  1. Jun 5, 2025 at 5:55 AM
    mach1man001
    mach1man001 New Member
    Rob
    2024 Limited Crewmax
    Bulletpoint is on Am*zon. I think most stuff ships free if you order it there. I ordered my adapter ball for my existing charger from them on there
    HomieDontPlayDat likes this.
  2. Jun 5, 2025 at 8:59 AM
    HomieDontPlayDat
    HomieDontPlayDat New Member
    Wednesday
    Vinny
    Southwest
    2025 Tundra TRD
    Man, thats clean! Nice setup!
  3. Jun 5, 2025 at 9:33 AM
    Noobo Baggins
    Noobo Baggins New Member
    Glenn
    2025 Platinum Lunar Rock
    OE 3" Lift, 35" BFG KO2
    Pretty sure the exact opposite is true.
    Typically Toyota uses a separate signal for directional and brake at the taillight.
    And all trailer wiring uses a "flashing brake signal" ... which will make your 3rd brake light blink.
    Tap into the tail light brake feed. Also, use an inline 5A fuse after where you tap to protect the truck circuitry should their ever be a short in the cap (shell) wiring.
  4. Jun 5, 2025 at 10:05 AM
    trustyfarms
    trustyfarms New Member
    Which mount did you purchase from Bulletpoint to attach the dash cam to the connector arm?
  5. Jun 5, 2025 at 12:23 PM
    Jigenax
    Jigenax New Member
    Ken
    Idaho
    2022 Blueprint Tundra DC TRD Sport
    I bought their "Quick-Adjust Bar Clamp Mount with 20mm Connector End Nubby" to attach to their "AMPS Compatible 20mm Ball Metal Mounting Plate".
    trustyfarms[QUOTED] likes this.
  6. Jun 5, 2025 at 12:29 PM
    Jigenax
    Jigenax New Member
    Ken
    Idaho
    Bulletproof offers free shipping for US orders that are $75 or more. They also offer discounts for new accounts (10%) and for military vets (15%) but you can only use one discount per transaction.
    mach1man001[QUOTED] likes this.
  7. Jun 5, 2025 at 2:34 PM
    bowhuntercoop
    bowhuntercoop New Member
    2025 limited off road
    Rear wheel well liners installed. Fitcamx
    Dash cam arrived for the front and rear. Might get a chance after the kiddos go to bed to install.
    so stupid new trucks don’t come with rear wheel well liners these days…
  8. Jun 5, 2025 at 4:20 PM
    MagneticPro
    MagneticPro New Member
    Alabama
    2005 SR5, 2025 Platinum
    I got mine delivered today. Putting them on this weekend.
  9. Jun 5, 2025 at 4:21 PM
    bowhuntercoop
    Literally takes like 2 mins per side, super simple install.ya need a 10 mm and plastic rivet pop tool or a flat head.
    Mr Rick and MagneticPro[QUOTED] like this.
  10. Jun 5, 2025 at 4:27 PM
    HomieDontPlayDat
    Wednesday
    Vinny
    Southwest
    2025 Tundra TRD
    IMG_0047.jpg IMG_0048.jpg IMG_0045.jpg IMG_0028.jpg Upgraded my JBL sound system to add more punch. Bought this Beatsonic enhancing plug and play amplifier. Install was about an hour and upgraded the sound tremendously. The stock JBL on the limited was good it lacked the mid tone and treble for that surround sound feel. It’s a small unit and hides internally behind the head unit. There’s tons of videos on install.
    Narco, MAC25Tundra, Hollows1 and 8 others like this.
  11. Jun 5, 2025 at 4:31 PM
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    For future reference, you can install or uninstall it without taking out the radio. Just pop up the tray above it.
  12. Jun 5, 2025 at 4:34 PM
    HomieDontPlayDat
    Wednesday
    Vinny
    Southwest
    2025 Tundra TRD
    Yes. You are right! The space was tight and I was sweating my balls off since I’m in Nevada so I decided to take off the whole unit to make it easier. Lol!
    ziznack[QUOTED] likes this.
  13. Jun 5, 2025 at 4:37 PM
    HomieDontPlayDat
    Wednesday
    Vinny
    Southwest
    2025 Tundra TRD
    Does the camera hook up to the 12v lighter on the dash or did you wire to a usb?
  14. Jun 5, 2025 at 4:56 PM
    mach1man001
    Rob
    That was @Paul499 not me. I was just quoting him.
  15. Jun 5, 2025 at 6:09 PM
    Paul499
    Paul499 Large Member
    Paul
    Sarasota, FL
    2024 Platinum Hybrid
    Weld 20x9, Toyo 285/60, RC N3 level, ceramic tint
    I have it plugged into the lighter.
  16. Jun 5, 2025 at 7:03 PM
    TundBP
    TundBP New Member
    23 Blueprint Platinum
    Great to hear! I ended up with bulletpoint's 2mm extension tube for the dashcam mount. I also went with the 4k front with 2K rear Miofive using a 2 inch drop mount from the headliner to avoid the roll down window.
    spliffgates and HomieDontPlayDat like this.
  17. Jun 5, 2025 at 7:52 PM
    bowhuntercoop
    rear liners done and dash cam installed, took longer to hide the cords then to install it.
    So clean and flush looks oem. Decided to mount the back camera lower. Perfect spot on the middle seat belt bracket. Rear window still goes up and down.
    hard to see from the outside since the windshield is tinted but it fits perfect, can’t even tell it’s there.
    got the drill free licence plate holder coming for the front and ordered some cup grippers that are recommended on here. Only thing I got left that I want to do is meso interior lights when they come back in stock. Freaking loving this truck. Ceramic is all cured so hope to get some outside pics this weekend.
    AF555, Raven67, spliffgates and 2 others like this.
  18. Jun 6, 2025 at 4:59 AM
    AF555
    AF555 New Member
    Michael
    2025 Tundra 1794 - Smoked Mesquite
    Did you use anything special to mount the rear camera on the seat belt bracket? I will be installing the same camera sometime this next week. Thanks!
  19. Jun 6, 2025 at 5:03 AM
    bowhuntercoop
    Nope just the supplied 3m. If it doesn’t stick with the extreme heat down here I will glue a magnet to the camera base then slide one under that rear plastic.
    I had to use magnets on the wife’s gx550 since it’s mounted up high with the way the windows and trunk is. The 3m wouldn’t stick to the curved plastic. 2 magnets later it hasn’t moved in 2 months of me installing it.
    you should be fine though. One piece of advice, start at the front and run the cables back, wayyyy more room to hide the spare wire behind the back seat plastic compared to the reviews and head liner.
    AF555[QUOTED] and ScottieBones like this.
  20. Jun 6, 2025 at 5:40 AM
    AF555
    AF555 New Member
    Michael
    Perfect. Thank you. I installed the FITCAMX in my daughter’s RAV4 XSE a couple months back, so somewhat familiar with the overall install. Many thanks!
    bowhuntercoop and 75tranzam like this.
  21. Jun 6, 2025 at 5:49 AM
    75tranzam
    75tranzam New Member
    Midlothian, Va
    2024 Midnight Black 1794 Limited Edition #751
    You guys have convinced me to take a look at the FitcamX as my new camera.
  22. Jun 6, 2025 at 5:53 AM
    bowhuntercoop
    They are expensive, made over seas of course, but the quality is top notch. App isn’t glitchy and the install is seamless. No using a 12 cig lighter or anything. All the wires are hidden and it’s oem flush install. I’ve switched all our vehicles to them. Highly recommend them.
    75tranzam[QUOTED] likes this.
  23. Jun 6, 2025 at 6:02 AM
    g4waldo
    g4waldo Professional Looking CSM Owner
    2023 Celestial Silver Metallic Tundra Platinum 4x4
    If you go the Fitcamx route, consider the "Sienna" cable for always-available power.
  24. Jun 6, 2025 at 10:32 AM
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    I ripped out the headliner. Going for a full black interior swap and sound deadening the roof while I’m in there.
    Have all the pieces ready to go, just waiting on temps to go down a bit today. Sourced the black parts from a mix of local dealer parts store and eBay for ~700. Material was ~50 bucks for oem-ish pattern. I didn’t want suede cause I don’t want to change the pattern too much so hope it comes out ok lol
    Crowmag, Yaboy, Mr Rick and 9 others like this.
  25. Jun 6, 2025 at 10:49 AM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    I’ve been thinking about doing this some day. Can’t wait see the results!
