Window regulator clips broke. Currently fixing.
Discussion in '2nd Gen Tundras (2007-2013)' started by Snarexander82, May 26, 2025.
  1. May 26, 2025 at 2:05 PM
    Snarexander82
    Snarexander82 [OP] New Member
    2010 Tundra 4.6L Crewmax
    2010 crewmax.
    My driver's side front window, rear window regulator clip/ bracket just broke. I replaced the window felt trim piece and I've cleaned out the window channels and have relubed it with some dry lithium. I'm assuming it broke because of binding with the channels and old trim. And because it's a crappy plastic piece
    I found some replacement brackets on Amazon because I'm not spending $600 on a whole new window when I just need to replace a simple bracket piece.
    Pain in the ass part is that the plastic bracket is epoxied to the window. So I'm going to apply some heat and get it off. The reglue the new piece in the same spot.
    Hopefully this works. Will update as I go.
    D4x4TRD and Ericsopa like this.
  2. May 26, 2025 at 2:11 PM
    D4x4TRD
    D4x4TRD New Member
    Định
    Va beach, VA
    2012 Sr5 DC TRD 4x4 Blaaaaaack baby 4.6liter
    Blacked out front grill badge Bigger tires 305/60r18 Tonneau cover
    Please post pictures please. If possible. Thank you sir.
  3. May 26, 2025 at 5:09 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    I had to do that to my single cab a few years ago. I traded that truck about a year later, so i don't know if the repair held beyond that.
  4. May 26, 2025 at 5:11 PM
    Half Assed
    Heartland Florida
  5. May 26, 2025 at 5:53 PM
    Snarexander82
  6. May 26, 2025 at 6:24 PM
    Half Assed
    Heartland Florida
