CMC with 0 offset and 295/70/18's?
Discussion in 'Wheels & Tires' started by Tundra234, May 24, 2025 at 12:40 PM.
  1. May 24, 2025 at 12:40 PM
    Tundra234 [OP] New Member
    Has anyone had to get a CMC with 0 offset and 295/70/18's? I had an alignment done yesterday after removing the Toytecs and installing Bilsteins and now I have rubbing while turning in reverse. I haven't checked to see if it's on both sides yet.
  2. May 25, 2025 at 9:00 AM
    It is both sides.
  3. May 25, 2025 at 9:07 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I had to CMC with your exact same spec. Sidewall/tread aggressiveness plays a factor, but the basic guidance I give is to plan for it with your offset/tire selection.
  4. May 25, 2025 at 9:50 AM
    Sounds like a plan. I'll have to see if any local shops do it at a descent price.
  5. May 25, 2025 at 10:42 AM
    memario1214
    Colton
    Missoula, MT
    That said... don't you have SPC uppers? Did you have the shop push your tires all the way forward using the lower cams? You should have been able to make a good amount of room there.
  6. May 25, 2025 at 11:22 AM
    Yes I have SPC's. I'm not sure what they did. I can post the alignment sheet this evening.
  7. May 25, 2025 at 2:17 PM
    Here is the alignment sheet.
