Where is the brake controller plug on an '07?
Discussion in 'Sequoia 1st Gen (2001-2007)' started by poormxdad, May 23, 2025.
  1. May 23, 2025 at 12:55 PM
    poormxdad
    poormxdad [OP] New Member
    2012 Tundra Grade Four Door 4.6 4WD/ 2007 Sequoia SR5 Leather
    Folks,
    I believe I have the factory tow package. She's got a bolt on hitch and a 7-way plug with wiring that appears factory. I can't imagine it being an add-on. It's just too well fitted.
    The hitch has a sticker with part number 51908-0C030 which is a Toyota part number. Pic attached.
    I've got the side panel off in the footwell and nothing looks like a plug for a brake controller. What color is it? Is it somewhere else?
    I'm looking at the eTrailer.com site for brake controllers for an '07, and there's a picture of the plug-in harness, but no actual installation instructions specifically for my truck.
    Any help would be greatly appreciated.
  2. May 23, 2025 at 1:27 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    It's a white 5 pin connector in the driver footwell area. If ya find a 5 pin connector with the colors shown below, you've hit paydirt.
    They did not make finding mine on a 04 Tundra very easy but the EWD for your 07 shows it in the same place as mine. It's not hidden like needle in hay stack but mine was not odvious. Had to get close and personal with wire harness bundle.
    poormxdad[QUOTED][OP] likes this.
  3. May 23, 2025 at 1:52 PM
    poormxdad
    Interesting.
    I had an '04 Tundra (totaled, unfortunately) and it was so obvious which was the plug--there was a big, white plug with nothing connected to it. I can't find a plug with nothing already connected to it on the Sequoia. I'm looking in the same spot as your Tundra.
  4. May 23, 2025 at 1:54 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Your welcome
  5. May 23, 2025 at 2:45 PM
    poormxdad
    Jeez, there's only one white connector that I can easily get to. Top of the pic on the left. It does have five wires, but they're not the same colors, and the connector is not the same shape. I suppose I need to order the brake controller kit with the harness, and see where (if) it fits.
    I'm having one of those days where nothing is going as planned.
    Be safe and have a great weekend,
  6. May 23, 2025 at 2:56 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Your 07 Seq is definitely very similar to my 04 Tun. The blue highlighted O5 connector is my brake controller plugin.
    Yours is stuffed up in the area of that bigger white connector but not easily found.
    Good luck and TGIF.
  7. May 23, 2025 at 4:23 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Not sure on 2nd gens or Sequoias but 2.5 gens were prewired with a plug behind this panel. And I think 2014’s were on the same panel but on the left side of the steering wheel.
    edit- Just remembered a 2007 Sequoia is a first gen. :(
  8. May 24, 2025 at 4:25 AM
    poormxdad
    Am I correct in assuming I have the factory tow package? I just want to put that question to bed.
  9. May 25, 2025 at 8:55 AM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Are you the original owner ?
    If you register an account at Toyota, you can view your vehicle specs.....Create Account
    If you choose to create account, once your logged in, click on this link....Toyota VIN Decoder - Find Vehicle Specifications By VIN | Toyota.com
    Toyota makes it hard to find otherwise.
    This is what my 04 Tundra shows as far as Tow pkg which was factory.
    If we are to believe the 07 Sequoia brochure, you would have to ask yourself if any of the below are true.....07 Seq brochure attached also.
  10. May 25, 2025 at 1:26 PM
    poormxdad
    No, sir. I am not the original owner, hence all the questions. IIRC, the hitch on our '04 Tundra was built into the frame.
    I created an account and put in the VIN. There's no mention of the tow package. However, she does have the 17 inch aluminum wheels and 265/65 tires--so it looks like it could have Alloy Wheel Package #2 as you posted above.
    The site also says it has fabric seats, but they're leather. I've got the power adjustable captains chairs without the seat heater, but no audio controls on the steering wheel.
    I just got off the phone with eTrailer. The nice lady told me the pigtail for my '07 Sequoia is the same as for my '04 Tundra, so I'm looking for the same plug.
    Thanks!
  11. May 25, 2025 at 2:11 PM
    poormxdad
    I found it. It was buried, above the white plug in the pic I uploaded in post #5, taped to a wire bundle with black electrical tape. It also had a blank female connector attached to it. I'm guessing it's never been used.
    Time for an IPA.
    Be safe,
    NewImprovedRon and BubbaW like this.
  12. May 25, 2025 at 3:18 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Yeah, I meant to mention earlier that my O5 optional connector had a dead female cap….not that it would have mattered.
    Enjoy your Memorial
    :oldglory:
    NewImprovedRon likes this.
