  1. Jun 3, 2025 at 5:18 PM
    shifty` Rappenin' is what's happenin'
    From Tundras.com's sister site TacomaWorld, so it involved tacoma:
    I am an ARE dealer, this is indeed called a Contour Strip. I replace a lot of these since they like to crack at the rivets. ARE part numbers:
    PA-15856
    05 Tacoma Contour Strip w/rivets (for CX/MX Series)
    PA-15223 05 Tacoma Contour Strip w/rivets (for V/TW Series)​
    PA-19105 05 Tacoma Contour Strip w/rivets (for CX/MX Series - Used after 5/1/2010)
    PA-19104 05 Tacoma Contour Strip w/rivets (for V/TW Series - Used after 5/1/2010)​
    PA-22717 2016 Tacoma Contour Strip w/rivets (for CX/MX Series)
    PA-22715-001 2016 Tacoma Contour Strip w/rivets (for V Series)
    PA-22715-002 2016 Tacoma Contour Strip w/rivets (for TW Series)
    Someone else recommended going to https://www.4are.com/ and looking for the dealer nearest to you.
    You'll want to pull your serial number off the plate inside the cap to get the serial number. You may also be able to figure out which variation it is (CX or MX or V or TW)
  2. Jun 3, 2025 at 6:05 PM
    Ok, F that horrible recycle box. Box 2.0 coming
    Voss, Dakillacore, oscardog86 and 5 others like this.
  3. Jun 3, 2025 at 6:28 PM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Nice, yeah I think I came across this post in my search as well. I did go to an ARE dealer a while back to see what they could get done or order for me, they basically gave me the "oh your serial # is too old because it starts with a F and we won't be able to look up parts for it". I'm fine taking my chances on one of those contour strips that may not technically be specific for my model as long is fits for the most part, I may even email ARE directly with that pic and a pic of my serial # plate to see if they can at least tell me what series the cap is.
    shifty`[QUOTED] likes this.
  4. Jun 3, 2025 at 6:42 PM
    455h0le_dachshund
    455h0le_dachshund Human tongue feels aluminum plate
    Rev. Hotdog
    TX...big surprise
    Didn't you tap and zerk your Solos yourself?
    That's something I'd like to someday do for my solos and spcs, when it's time to regrease the bushings. Pop em out and drill some holes in the bushings to allow the grease to flow when being pumped in.
  5. Jun 3, 2025 at 6:51 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I normally jack the truck up, loosen the bolt, grease, hand tight, lower truck back on its own weight, retighten. Zerk or no zerk I've always gotten the best results this way.
  6. Jun 3, 2025 at 6:55 PM
    Box 2.0 is rising from the ashes, er maybe sawdust…
  7. Jun 3, 2025 at 7:26 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Today.....towed the long trailer (7'x18') and did three yards.
    Coming up a steep hill and just after passing under a bridge where the road narrows to one lane (naturally you cannot see what's coming as there is a knoll) BOOM here is a BIGGER truck pulling a BIGGER trailer! Had either of us been three seconds faster we would have had a head-on collision!
    I put the brake pedal to the floor, yelled some words I won't type out, but the guy must have been going kinda slow and he must have gotten way over to his right...at least a foot or two between the trailers as we passed each other. Guess my heart is in pretty good shape as I am sure I spiked the heart rate!
    Made a comment about "needing to change my undies" which the immigrant wife had no clue "why would you need to do that?" SMH LOL
    *Maybe a good thing I let the stealership replace the calipers, rotors, and drums....
    Also, as soon as we get some bills paid off, putting that brake controller thingie on there.....
  8. Jun 3, 2025 at 8:49 PM
    Fuck. That. Back. Seat.
  9. Jun 4, 2025 at 5:16 AM
    The Black Mamba
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    K. I. D. S.
    So there is a guy in the suspension subforum bitching about a creaking noise from his SPC uppers. Turns out he's don't have zerks, but it reminded me about the conversation we had last year.
    SPC UCA Groan/Creaking | Toyota Tundra Forum
  10. Jun 4, 2025 at 7:07 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Gotta lube the UBJs every other oil change.
    Bushings every like 30k miles
  11. Jun 4, 2025 at 7:11 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Seriously? Is there a oil plug there?
  12. Jun 4, 2025 at 7:12 AM
    Not for OEM
    des2mtn likes this.
  13. Jun 4, 2025 at 7:14 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Specific to the SPC adjustable uppers control arms.
    There's a grease zerk on the upper ball joints. Just not on for the bushings, like JBA UCAs
  14. Jun 4, 2025 at 7:38 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Oh geeze, add that to the list! I'll give mine a looking over and try to get on that. I have a grease gun, use it on my mowers and trailer hubs.
    Thanks.
    Can you hit me with a pic of these grease plugs on your truck?
  15. Jun 4, 2025 at 7:44 AM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
  16. Jun 4, 2025 at 7:46 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Wow, there it is!
    Have to mow today, will have a look under the fender well when I go out here in a bit.
  17. Jun 4, 2025 at 7:59 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    Highly unlikely your truck has those grease zerks. That picture and what they're talking about is on an aftermarket part. The OEM equivalent part does not have grease zerks.
  18. Jun 4, 2025 at 8:02 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    Oh thank God and God bless you sir! I have enough grease plugs to grease as it is.
    Voss and des2mtn[QUOTED] like this.
  19. Jun 4, 2025 at 8:32 AM
    The Black Mamba
    DFW
    Imma keep it stock
    I wondered about that but then I thought that he might know something about his truck that we don't. After seeing some things on here, I don't assume anyone is running OEM anything anymore.
  20. Jun 4, 2025 at 9:30 AM
    Bought2Pull
    Greg
    WV
    2006 Tundra 4 door
    I OEM all the things!
    I didn't do it but a previous owner (DMV says I'm owner #7!) put on some aftemarket shocks and the touchscreen radio (crappy) and backup camera (crappy) are not OEM. :(
  21. Jun 4, 2025 at 9:40 AM
    Dakillacore
    Georgia
    Hell, the back up camera sounds like an upgrade to me.
    The audio system is my next upgrade on the "Tundra to do list"
  22. Jun 4, 2025 at 9:50 AM
    The Black Mamba
    DFW
    Imma keep it stock
    A back up camera is nice to have, but I still do the turn and look backwards method. I like the camera for getting close to things I can't see.
    bmf4069, BroHon, oscardog86 and 4 others like this.
  23. Jun 4, 2025 at 10:33 AM
    Kalannar97
    Kalannar97 New Member
    Michael
    Hillsboro, TN
    2003 Red Tundra SR5 2wd AC V-8 LSD ABS
    New Frame (Recall in 2019), added 17" 4-Runner Snowflake Rims
    I almost learned the hard way with my CR-V camera that objects on the screen are much closer than they appear. Camera makes it look like you are a foot away when in actuality you are about an inch away. Plus, there is no beeping tone as you approach an object. It only beeps for cross-traffic warnings. I always look over my shoulder/mirrors except when I can't see over a vehicle backing out of a parking spot. That's when it is the most useful for me.
  24. Jun 4, 2025 at 10:42 AM
    des2mtn
    SW
    Tonto cover
    True, I made an assumption based on the fact he has an old man truck which usually have stock UCAs.
    455h0le_dachshund likes this.
  25. Jun 4, 2025 at 10:46 AM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    I lost the zerk fitting on my driveshaft closest to the transmission. Ordered one from dealer and it doesn’t have threads on it. Anyone know how to install driveshaft zerks? Just push it in? IMG_0992.jpg thanks
    oscardog86 likes this.
  26. Jun 4, 2025 at 10:56 AM
    Dakillacore
    Georgia
    Those are all different systems when it comes to the beeping and camera system.
    The beeping when you approach an object is from the ultrasonic parking sensors. These are little circular sensors imbedded in the bumper cover.
    The cross traffic alert system is tied in with the blind spot monitoring system. This is a different radar unit than the parking sensors and is located in the rear on either side of the lower quarter panels.
    The rear camera is really just a camera with no additional functions. Unless you have the surround view option (birds eye camera system) then it would require calibration to the system if ever damaged.
    bmf4069 and The Black Mamba like this.
  27. Jun 4, 2025 at 11:17 AM
    Kalannar97
    Michael
    Hillsboro, TN
    Yeah, mine is a way different system to my wife's Sorento. Since I mostly drive the truck and CR-V, I'll just keep doing it the old fashioned way. lol
  28. Jun 4, 2025 at 11:17 AM
    Box 2.0 looking nasty! Glued and brad nailed all joints. Added a brace since I’m using 1/2” MDF/HDF. Kicker Solabaric round 8” calls for 0.44cuft of airspace. This box is 0.456, minus the brace :eek2:. Nailed it.
    Hutcheson, bmf4069, Sirfive and 4 others like this.
  29. Jun 4, 2025 at 11:25 AM
    oscardog86
    oscardog86 New Member
    Southern California
    Interesting, im not sure about mine but ive removed one of my driveshaft zerks and it was threaded. So not sure!
    Voss[QUOTED] likes this.
  30. Jun 4, 2025 at 11:41 AM
    The Black Mamba
    DFW
    Imma keep it stock
    Not all propeller shaft spider grease fittings are the same. Here is what I found in the FSM. Unfortunately, it's not very helpful. Even searching "spider"
    oscardog86 and Voss[QUOTED] like this.
