General Supercharger Thread
  1. Jun 6, 2025 at 1:31 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    HulkSmurf14 and koditten like this.
  2. Jun 6, 2025 at 3:46 PM
    centex
    centex New Member
    Just dropped mine at UPS. Hopefully it helps get you yours soon!
    bflooks[QUOTED] likes this.
  3. Jun 6, 2025 at 4:00 PM
    blenton
    blenton New Member
    My thermal blanket is sitting unused on the shelf, no ETA on my SC rebuild from Whipple. I'd be happy to send the blanket your way if you are itching to get going on it.
  4. Jun 6, 2025 at 4:50 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I should be good. It is supposed to be here on the 13th. I still have to pull it and press on the new snout bearings.
    I appreciate the offer though. Enjoy the weekend.
    blenton[QUOTED] and HulkSmurf14 like this.
  5. Jun 6, 2025 at 6:31 PM
    sctomfar
    sctomfar Chasing 700RWHP
    Tom
    Bluffton, SC
    Supercharged Reg cab
    Harrop 2650 supercharger TRD suspension TRD intake Custom exhaust Dirtydeeds cross pipe Fully built bottom end motor Manly Rods Crowder Pistons ARB Stud Kit National Speed Tuned Redesigned fuel system XAT Fuel Rails Twin Demon Fuel Pumps 83cc Injectors Morimoto Headlights
    I might have missed in this thread… I’m needing to upgrade my ecm. No one I’ve seen or found has something compatible. XAT is telling me about an add on deal… I forget exact name. I’m setting mine up for more street fun and can’t get over 132mph and need to be able to control Trac system for better hook up. Ideas ?
  6. Jun 6, 2025 at 6:36 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Motec
  7. Jun 6, 2025 at 6:36 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Do you already have a built engine? Are you requiring a stand alone tuning option? The oem ecm can be tuned and optimized past your goals. HP Tuners, VF Tuning, etc can muster out some power with the right builds. Sounds like you need a LSD like a Powertrax...better than that, you should consider the Sequoia transfercase AWD swap...bolts right in and traction becomes just a word with the right tires...share more of what you have and you'll get more help...
    M3Tundra-JK, Mdl and blenton like this.
  8. Jun 6, 2025 at 6:37 PM
    HulkSmurf14
    2014 Tundra Limited
    Only $10-$15k but you're in control, than!
    Mdl and reywcms[QUOTED] like this.
  9. Jun 6, 2025 at 6:59 PM
    centex
    centex New Member
    I need more details on this build. 132mph is no easy feat.
  10. Jun 6, 2025 at 7:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I've seen a. stock tundra hit 150mph on long open roads in TX. I believe it was before hpt and removing the abs module or something like that. Mph recorded based on gps.
    I searched tundratalk but couldn't find the video, 2013-2014.
    Silver17, reywcms and HulkSmurf14 like this.
  11. Jun 6, 2025 at 8:25 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Can't be that hard, I've had mine over 120 with the 5.29s too as I recall and it was still accelerating. I'm more curious about why it stops at 132 if the governor is disabled?
    Silver17, Mdl, reywcms and 4 others like this.
  12. Jun 6, 2025 at 10:06 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Right.. I’ve had mine over 120 in the dirt
  13. Jun 6, 2025 at 10:19 PM
    blenton
    blenton New Member
    Oh yea? Well I've had mine triple digit speeds with my enclosed trailer in tow.. :boink:
  14. Jun 7, 2025 at 2:58 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    115 up a 7% grade. By accident actually.
    HulkSmurf14 and carn_dogg like this.
  15. Jun 7, 2025 at 7:25 AM
    Backroadgee
    Backroadgee Well Known Member
    west
    Missouri
    SDHQ BAJA ADD PRO SKID PLATES
    I'm getting the Stage 1 Harrop installed next week.
  16. Jun 7, 2025 at 8:34 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Not trying to open a can of worms...might want to consider a Deatschwerks DW300 fuel pump(forgot it cones with it) and used TRD 535cc injectors to start off right. It's just to keep it in a safe zone.
    blenton, Silver17 and HulkSmurf14 like this.
  17. Jun 7, 2025 at 8:37 AM
    Silver17
    Eastern PA
    The kit comes with that pump actually. Agreed, should just do the bigger injectors and a tune right away.
    Mdl[QUOTED] likes this.
  18. Jun 7, 2025 at 8:41 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Forgot about that...up too late.:oops:
    Silver17[QUOTED] likes this.
  19. Jun 7, 2025 at 8:55 AM
    blenton
    blenton New Member
    I STILL think it doesn’t come with a pump even though I’ve been corrected several times. My brain just won’t fix that little factoid…
  20. Jun 7, 2025 at 8:58 AM
    Jego
    Jego New Member
    Orlando
    PR
    2018 Tundra 1794
    Mdl and mustang67408 like this.
  21. Jun 7, 2025 at 9:17 AM
    sctomfar
    Tom
    Bluffton, SC
    its a fully built motor and transmission. running a harrop 2650. headers exhaust intake etc... tuned on pump gas at 650 rwhp from national speed. right now im doing the suspension its scary with that speed.
  22. Jun 7, 2025 at 10:16 AM
    Silver17
    Eastern PA
    Looks like the old turbokits truck wound up pretty close to me and is for sale.
    Jego, M3Tundra-JK and Mdl like this.
  23. Jun 7, 2025 at 10:21 AM
    blenton
    blenton New Member
    Dangit! That’s tempting. My boys would love a truck but I told them they had to fix one up…
    Silver17[QUOTED] and Mdl like this.
  24. Jun 7, 2025 at 10:39 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I believe venting just after the radiator by the front of the hood will extract a lot of heat. It's a low pressure spot.
    @reywcms was thinking of brake vents for cooling. Not sure if he still plans on it.
  25. Jun 7, 2025 at 10:42 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Do it
  26. Jun 7, 2025 at 11:05 AM
    Silver17
    Eastern PA
    You do it! 7500 could go toward the built engine fund.
    Mdl likes this.
  27. Jun 7, 2025 at 11:15 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Doesn't look like they are available yet, it says "available soon". Looking at the instructions, they don't mention cutting the inner fender between the engine bay and the outer fender, so it won't do much if anything.
    Saltyhero13 and Mdl like this.
  28. Jun 7, 2025 at 11:20 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    That's the sweet spot for sure
    Jego and Mdl[QUOTED] like this.
  29. Jun 7, 2025 at 11:27 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I got some vents for there just gotta find the time to cut it up...
  30. Jun 7, 2025 at 11:30 AM
    M3Tundra-JK
    Scott
    2005 GX470
    I've had one of those for my E46 M3 sitting in a drawer for years lol
