the white cargo light bulbs was melted. There are now two holes there due to the heat and I had to scrape black melted plastic from the metal below. Maybe this helps someone. Good luck
    rouxster70, abcinv and shifty` like this.
  9. Jan 2, 2025 at 6:37 PM
    Thanks for looping back on this, and confirming. What you're explaining is essentially identical to what I've seen/heard from others.
    FYI, the OEM halogens that will come in that fixture will ultimately lead to melting holes in the top. Since you've pulled the original, I'm pretty sure you know what I mean. I'd be sure to replace the halogens with LED bulbs. I cannot recommend Sylvania's ZEVO LED bulbs enough. Yes - they cost a lot. But they work without issues, I don't think they're polarity-limited, won't cause hyperflash, are lifetime warrantied (the ZEVO ones only) and you should only need to buy once in your lifetime.
    The LED bulbs you'll need are size 921. 168, 194 or others will technically fit, but not be very bright. It looks like Sylvania only carries the ZEVO in white now, sadly. But they do have a non-ZEVO 921 in red (part number "921R")
  10. Jan 2, 2025 at 7:04 PM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    Regarding LED replacements for the 3rd brake light assembly, I agree that Sylvania Zevo are the way to go if available. In my case, I decided to go with the Lasfit kit. I've got an extra red LED too. These are very bright and have been functioning well for the past 6 months. See screen shot.
  11. Jan 2, 2025 at 7:40 PM
    DBombs
    NE Atlanta
    Helpful info on the bulbs. I’ll follow the good advice. Wouldn’t white bulbs work for the brake light also since the lens is red?
    The foam seal from Amazon seems a bit thin compared to OEM. Still have not installed, so I could still order something different. I’m assuming it will work fine as is? Maybe my eyes just think it looks thin.
    My housing had melted spots as described due to the halogen bulbs. I did use a solvent to help remove the sticky material. I tried to be precise so in theory the only effected area will be covered by the housing. Getting the housing clean and prepped for reinstall is also a bit of a chore
  12. Jan 2, 2025 at 7:42 PM
    Well, OEM bulbs were white, so I assume "yes" is the answer.
  13. Jan 3, 2025 at 3:13 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
  14. Jan 3, 2025 at 6:29 AM
    And this is why "ASSUME makes an ASS out of U and ME" :rofl:
  15. Jan 4, 2025 at 10:38 AM
    DBombs
    NE Atlanta
    The 921 bulbs are a simple swap and plug in with no resistors or other adapters needed? The reason I ask is because it’s the same bulb as the back up lights and certainly a higher output than interior lights. Thank you again for all the input
  16. Jan 4, 2025 at 10:48 AM
    I don't think you'll find an issue. I can't say: I have LEDs in my 3rd brake/cargo light, but halogens on all four corners. I have LED mini projectors in the headlight housings, and a single LED in the "teardrop" (park light) position. But I didn't do any of those LEDs before installing the Diode Dynamics SmartTap, which will kill any risk of hyperflash. They also have a non-smart version that's about 80% cheaper last I checked. It's well-worth investing in. Just avoid scAmazon/fleaBay for purchase, they have problems with couterfeiters, their part design was stolen long ago, and the knockoffs don't have any worthwhile QC/QA on them so it's a risky purchase to save a few bucks. Other members have gotten burned on the non-smart knockoff part you'll find all over scAmazon, part died within a year or two or didn't function straight outta the box.
  17. Jan 4, 2025 at 11:15 AM
    DBombs
    NE Atlanta
    Ok thank you
  18. Jun 2, 2025 at 11:05 AM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    5 months later, and all 3 of these Lasfit LEDs have failed. Flush $20. Now going with the Sylvania zevo LEDs
    DBombs[OP], shifty` and FrenchToasty like this.
  19. Jun 7, 2025 at 10:47 AM
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    Went with 2 sets of white Sylvania zevo LEDs because the red ones are almost unobtainium. The extra 4th LED is now a replacement for any of them. $16 per pair on eBay vs $25 at Advance Auto/Amazon.
    The Black Mamba likes this.
  20. Jun 7, 2025 at 1:55 PM
    Hopefully they’re authentic. Man, I hate buying on fleaBay. I think I got mine from Advance Auto with an online coupon. ScAmazon usually has em too.
