  1. May 28, 2025 at 8:25 AM
    Hell naw, best OEM wheels ever made for any truck, ever.
    Voss and Dirt Ferguson like this.
  2. May 28, 2025 at 9:07 AM
    Dirt Ferguson
    Dirt Ferguson New Member
    Daniel
    Northern California
    04 SR5 AC 4X4 V8
    the poke is not bad at all. I’ll take some up close profile pics. I think it’s more photo perspective trickeration. I’m no flat brim brodozer owner…. lol.
    edit: I’m not sure what I’m going to do with the OEM wheels. I know a lot of people really like them.
    bmf4069 likes this.
  3. May 28, 2025 at 9:30 AM
    M14 EBR
    M14 EBR Oh No, Rex Kramer!
  4. May 28, 2025 at 9:33 AM
    Yes x2. Those are nice OEM wheels but the overall appearance now is much better. Well done @Dirt Ferguson
  5. May 28, 2025 at 10:44 AM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    I like the how it started picture the best. But I'm older so what do I know.
    Hard to beat the OEM look (minus the rake)...
  6. May 28, 2025 at 11:00 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    I think they may be the originals; not sure if they were ever rebuilt, but they probably have about 200k miles if I remember correctly. The truck was babied and everything is pretty spotless. I might start by swapping the driver-side one since that one is aftermarket from a collision previous owner had and it has way more resistance than the passenger side.
    Dirt Ferguson likes this.
  7. May 28, 2025 at 12:00 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    So today I test ran the roof rack I’ve been working on(man did I underestimate the difficulty of this project!). IMG_0949.jpg
    IMG_0950.jpg It whistled like a pig, huge bummer. Had left only about a 1/4” space if not less. Had, not sure what it’s called but this stuff…IMG_0954.jpg
    And now it’s as quiet as before. What a relief!
    Oh and a new issue today, greasing things underneath the truck and noticed a zerk fitting missing on the driveshaft. I was so confused at 1st lol. Easy enough fix IMG_0951.jpg
  8. May 28, 2025 at 12:06 PM
    oscardog86
    oscardog86 New Member
    Southern California
    @Voss Wow dude that roof rack looks incredible! Mustve been annoying and tedious to fit the contour of the roof! Glad you got it nice and quiet too
    Voss likes this.
  9. May 28, 2025 at 12:13 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I can mail you a zerk if you need one. I have a pack in the center console leftover from my UCAs that I never took out.
    BroHon, shifty`, bmf4069 and 2 others like this.
  10. May 28, 2025 at 12:13 PM
    Voss
    2003 AC TRD 4x4
    Thanks bud. Yeah each section, down to its attachment points were a pain. Mostly eyeballed the entire thing by slowly grinding down to fit.
    Still have a little work to do but hard part over.
    oscardog86[QUOTED] likes this.
  11. May 28, 2025 at 12:14 PM
    Voss
    2003 AC TRD 4x4
    Thanks but ordered one from stealer. Even the guy thought it was too expensive, $13 but it’s close and convenient. Appreciate it bud!
  12. May 28, 2025 at 12:16 PM
    oscardog86
    Southern California
    You should trace the countour on some cardboard and keep at template around! Maybe useful if you wanna make another one or to give to someone else. Just seeing yours makes me want to build one but I dont know what id put up there, haha
    BroHon, Voss and The Black Mamba like this.
  13. May 28, 2025 at 12:30 PM
    Voss
    2003 AC TRD 4x4
    Good idea. I have lights, a solar panel & one day a sun based water heater going up there. Also hoping it helps with MPG as a windbreaker for my tent.
  14. May 28, 2025 at 12:36 PM
    matkes77
    matkes77 New Member
    2002 4.7L AC 4x4
    @Jack McCarthy hey buddy, any luck on your leak? I have a drip from the same spot. Luckily one of my extra drain pains catches it in the mean time when it rains until I figure out a fix. thanks!
  15. May 28, 2025 at 12:50 PM
    I’m waiting for the next rain storm but covering the 3rd brake light didn’t give me any water issue, however it only lightly rained after I put the 2” tape on there.
    If successful, I’ll have to buy that $15 brake light gasket to fix it.
    Last time I used electrical tape on the brake light, it was only 3/4” wide, so it buckled after a few rain storms potentially giving me the problem again.
    matkes77[QUOTED] likes this.
  16. May 28, 2025 at 1:01 PM
    matkes77
    matkes77 New Member
    2002 4.7L AC 4x4
    We're supposed to have rain this week, so I'll try the 3rd brake light taped and report back. Thanks
  17. May 28, 2025 at 1:07 PM
    WTF?!? How does only one tire wear like that and at such an angle?
    Edit: Just my imagination. The other one is similar, it just hasn’t worn off the tread just yet.
  18. May 28, 2025 at 1:10 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    are your lca’s adjusted all the way in?
  19. May 28, 2025 at 1:10 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Toe out of adjustment
  20. May 28, 2025 at 1:28 PM
    I think the camber was a little positive from the last alignment. But they can go in more if needed.
    Definitely a possibility, but the camber is a little positive on both sides but within spec.
  21. May 28, 2025 at 1:48 PM
    Feathering is usually a toe thing, IIRC. You'd think it'd be a positive camber issue, but usually toe wear is edge wear. If it's equally like that on both sides, it's more likely overinflation.
    Our '20 Highlander was showing identical feathering on both front tires, but only 1/4 of the wear you're showing on front-passenger. I rotated front to rear recently. I was told "latest gen of Highlanders naturally tend to have edge wear up front", not sure if I believe it. Really need to take it in to be aligned. I was just shocked it was necessary after so few years.
  22. May 28, 2025 at 1:55 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Toe & positive camber with more left hand sweeping turns than right.
    I've seen multiple brand new vehicles that needed alignments. Factory is close enough, until the suspension settles after 500-1k mi.
    shifty` and Jack McCarthy like this.
  23. May 28, 2025 at 1:57 PM
    It’s not really feathering. You can feel the tread getting lower going across the tire and it’s relatively a smooth transition, not choppy.
    I never have much luck with t*ts or tires anyway.
    Trying to get a good alignment vs good “enough” is like pulling teeth and I’ve had LCA bushing issues that led to premature wear in the past.
    455h0le_dachshund and BroHon like this.
  24. May 28, 2025 at 1:59 PM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
  25. May 28, 2025 at 2:14 PM
    I think your tits look awesome FWIW.
    Voss and Jack McCarthy[QUOTED] like this.
  26. May 28, 2025 at 2:31 PM
    I’ve got a male coworker at the radar site who would probably appreciate that comment. Dude is bigger than my last gf and she was a C-cup.
  27. May 28, 2025 at 2:31 PM
  28. May 28, 2025 at 3:06 PM
    pirates712
    pirates712 New Member
    Rochester NY
    2000 V8 AC 4x4
    Anyway.....
    Finally got the replacement bolt. Surprised to see it has what looks like blue locktite. Based on previous experience I think I'll be removing it. Also bought a grommet for the cam position sensor since mine has been missing.
  29. May 28, 2025 at 4:11 PM
    matkes77
    matkes77 New Member
    2002 4.7L AC 4x4
    @Jack McCarthy mine is the windshield. I had it replaced shortly after buying the truck a couple weeks ago and they didn't install it correctly
    455h0le_dachshund likes this.
  30. May 28, 2025 at 4:14 PM
    Yeah, I saw your comment a few minutes ago. Glad you solved your issue.
