  1. May 31, 2025 at 9:41 AM
    RobertD
    Robert
    DFW, Texas
    https://www.ebay.com/itm/293336326056
    He gets handles often but they go quickly. If you message him, he will sometimes message back when he posts one.
  2. May 31, 2025 at 9:49 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Just keep looking on eBay. I found mine after I lost one that sold to another person.
    Rick52Chevy[QUOTED] likes this.
  3. May 31, 2025 at 10:01 AM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
  4. May 31, 2025 at 10:55 AM
    RobertD
    Robert
    DFW, Texas
  5. May 31, 2025 at 11:01 AM
    rdiddy5
    rdiddy5 New Member
    Arizona
    2018 Crewmax 1794 4x4
    I def have benefited from having them on my 2.5gen!
    coldcanuk, Soflo and RobertD[QUOTED] like this.
  6. May 31, 2025 at 12:57 PM
  7. May 31, 2025 at 2:03 PM
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    MORE BOLTS
    Officially have everything I need to install all new suspension aside from the time to actually do it lol. And some anti-seize, but that’s easy to get.
  8. May 31, 2025 at 2:11 PM
    Fergie
    Fergie New Member
    From this:
    To this:
    Drove Big Booty Judy for the first time in a month after a rear diff failure, R&R of both front and rear, and a regear to 5.29s from ZUK.
    If y'all need gears done, contact Ayers in PHX too...ask for Parker. His family owned business can do cryo and REM on any sets. Only noise I hear was tires on pavement instead of the near constant whine I've had for two years.
    As an aside too, anyone know why my FRAC system would stop working after sitting for a month? Its done this before, but I cant recall the situation. Required pulling the radio, unplugging and replugging things back in and it was fine after that.
  9. May 31, 2025 at 2:18 PM
    rdiddy5
    rdiddy5 New Member
    Arizona
    went over to check on the travel trailer. i was able to successfully rig up an extension for the 7pin plug since my new WDH shank is longer to clear the tailgate, thus requiring more length on the trailer wires.
  10. May 31, 2025 at 2:50 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
    Order from Toyota Genuine Parts online 2b490b1e-8faf-44d8-8f85-2d105f94ca9b.jpg and that bolt setup from Lowes
  11. May 31, 2025 at 4:21 PM
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    First oil change on the Tundra as well as first oil change I’ve done in a decade or so.
    Pretty straightforward except for two small issues:
    1. As the oil slowed down coming out of the pan it started dripping onto the TRD skid plate, so much so it was dripping out the other end towards the front. I’m due to pull that off anyways as I’d like to clean it and paint it black with SEM Trim Black and also to swap front sway bar for TRD sway bar. I ended up jacking the truck up on drivers side to help it finish draining a bit faster and avoid more mess to clean on the skid plate.
    2. The filter drain plug didn’t come out, instead the entire filter did, so a bit more mess. I didn’t have a vice or filter wrench to get the drain plug out after I pulled the filter so just punted it to the next change. Figured it only needs a new gasket if I had actually pulled the drain pug off.
    Also I looked carefully and everywhere for the crush washer and could not find it, so further confirmation it’s better to do it myself (also dealership will have me sitting for 2-3 hours sometimes for an oil change).
    Finally I installed the Valvomax drain plug - with the skid plate issue this seems like a really good idea for next time.
  12. May 31, 2025 at 4:51 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Get this setup Screenshot_20241214-145727.png Screenshot_20241229-082854.png
    And I installed a Fumoto valve but I like the one you added also.You can also order a pack of the crush washers off Amazon
  13. May 31, 2025 at 5:24 PM
    French Avocado
    Utah / Wyo
    Installed the dual USB-C ports
    Henry1jg, woods, Bdiddy and 14 others like this.
  14. May 31, 2025 at 5:47 PM
    TNThunder
    TNThunder New Member
    Colten
    TN
    2017 Inferno SR5 Off-Road
    Gave her a bath and cleaned the inside after our camping trip. Got an awesome Memorial Day deal from Amazon on these floor mats https://a.co/d/bYfrZlj for $20 and installed them. Also put this little decal on as well. IMG_4816.jpg IMG_4817.jpg IMG_4818.jpg IMG_4821.jpg
  15. May 31, 2025 at 5:52 PM
    centex
    centex New Member
    Those look like they function way better than the Toyota junk I’ve got. May have to snag those.
  16. May 31, 2025 at 5:57 PM
    Unbound
    Unbound New Member
    2021 Toyota Tundra SR5
    Awesome! Link or part #?
    SAGE63 likes this.
  17. May 31, 2025 at 6:01 PM
    TundyManFL
    Yep I have - filter wrench fit perfectly and the screw in funnel also made it super easy to fill. Didn’t get to use the filter drain tool unfortunately.
    I watched a vid from the car care nut talking about not switching to the metal oil cap. Seemed a bit overly cautious. What benefit do they provide other than not being plastic?
    The Valvomax came with its own washer so didn’t need. My dealership also sticks one in the box when I buy a filter there. Was more concerned that last oil change didn’t put one on.
  18. May 31, 2025 at 6:22 PM
    French Avocado
    Utah / Wyo
    Someone else on here found it.
    It is a Toyota part (for the Prius but fits 2.5 Gen Tundra exactly with the same connector) 85532-48080.
    It is pricey $94, so best to buy during one of the 25% off sales - hopefully July 4th - for $71.
    Edit - credit to @Gtboosted
  19. May 31, 2025 at 6:23 PM
    TNThunder
    Colten
    TN
    I can’t vouch for durability but they seem nice and for what I assume was a price error was a good buy. They fit really well too.
    woods likes this.
  20. May 31, 2025 at 6:31 PM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Yeah I didn't think about not needing the washer anymore....duh...I watched the same YouTube from the Car Care Nut and had the exact problem getting the dang plastic filter housing off after the dealership I bought the truck from did a presale service.Glad I had the metal filter housing on standby and that's what is on my truck now with no issues
    bulldog93 likes this.
  21. May 31, 2025 at 7:02 PM
    koditten
    Kirk
    Midland of the Mitten
    Are you sure you weren't referring to the lower control arm bolts?
    Those fuckers always sieze!
    In the last 25 years of Toyota truck ownership, every truck has had at least 1 siezed bolt.
    In fact, my '21 has both rear cam bolts froze up. SMH.
  22. Jun 1, 2025 at 5:12 AM
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    Both actually! I’m tabling messing with LCA bolts until I pick up some oem LCA’s and just replace the whole thing instead of doing bolts and bushings.
    HulkSmurf14 and BR73 like this.
  23. Jun 1, 2025 at 6:13 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Road to revival continues
  24. Jun 1, 2025 at 6:14 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Oooooooooo........please tell the story Mr.! What is going to be done to those 2 beauties?
  25. Jun 1, 2025 at 6:20 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    So the new motor on the left is a special spec motor straight from TRD. The one coming out of my truck will get fully built to hold 800-1000hp.
    I had a buddy who was having a spec race truck built by terrible herbst team/1nine. The team ordered it but then they went to get it cleared by the racing org and they didn’t want to add a Toyota motor to the class so they pulled it out. The motor on the right I’m giving to Snivilous for parts R&D for the community.
  26. Jun 1, 2025 at 6:23 AM
    Corndog123
    Sam
    Tennessee
    Wow man, that's a whole bunch of awesome!! 800-1000 HP? Good Lord!! That's incredible. Now is that TRD engine a 5.7 like ours? I mean, I'm sure it would have cams and pistons and all rhe good internals. But is it or is it something bigger?
  27. Jun 1, 2025 at 6:25 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yep 5.7 3URFE with some modifications to fueling.
  28. Jun 1, 2025 at 6:29 AM
    Corndog123
    Sam
    Tennessee
    Wow, I had no idea the block and heads could handle 1000 horses. Wow, that's impressive. I like things to be overbuilt. That's how I make my knives.
    bulldog93 and ATV25 like this.
  29. Jun 1, 2025 at 6:31 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    The stock motor can’t handle that but can be built to handle that. The crank would remain stock. Upgraded pistons and rods etc would happen to hold 800-1000hp with lower compression to be more boost friendly. Stock motors about 700-750 is about the limits. The transmissions the weakest link but there’s upgrades to those or even transmission swaps happening by a few
  30. Jun 1, 2025 at 6:39 AM
    Corndog123
    Sam
    Tennessee
    Wow, still 700-750 hp is very impressive imo. And yeah the lower compression for the blower. Gotchya. And tranny swaps? Have you done those or do you get the OEM beefed up?
