Frame Rust
Discussion in '1st Gen Tundras (2000-2006)' started by Caderade33, May 24, 2025.
  1. May 24, 2025 at 6:56 AM
    Caderade33
    Caderade33 [OP] New Member
    I am going to look at a 2002 Tundra it’s a 1 owner truck. Should I be concerned with this rust on the frame and also what other things should I look for? It has the 4.7 with 170k.
  2. May 24, 2025 at 7:36 AM
    ATBAV8
    ATBAV8 Mr. Bentley-He builds fast trucks.~Ettore Bugatti
    Tempe, AZ
    Bilstein 5100s with OME 2884 springs, Firestone RideRite airbags.
    We have a stickied mega thread about what to look for on these trucks. Also, if you just search “rust” and limit search to this forum, you’ll quickly become an expert in what to look for. Guys post photos “is this rust hole too big?” and “if more than ten layers flake off is that bad?” and dudes here give it their best guess as to dicey-ness or what.
    Because I am lazy today, I borrowed this from @JasonC. from another similar post. Search on this forum is your friend.
  3. May 24, 2025 at 7:48 AM
    This specific pic is not promising.
    I updated the thread @ATBAV8 is referencing (this one) with much more detail to what you need to look for. Here's that chunk:
    • Some (not all) common spots to check HERE.
    G_unit3000 likes this.
  4. May 24, 2025 at 10:37 AM
    bfunke
    bfunke Tundra Curmudgeon
    Agree with shifty. Run!
  5. May 24, 2025 at 10:41 AM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Yeah, as I was scrolling through, that pic was the tipping point for me too.
  6. May 24, 2025 at 6:22 PM
    2003DC
    2003DC New Member
    Ditto. It's a body mount, and right in front of the spring mount. I bet if you look on the inside of the frame at that location - which has the frame stiffener - it's in even worse shape. Bad spot to have that kind of rust.
  7. May 25, 2025 at 2:33 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    2001 4x4 4.7L AC Limited 55k mi
    I was reading this and was like whoa did I dream about posting this on here, is this what dementia feels like????:rofl:
    ATBAV8[QUOTED] and G_unit3000 like this.
