General Supercharger Thread
  1. May 26, 2025 at 8:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I have a set of 535cc which is standard for basic SC. If you want more head room for more psi others have said they have 650cc's available.
    ARES35, HulkSmurf14 and AZTundra like this.
  2. May 26, 2025 at 8:14 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I guess if I paid attention to your jumper wire post that I actually looked at the fuel psi gauge earlier...:rolleyes:
    AZTundra[QUOTED] likes this.
  3. May 26, 2025 at 8:26 PM
    centex
    centex New Member
    I’ve got some oem flex fuel injectors available.
  4. May 26, 2025 at 8:29 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Is the wholesale transmissions valve body as aggressive as the IPT in the 1-2 shift?
  5. May 26, 2025 at 9:04 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    From those that installed the WAT extreme its said that it's not harsh. WAT says it can be but wasn't experienced. IPT and Level10 can have harsh shifts but not for everyone. My IPT does not shift hard from 1-2.
    ARES35, Wynnded and HulkSmurf14 like this.
  6. May 27, 2025 at 7:07 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    I suppose I could ask them to do this when I order the unit, but from responses below, it seems like not all of them have a harsh 1-2 shift. I actualy don't have complaints about the shiting on my truck, other than the RPM's at which it currently shifts in specific gears. I'm only looking at valve bodies for long term relaibility of my trans.
    Found an interview from IPT from a couple years back and noticed he also said that he recommends 24K drain and fills on these transmissions for improving life. Are you guys doing the same?
    HulkSmurf14 and blenton like this.
  7. May 27, 2025 at 7:39 AM
    blenton
    blenton New Member
    The shift points can be easily adjusted electronically via a tune.
    As for D&F interval, I’ve done 30k intervals since new and had the fluid tested around 190 or 200k miles (lots of towing and hauling in there). Fluid integrity was very good but it was a bit dirtier than expected - meaning I could have used a slightly shorter interval. So 24k miles would be very reasonable. I opted for a few extra D&F’s to clean up the fluid. I can’t imagine how filthy the fluid would be having never been changed. Our sequoia was absolutely horrid at less than 100k when we bought it. Still shifted ok, but shifter better even after a single d&f.
    Edit - I should also note that the sequoia lacks a transmission cooler just like your 21, and that fluid is cookin! We saw 241* on a trip to socal last year on the freeway with out a trailer or rocket box. It was very dark and stunk, but luckily didn’t smell burnt.
  8. May 27, 2025 at 8:11 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Wow, I have my high atf TC lockup cooling set to lockup if it hits 240.
  9. May 27, 2025 at 8:13 AM
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Yeah, I'm also looking at trans cooler kits, even though I do not ever tow with this truck. Looks like the Genuine Cooling Systems kit is compatible with Magnuson kitk, but they also say to contact them about fitment.
    As for shit point adjustments through tune, it seems that my current tuner doesn't seem to be capable to doing this on my sutom tune as I have been complaining about this for 3 revisions and nothing with my shit points seem to change unless he just reverts to stock shifting so I am talking to other tuners to start this process over again...
    Mdl likes this.
  10. May 27, 2025 at 8:16 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's probably overkill but I do it biennial. Although I did it twice this year to try different dex3 and AISIN atf.
    HulkSmurf14 likes this.
  11. May 27, 2025 at 8:20 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    I tow a lot so I do it annually, along with diff fluid change, it's definitely an overkill but it puts my ocd at ease.
    bflooks, Mdl and Tripleconpanna like this.
  12. May 27, 2025 at 8:21 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'm not SC'd... but my '08 received a single D&Fs every 30k, and my '21 will receive the same. I'm just hitting 25k on my '21 right now, and will be doing a D&F and intalling the trans cooler at 30k :thumbsup:
    HulkSmurf14, bflooks and Mdl like this.
  13. May 27, 2025 at 9:13 AM
    Winks4x4Toy
    Winks4x4Toy New Member
    Maryland
    2015 1794 Super White Tundra
    Bak Flip cover, LED interior lights, American Flag tail gate letter inlays, 20in wheels, full audio system, 12in Android center screen.
    Let me ask you this, do you think I'd go through all this if there was any doubt in my mind it wouldn't work? When you try to do something there's a lack of confidence in knowing your result. I know that you seen the Tundraswat guys already doing 4l80 swaps and even Prospeed has already done one with the 1k whp turbo build. So let's have a little faith here and get over the fact that I'm fully committed to going 4l80 and not just trying, regardless of whether the trucks running or not. Remember words have meaning.
    ssmokedz likes this.
  14. May 27, 2025 at 9:21 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    LOL don't get butt hurt just giving you hard time. I'm fully aware of the running 4L80s out there and the other viable trans options. I've got no doubt it'll all come together.
  15. May 27, 2025 at 9:31 AM
    Winks4x4Toy
    Maryland
    No, all the butt hurt! Lol, but for real it did rub my the wrong way and it's not your fault, I'm just over here without a truck I haven't been able to enjoy for a long ass time and that shit gets annoying. There's always a cause and effect with everything. All is well, carry on with the plan of the day!
    :benchpress:
    :burnrubber:
  16. May 27, 2025 at 9:32 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    LOL dude I hear that- mines been down for a bit and the old mans has been down over a year. The itch to get back out is real.
  17. May 27, 2025 at 9:34 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm still trying to figure out how I am going to explain to my wife that, after 5 months and counting of waiting for an engine, that we will only have to wait a month or two for the transmission. I'm looking forward to keeping the peace and installing a gold 4l80 out of respect for you both. :)
  18. May 27, 2025 at 9:41 AM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Always wanted to build a 5.7 from the ground up.
    Mainly to beef up the innards so I could up the boost from the Magnuson.
    Now that I'm retired I'm seriously considering getting started on it.
    Sitting on the back porch perusing the internet gets a bit old after awhile.
  19. May 27, 2025 at 10:12 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Another piece of my puzzle has arrived, and it's beautiful
    ARES35, ZPhilip, Saltyhero13 and 9 others like this.
  20. May 27, 2025 at 10:44 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I have 5-0 650s
  21. May 27, 2025 at 10:51 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I do mine every 30k miles, as well...
    Tripleconpanna[QUOTED] and Mdl like this.
  22. May 27, 2025 at 11:07 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    That's some nice hardware! I'd be fine spending $500 on that :oops::D
  23. May 27, 2025 at 11:15 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    okay...not to sound like I'm a noob but what exactly am I looking at?
    Tripleconpanna likes this.
  24. May 27, 2025 at 11:18 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Adapter kit for a Dodge Hellcat 8HP90 transmission to mount to the Tundra 5.7L engine
  25. May 27, 2025 at 11:20 AM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Okay,that makes me feel better.
    I'd like to think I'm pretty well versed when it comes to engines but that threw me for a loop.
    Winks4x4Toy and HulkSmurf14 like this.
  26. May 27, 2025 at 4:47 PM
    blenton
    blenton New Member
    That's a good idea. I was pretty surprised to see it hit that high on the sequoia, if it was 110* outside. Even with the SC, my tundra stays below 212 even when towing, with a very rare bump to 218 or 220 that settles immediately when I select a gear. So that cooler makes a big difference, combined with lockup tuning in 4th makes a HUGE difference. Immediately after SC install/tune, I saw 230 ONCE, but the transmission was acting weird. A reflash fixed it and I never had an issue again.
    bflooks and Mdl[QUOTED] like this.
  27. May 27, 2025 at 4:50 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Wait...you'll make it for us for $500. :rolleyes:
    Just the materials have to be up there. Gotta spend the bucks for quality stuff.
  28. May 28, 2025 at 4:50 AM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
    L10 set my D&F at 20k intervals. I'll be following that. 8k on the new trans and zero issues heavy towing. temps stay around 200 in the pan with tc fluctuating but never getting too high on steep grade
  29. May 28, 2025 at 7:20 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Who is still waiting for their WAT valve bodies from the group buy? I'm working with Johnny and he was under impression all orders were satisfied. Please respond only if you have NOT received yours yet. Thx!
  30. May 28, 2025 at 10:54 AM
    ssmokedz
    Shelton CT
    I did get mine. I know someone covered it already I think, But does anyone know the return address/instruction for returning the core?
