General Supercharger Thread
  1. Jun 5, 2025 at 5:17 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Looks like it puked up some unnecessary wiring. :D
  2. Jun 5, 2025 at 5:24 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Hopefully I finish Reys before his dad gets his back is my goal :rofl:
    All of that was from JUST the engine harness of this FJ40 buggy I've been working on
    And now simplified to just one little look with maybe two dozen wires that are all 18" long or so
    I've been keeping that bundle of shit just in case I need to fish back through it and find some weird connection, but at this point I'm about ready to throw it all out. Not like there's anything I'd want to reuse from all that gunk. And the inside of the FJ I pulled out probably two or three times as much wiring. Literally hot leads just flying open in the glovebox, wires hand twisted together and duct taped, it just goes on with nasty shit. I'm rewiring the entire vehicle from scratch, and that's just the beginning of the upgrades on it. Could be a whole build thread in itself hahaha
  3. Jun 5, 2025 at 5:25 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    Sorry if this has been covered before. 800+ pages, I'm still searching...
    Before I S/C'd the Tundra, I was running an auxillary fan on the condenser like a Sequoia. It really worked well, you could tell the difference in AC temp when I turned on the fan..
    Now that the intercooler is there, will adding a fan or 2 help the S/C or even the AC?
    The AC is not a cold as it used to be and the system is properly filled and working.
    2- 8" fans (Spahl or Perma-cool) will fit perfectly on the intercooler..
  4. Jun 5, 2025 at 6:52 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    2 pusher fans couldn't hurt. Just make sure, as I think you do, you got a decent relay.
    I burned up an 80amp on my e-fan. Switched to an old Pac 80 amp relay/isolator I had for a stereo. Been working fine.
  5. Jun 5, 2025 at 6:54 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Simplified wiring=perfect.
    Did you send @reywcms that pic? Hey I took care of some extra wiring that wasn't needed.:rolleyes:
  6. Jun 5, 2025 at 7:00 PM
    mustang67408
    Victor
    Like this one? :rofl::rofl::rofl:
    Seriously tho, you are correct I will get a really good relay..
  7. Jun 5, 2025 at 7:03 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That's an oldie but goody and a beefy one.
    mustang67408[QUOTED] likes this.
  8. Jun 5, 2025 at 10:29 PM
    blenton
    blenton New Member
    Been curious about doing this as well. Do you have it on a manual switch, or thermostat? I was musing over programming something like a TR7 or something even simpler to make a timer that activates when I tap a momentary button in the cab, runs the fan for 5 mins or whatever, then turns it off so I don't forget to turn it off.
  9. Jun 5, 2025 at 10:34 PM
    blenton
    blenton New Member
    Perusing their site, they also list an HD kit for the AB60E; the only note attached says it doesn't include a gasket. I'm curious what the difference would be. I also looked at their distributor list and see that my local transmission parts place is on their list. Might have to give them a call tomorrow just out of curiosity.
  10. Jun 6, 2025 at 4:53 AM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    The old kits had the pan gasket included. Pricing on the kit is all over the place from a low of $47, to well over $100, so shop around. IMO, either price is a bit high for the components received, but I suppose it’s also for the knowledge and instructions on how to modify the valve body.
    Silver17, blenton, Mdl and 2 others like this.
  11. Jun 6, 2025 at 5:47 AM
    mustang67408
    Victor
    I had the last one on a manual switch, and its still wired in. I just removed the fan when I added the SC and intercooler this time. It's basically already pre wired, I just need to get and mount the fans, and update the relay...
    Mdl and HulkSmurf14 like this.
  12. Jun 6, 2025 at 9:48 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    The mock up injector fits like stock, actually the plug is lower and clears better than stock. The plug is different from the stock denso injectors, so cutting and re-pinning of the injector sub-harness will be required, but no big deal there.
  13. Jun 6, 2025 at 9:52 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Oh snap
  14. Jun 6, 2025 at 9:56 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Where's the link to these even though I did do a search on the google from other vendors
    HulkSmurf14 likes this.
  15. Jun 6, 2025 at 9:59 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I don't have a link, I'll ask if there is one, but I think you can order based on the part number in my screenshot. Or, I would think you can email support@injectordynamics.com and request a sales order for ID1050x-48-11. I'll post up the sales order details...I should receive it today.
    e30cabrio, Wynnded, Mdl and 1 other person like this.
  16. Jun 6, 2025 at 10:12 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Mdl likes this.
  17. Jun 6, 2025 at 10:23 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Is there any difference between the 2nd gen and 2.5 gen as far as the fuel rails/spacers are concerned? I didn't think there was, but wanted to verify before I tell them the year range so they can update their website.
  18. Jun 6, 2025 at 10:25 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I don't believe so. Rey and I both use five O 750's, 2nd and 2.5gen. I also have 2.5gen spare fuel rails.
  19. Jun 6, 2025 at 10:47 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I'm also ordering new injector harnesses from Toyota, so I can revert easily if needed...I don't expect to, but you never know.
    M3Tundra-JK, bflooks and Mdl like this.
  20. Jun 6, 2025 at 10:52 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    My FI interchiller thernal blanket made it to Tacoma but for some sorting reason is in NJ! Way to go UPS. Glad I didn't pull the SC last week I'd be waiting...
  21. Jun 6, 2025 at 10:55 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    From Texas to Washington by way of NJ? That's some efficient shipping right there!
    e30cabrio and Mdl[QUOTED] like this.
  22. Jun 6, 2025 at 11:01 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Been doing some research on machine shops etc. Found out a company in phx works on the 3urfe and can accommodate. Quoted $10.5k with shipping included full forged internals, new crank etc with a 90 day warranty. Said no problem holding 950-1000hp. Turn around time would be 5-6 weeks. I'll most likely pull the trigger on this Q1 or maybe Q4 this year we'll see.
  23. Jun 6, 2025 at 11:14 AM
    bflooks
    bflooks New Member
    Metrowest MA
    $10.5k for the short block or long block? The pricing over the last 6 months and it could be either. Can you define forged internals? Name brands like the rest of us know or is this all in-house?
    Regardless, Subscribed. If those timelines prove real, your Q1 (or maybe Q4 this year) is likely to be faster than my still pending Q2 purchase. :annoyed:
  24. Jun 6, 2025 at 11:17 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Long block: But I may upgrade some items in the heads so I'm sure this would change pricing but gives you an idea
    Shipping your engine in
    Forged Manley Piston/Ring kit
    Forged Eagle/Manley H-Beam Rods
    Brand New OEM Crankshaft
    In House Crank Balancing
    King Performance Rod/Main Bearings
    Complete Engine Block overhaul
    ARP Head Stud Kit
    Brand New OEM Valve Train (lifters/rockers/Cams)
    Brand New OEM Timing Components
    Brand New OEM Timing Cover
    Brand New OEM Rear Main Seal
    Brand New OEM Gasket Kit
    Return Shipping to You.
    Silver17, Mdl, HulkSmurf14 and 4 others like this.
  25. Jun 6, 2025 at 11:25 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    XAT has an ARP main stud kit, valve springs, and billet main caps...while you're in there. Might as well, since they'll be touching all that anyways it shouldn't add anything to the labor costs.
    Silver17, Mdl, HulkSmurf14 and 2 others like this.
  26. Jun 6, 2025 at 11:33 AM
    bflooks
    bflooks New Member
    Metrowest MA
    that's a robust list of new parts for the price point! XAT oil pump might be another option to consider along with those ARPs.
    HulkSmurf14, armyoffoo and reywcms like this.
  27. Jun 6, 2025 at 11:35 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Exactly my thoughts
  28. Jun 6, 2025 at 12:16 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Finally received the Supra shifter for my 8HP90 project, this is the last item I needed besides a driveshaft which I will need the trans installed to get the dimensions to get made. Now I need to get off my ass and get the Haltech installed, so I'll be ready to install the CANTCU and finally install the trans...wish it wasn't so damn hot outside...
    ZPhilip, e30cabrio, Silver17 and 7 others like this.
  29. Jun 6, 2025 at 12:37 PM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    blenton and reywcms[QUOTED] like this.
  30. Jun 6, 2025 at 12:44 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    With only reading the list of parts, they emit a "gold" visualization in my mind...no kitchen counter needed, this time!
