  1. May 28, 2025 at 7:02 PM
    MRweeka
    MRweeka Validator
    Savvon
    Atlanta, Georgia
    2023 Tundra
    SDHQ Mounts Rough country Seats
    I have some iTunes music I can't play because its the m4a is linked to another iTunes account, having a hard time figuring it out.
  2. May 29, 2025 at 4:28 AM
    bigjuice
    bigjuice Spring hath arrived…
    WA State
    2024 Terra TRD Pro
    Which # Dobinson rear springs did you get?
    …and what’s the lift height and weight rating?
    spliffgates[QUOTED] likes this.
  3. May 29, 2025 at 5:35 AM
    Reubenski
    Reubenski New Member
    2025 Limited CM, TRD Off-road package, 3" lift
  4. May 29, 2025 at 6:06 AM
    Volator
    Volator New Member
    Vassalboro, Maine
    2025 Tundra CrewMax TRD - MGM
    Alu-Cab Contour with Crossbars Decked Drawers - Gen 2 Rough Country HD2 Steps Custom 2nd row platform for Dog Kennels Bullet Point Rubigrid Weathertech HP Matts Ceramic Coated Chrome Delete (Vinyl wrapped) Spigen Tempered Glass Screen Protector JDMCAR Central Control Gear Shift Panel Trim Cover Cornfed 2nd Gen 1.5" Front Lift Cooper Discoverer Stronghold AT 295-70/r18 Toyota TRD Exhaust Tip Rok Block tailgate gap seal GG Offroad Camera Relocation kit GG Offroad brake light cable GG Offroad Camera Suction Cup Mounts
  5. May 29, 2025 at 6:12 AM
    Reubenski
    That's too bad. There's not a lot on the market for oem'ish level wiring harnesses like these. Glad GG OR is doing it
  6. May 29, 2025 at 7:14 AM
    spliffgates
    spliffgates New Member
    2022 Magnetic Grey SR5 Tundra 4x4
    I got the dobinson 2 inch rated for a load of 0-110bs spring number is C59-841v. It rides pretty high I should’ve taken before/after measurements but it’s about a 3.5inch lift for the front I maxed out the ADS suspension height.
    Finally took it off road a little bit yesterday and it rode amazing. So smooth and the faster you go the better it soaks everything up.
    bigjuice[QUOTED] likes this.
  7. May 29, 2025 at 12:20 PM
    JollyRogers
    JollyRogers New Member
    South Louisiana
    2025 Lunar Rock Tundra 1794 TRD
    Swapped on the TRD-Pro Tailpipe (PT226-34220-02) that I got during the recent Toyota parts sale. IMG_4379.jpg IMG_4380.jpg
    Zudrick and CappyKD like this.
  8. May 29, 2025 at 1:17 PM
    RabidAxolotl
    RabidAxolotl New Member
    25 Lunar Rock Limited
    What size did you go with?
    Ive had mine sitting in the box since I got them a few weeks ago. Keep forgetting about them
  9. May 29, 2025 at 2:36 PM
    bailey bulldog
    bailey bulldog New Member
    Regular, fit and look great for my setup.
  10. May 29, 2025 at 6:09 PM
    NTX_Tundra
    NTX_Tundra New Member
    Was this just a straight swap or did you need to do anything additional for fitment?
  11. May 29, 2025 at 6:14 PM
    JollyRogers
    South Louisiana
    Straight swap, the tail pipe comes with a new gasket and nuts.
    Super easy swap, pop off the two rubber exhaust hangers, unbolt the clamp at the junction. Drop the spare tire and jack up the truck by the hitch to increase the gap between frame and axle to get the exhaust out and in. New exhaust bolts right in and uses same hangers.
    CappyKD and NTX_Tundra[QUOTED] like this.
  12. May 29, 2025 at 6:27 PM
    MRweeka
    MRweeka Validator
    Savvon
    Atlanta, Georgia
    2023 Tundra
    Powerswitch mount?
  13. May 29, 2025 at 6:52 PM
    RabidAxolotl
    Use the screws they supplied? Didn't realize they used screws and couldnt find my 90degree screwdriver, so it waits a few days
  14. May 29, 2025 at 6:53 PM
    RabidAxolotl
    Any sound difference at highway speeds compared to the original?
  15. May 29, 2025 at 7:00 PM
    JollyRogers
    South Louisiana
    Haven’t been on the highway yet; not expecting much difference and honestly don’t know that I’d be able to identify a mild change at those speeds
  16. May 29, 2025 at 7:22 PM
    Daedalus
    Daedalus New Member
    Nope. Mild change outside, nearly imperceptible inside.
  17. May 29, 2025 at 7:44 PM
    bailey bulldog
    I did....if you have a ratch, socket and short screw tip it works better. After I put them on, I've sprayed them a couple times with black spray paint so it looks much better.
  18. May 30, 2025 at 1:27 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Installed "Tool" box, relocated rear differential vent and installed AVS window vents.20250529_075445.jpg 20250530_105725.jpg 20250530_100903.jpg 20250530_091517.jpg
  19. May 30, 2025 at 2:01 PM
    Daedalus
    Daedalus New Member
    Giving the HyperDip a shot. So far I’m impressed
  20. May 31, 2025 at 10:41 AM
    Noobo Baggins
    Noobo Baggins New Member
    Glenn
    2025 Platinum Lunar Rock
    OE 3" Lift, 35" BFG KO2
    Added the color matched stash and soul patch today... Ecoological BumperShellz
  21. May 31, 2025 at 12:17 PM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    @dirtydeeds axle dump! $100 cheaper than nytop and I got it in a week, despite the longer lead time advertised on Keith’s website. Really like that it comes painted as well.
    51TRDPRO, SnowToy and MAC25Tundra like this.
  22. May 31, 2025 at 1:42 PM
    Daedalus
    Daedalus New Member
    Final product.
    ARCOVT23, BWag5, RatPanda and 4 others like this.
  23. May 31, 2025 at 2:46 PM
    RabidAxolotl
    RokBlokz on finally. Pretty much covers the wheel poke on +18 Method 316s
  24. May 31, 2025 at 3:18 PM
    Retroboy1989
    Northern Utah
  25. May 31, 2025 at 3:22 PM
    Daedalus
    Daedalus New Member
    BlackNBlu, 60centenergy and Raven67 like this.
  26. May 31, 2025 at 3:30 PM
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    Used Carista to turn off fake engine sounds.
    Used Carista to turn on fake engine sounds.
  27. May 31, 2025 at 3:46 PM
    ToyoJon
    ToyoJon New Member
    2025 Tundra Limited
    I did the same thing. Much better now.
    BdBoyitz and Bulldog6[QUOTED] like this.
  28. May 31, 2025 at 5:48 PM
    60centenergy
    60centenergy Mods Member
    Zack
    GVL
    ‘24 Lunar Rock SR5 TRD Sport
    Agreed. Had mine installed for close to a year now and works great. I’ve forgotten all about that auto off feature of the truck. Just wish we could eliminate the dash icon.
  29. May 31, 2025 at 8:43 PM
    Soflo
    Soflo New Member
    Tom
    Miami, FL
    2022 Tundra TRD off road
    What’s wrong with stock?
    Finally used the new bed mat. Stopped smelling after two weeks covered with a tonneau cover.
    BlackNBlu, Bulldog6 and BdBoyitz like this.
  30. Jun 1, 2025 at 4:24 AM
    bowhuntercoop
    bowhuntercoop New Member
    2025 limited off road
    gotta wait for it to cure before I take some outside pics. Full paint correction and Ceramic coated the old girl. Also did the rims. Glad it’s done haha. Once a year touch up to keep it looking mint is all that will be needed.
    made a bed divider. Added some e trac and some tie down. Cut a 2x4 so I can make a true divider if needed. Got some bed liner coming to paint it up and make it look half decent.
