  1. Mar 13, 2022 at 8:26 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    My intent was not hurt you in the feels, rather to (foolishly attempt) reducing the spread of misinformation regarding an issue which does not affect 99.99% of us.
    I was born a smart-ass and some don't find my helpfulness to be helpful.
    All types in this crazy world
  2. Mar 13, 2022 at 12:15 PM
    SkipperPete
    SkipperPete New Member
    Pete
    Nicholasville, KY
    2012 Silver Tundra Crewmax
    How do you like those alpharex tails? They look sharp!
  3. Mar 14, 2022 at 6:57 AM
    Ricos
    Ricos New Member
    Ricardo
    2010 Tundra SR5 White Widow
    Never stopping ...
    Has someone mounted this quick load system for a dirt bike in the back of the tundra bed ? I just ordered them wondering if some one has some pictures …
  4. Mar 14, 2022 at 8:54 AM
    Mattyc
    Mattyc <insert custom title>
    Matthew
    NY
    2008 Limited Rock Warrior
    Not stock
    I like them a lot. Very bright, fit well. Only drawback is regardless of the resistors I installed I cannot rid the hyper flash. I have sequoia lights so all LED = crazy turn signals. I’ll eventually figure it out this spring but was tired of working on it in the cold. Overall they’re a great product, no leaks, good fitment and really updated the rear end
    SkipperPete[QUOTED] likes this.
  5. Mar 14, 2022 at 2:29 PM
    SkipperPete
    Pete
    Nicholasville, KY
    That's good to hear! I was concerned about them leaking. I'm curious if the hyper flash would exist if you didn't also have the sequoia LEDs up front.
  6. Mar 14, 2022 at 2:53 PM
    NueveTundra
    NueveTundra Mod list in Bio
    Planet Earth
    07, Black Tundra SR5 CrewMax
    Exterior: Toytec ultimate 3" lift level, Total Chaos Uniball UCA's, Total Chaos Cam Tab Gusset kit, AcanII smoked headlights, AcanII smoke Tail lights (2.5 gen style), DV8 front winch bumper , Badlands 12k winch with Apex Synthetic, White AUTMATCH Shackles 3/4" D Ring Shackle, Apex Winch shackle, Trail Ridge mirrors ,Icon Rebound Pro 17"x8.5" +25, Cooper Discovery STT Pro 285/70R17, PowerStop drilled n slotted rotors W/Carbon pads, Rigid flood flush mounts rear bumper , WeatherTec rain guards , OEM black side badges , Rigid Amber Radiance Pods. Energy Suspension Red Rack and Pinion Bushings, EAG front mesh Grille, RCI HighLift bed mounts. Rough Country DS2 Steps, A.R.E OverLand Canopy with Ascend basket, Stickers: ToyTec lifts windshield banner, Red Strange Music window sticker(back cab), White Strange Music sticker(back canopy), White Rigid sticker x2 (canopy sides), white Official BigFoot Research Team (Back Canopy) Interior: Alpine double din touch iLX-650 , JL C5-653's (front) JL C1-650x (rear) , JL JX400 4 channel amp , JL JX500 mono amp , 2 JL 12" subs , WeatherTec floor mats, Kenwood F/R Dash Cams, Black steering wheel emblem overlay, Tekonsha P3 Brake controller, ToyTec "Fresh" Scent coilover air freshener, Under the Hood: Koyo all aluminum radiator, Mishimoto red silicon hoses , XS Power 3000 amp battery , LAlectric 300 amp Alternator , K&N replacement filter. Online LED store accessories Fuse/relay box. (Identified) Dirty Deeds 8" Cat back exhaust with DD resonator delete/axel over converted into dump. Coming soon:
    I gave mine some exercise and a spa mud bath
    E78B80FC-0F47-436D-A7C0-0F9917B16C01.jpg 2C42A5ED-4127-488D-9C4A-EB2FB53219DE.jpg 5E582CB0-C57C-41E0-99F6-B055659762E2.jpg F5184FC4-07C4-4721-8074-ABB970692CCE.jpg
    oh yeah and upgraded my rotors to NeoChrome thanks to AutoLSD :rofl:
  7. Mar 14, 2022 at 3:20 PM
    CaliBPGen2
    CaliBPGen2 Dude
    Brandon
    Crazy-Cali
    2013 Silver Tundra
    Bed Cover, Liner, 2018 Tundra Wheels, Remote Start, Morimoto XB Headlights inbound. Just getting started...
    Right you are! Installed them on top setting and reused the existing coil. A little out of my comfort level, but it turned out in the end. Overall, pleased with the way it turned out. Haven’t driven it much, but the few miles I drove it to get an alignment done was much better than the factory shocks which make me want to :puke:.
    Picture before:
    …and after.
  8. Mar 14, 2022 at 7:12 PM
    NueveTundra
    Planet Earth
    Well following my last post ordered up "Power Stop high performance pads and rotors", kinda been needing rotors but did cheap pad slaps 7k ago and well ended up boiling the fluid and smoking a pad today. :(
  9. Mar 15, 2022 at 4:17 PM
    surffj62
    surffj62 New Member
    2011 DBL RW
    Took out the washer fluid bottle. Drained the 11 years of mixed smeg. Cleaned it out and replaced with fresh rainex. First world problems!
  10. Mar 15, 2022 at 4:19 PM
    surffj62
    surffj62 New Member
    2011 DBL RW
    Doh- double post
    MTRock likes this.
  11. Mar 15, 2022 at 5:36 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Removed the rear section of the driveshaft and cleaned out theslip joint then relubed it. I discovered that ther is a chunk of foam inside the driveshaft...
    Wile I was at it, I decided to lube the ujoints. I'm not sure they've ever been done, judging by the look and smell of the old lube coming out. Got all of them but the rear joint on the front prop shaft. I'm thinking I will unbolt it, and see if there is enough play in that slpijoint to get a grease gun on it.
    Next will be a new gasket at the exhaust to muffler joint. It's leaking and I'm not convinced I have the correct replacement. Stalling on this as there's a 2019 system available for a great price. Just not sure it will fit.
    I did notice something I thought was odd. The nuts at the flanges between the cats and the mufflet were tack welded to the flanges. Not sure if this was factory or done later for some reason.
  12. Mar 15, 2022 at 6:39 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Katzkin Leather seats, JRI shocks, Rival aluminum skids, 285/70/17 outpost nat, Berger catch can, icon rear +.5 springs, gator trifold bed cover, Perry parts bump stops, switchback turn signals,
  13. Mar 16, 2022 at 1:40 AM
    pyrite808
    pyrite808 Real TRD Pros are built not bought
    Anthony
    Mid Tennessee
    08 DBL Cab Pyrite
    Installed Goodrich stainless steel brake lines then bled the brakes and put new fluid in. Also added some resistors to finally get rid of the hyper flash from my rear led turn signals.
  14. Mar 16, 2022 at 9:36 AM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    Won't even lie, I'm a bit stunned. Need some advice.
    Just had rack and pinion replaced. Truck won't align, caster is off. This is a little stunning to me, I just had my dads mechanic align the truck a month ago when I replaced the LCA with 0 issues. Hard to believe the bolts would rust in a month (they didn't). I'm probably going to take it back to my dads mechanic and see if he can align it.
    Just wondering if anyones got any experience with something like this? With this estimate I'll be coming up on 4 grand for repairs.
  15. Mar 16, 2022 at 9:40 AM
    Windsor
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Used a break in the rain yesterday to put the headliner back in. Bass sounds better now with the sound deadener/thermal insulation/headliner all in place. The vibration I was getting in the roof from the platform is gone. Alignment issues are small and I think I can tweak the clips that the screws go into and get everything back to where it should be. I did somehow manage to misplace one screw for the passenger visor, but a trip to HD corrected that.
    Biggest PITA getting it back in was having to lay my 55 gal water drum on its side with 15 gal still in it stand it back up after.
    I think we are expecting some low 70s next week, I'll get deadener on the pillars while it is warm and get the covers back in after that.
  16. Mar 16, 2022 at 3:26 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    Installed some new power recepticles.
  17. Mar 16, 2022 at 5:22 PM
    Tundra3k
    Tundra3k New Member
    Kansas
    2018 Crew Max
  18. Mar 17, 2022 at 11:29 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Nothing really to show, I installed a bullydog bdx :)
    joseph_womack, WVI, omgboost and 2 others like this.
  19. Mar 17, 2022 at 9:53 PM
    Windsor
    Homeless in Oregon
    Some.
    Put the lights on the side. The cutoff line from the roof is a little closer than I thought it would be. It looks dark, but I still get enough reflective light that I can see.
  20. Mar 17, 2022 at 10:33 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Finally repaired my broken window mount.
    Melted the old one with a butane torch and scraped it off with the glass still in the door. Then glued a new mounting clip on.
  21. Mar 18, 2022 at 8:53 AM
    Beachcomber
    Beachcomber New Member
    2011 Silver Sky CrewMax
    BDS 4.5" w/fox CO Lift Sequoia Grill & Headlights Prinsu Roof Rack Bullet Lined Roof Fuel Wheels/NItto Grappler Tires
    Replaced the block from the BDS lift kit with Old Man Emu springs and coachbuilder +2" shackles. I was getting a bit of a sag in the back with the blocks and 11 year old springs, a bit hard to tell from the pictures but now I have a slight rake which is what I was trying to achieve. The customer support from Ekstrom Design was great, they couldn't have been more helpful.
    20220318_111423.jpg 20220318_111609.jpg 20220318_111503.jpg 20220318_111534.jpg
    wv00097, Stainlesst, D4x4TRD and 13 others like this.
  22. Mar 18, 2022 at 7:18 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    definitely need a second opinion, what do they mean by seized eccentrics? Cam bolts?
  23. Mar 19, 2022 at 6:14 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Bought some new wheels.
  24. Mar 19, 2022 at 7:34 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Yep.
    joseph_womack[QUOTED] likes this.
  25. Mar 19, 2022 at 8:30 AM
    Jjclamdips
    Jjclamdips New Member
    Wichita, Ks
    2008 Limited Double Can 2WD
    Changed out the black mirrors covers for body match, body color matched handles instead of the black and and added a Toyota decal to the tailgate.
  26. Mar 19, 2022 at 10:42 AM
    AstroDude
    AstroDude New Member
    Eddie
    2011 Toyota Tundra Double Cab 4x4
    Ironman 4x4 3.5" lift Stoptech drill and slotted rotors RRW 0 offset rims BMC 35" K02s TrailToys High Clearance Rear Bumper Steel and Kevlar braded brake lines Front diff drop UpTop Overland Rack RoofNest Falcon XL Roadshower 4L IronMan4x4 Awning IronMan4x4 Privacy Tent Custom built bed molle panel (because they don't make them for crew cabs)
    Things I've been trying to do for the past 3 days. Replaced my steering rack and power steering pump. 10/10 pain in the ass.
    QUESTION: Can I bang the CV axle into the front transmission OR should I remove the CV axle from the knuckle and then bang it in?
    D4x4TRD, WVI, Mountun Goat and 2 others like this.
  27. Mar 19, 2022 at 11:35 AM
    NueveTundra
    Planet Earth
    Which ever way allows the CV to be straight while its inserted into Axel axel housing. If you have the CVs at a angle while hitting it you have a chance to break the CV's.
    Most likely will need to remove it from the knuckle.
  28. Mar 19, 2022 at 12:23 PM
    AstroDude
    Eddie
    OK so I pretty much took everything off and next is the UCA nut. There's little to no tension on the brake kine.. It should be much easier to manipulate after that.
    Feels like I'm wrestling a aligator...
  29. Mar 19, 2022 at 1:52 PM
    COTundie
    Trey
    Pretty things
    After accidentally divorcing my cv axle from the front diff, I was able to rotate the axle till the slpines engaged, depress the cir-clip, and slide the cv end into the differential an inch or so (with force, but only hands).
    Then lifted the lower control arm with a jack to achieve a more desirable alignment/angle on the joint. Confirming with rotations that the slpines still seemed engaged.
    I seated a long, mechanics prybar in the groove on the cv collar and lovingly tapped it home with a 3lb mini-sledge.
    Refilled with Mobil 1 75w90, and everything's been running great since (~5k miles)
    wv00097, joseph_womack and AstroDude like this.
  30. Mar 19, 2022 at 3:15 PM
    AstroDude
    Eddie
    Yeah unfortunately when I jack my lower control arm, the truck starts the lift. So I'll have to take the root of taking the CV axle out of the knuckle...not excited about it. Now I'm trying to find the ungodly sized socked to take off that nut
    joseph_womack likes this.
