The Coachbuilder TRD Pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by trdpro144, Mar 29, 2018.
  1. Sep 23, 2023 at 4:12 PM
    #481
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Once you're finished with the install and the truck is aligned is the best time to take notice of the improvements. If you get stuck anytime during the install or have any questions. feel free to reach out. I'm always happy to help.
    Ekstrom Design
    801.635.4872
  2. Sep 23, 2023 at 4:29 PM
    #482
    robstruck
    robstruck New Member
    2016 Tundra Trd
    Pro comp leveling with 305/65r18 bfg ko2, magnaflow exhaust, tanneu cover, alpine speakers
    Ok, thanks. Il wait for that. I can see how some may benefit from a firmer ride, guess i just like mine a bit on the plush side. Everything in the kit seems really high quality though
  3. Dec 28, 2023 at 10:58 AM
    #483
    Born-Riding
    Born-Riding New Member
    Barrett
    2021 Tundra crewman TRD PRO
    David, I got the full coach builder kit for the pro in '21. I eventually figured out the problems i was having with it. The shop did not do the wheel spacers so thats why the alignment was never within proper range. i don't think i had any issues with the CB Steering arms. I never figured out the rear wheel chatter/bounce feeling, but it may have been tire imbalance or something. I unfortunately wreck my truck last year and just picked up another 21 tundra trd pro. 295/70R18 on it. I am considering just putting another full CB kit on it with the +3 shackles again as i did before. I am not a huge fan of wheel spacers in general so wondered if there is a set of upper control arms that work to allow the stock Pro BBS wheels (+60mm offset) to be used? Have you come across any? I have only heard of one other person saying something similar about the rear end and they put on the RoadActive Suspension (helper) and said it cured it. Wondering about your thoughts on the two topics. Thanks, B
    Coachbuilder1[QUOTED] likes this.
  4. Dec 28, 2023 at 9:42 PM
    #484
    Savmikey47
    Savmikey47 New Member
    What trd caps are you using?
  5. Jan 6, 2024 at 6:49 AM
    #485
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Minnesota
    2020 TRD Pro Tundra, 8371 Club
    Coachbuilder Pro Kit, 35x12.5 BFG KM3s, Baja S8 hood mounted, Rago Lo-Pro Brackets sitting empty at the moment, Rago Dash Divot Plate, AJT Stuff, LED Lighting throughout, TRD Intake, Bedliner, Tint, Full front PPF, SPS Graphene Coating, and dropped the B out of JBL ;-)
    Tire pressure is everything for ride comfort! The differences between my KM3s at 20-30-40lbs is drastic. I would never go over 32lbs cold if I'm looking for a softer ride. Ride comfort on the trail at or under 20lbs is significant and promotes grip and a larger contact patch. When we get on a forest road after wheeling it feels like your riding on E load pillows...
  6. Jan 9, 2024 at 9:10 AM
    #486
    Born-Riding
    Barrett
    If I have a cb +3 shackle and RAS HD on lowest setting is that going to put me riding at the top of the shock travel? Would i need to consider a longer shock as well? Fox 2.5 or 3??
    Would SPC adjustable Upper control arms give me better alignment range, as i am trying to avoid spacers and aftermarket wheels? currently cannot fit a pinky between tire and stock UCA.
    I am trying to learn all this stuff, and the local shops are too busy to advise. Any help or thoughts on previous post would be really appreciated
    B
    DoublePro likes this.
  7. Jan 9, 2024 at 11:09 AM
    #487
    Born-Riding
    Barrett
    This is the alignment reading without spacers, felt unstable and twitchy and followed road on its own. CB recommendation are on the bottom, just wondering if those in the know would be able to tell if i could achieve what I'm looking for with the adjustable UCA. Thanks all
    Ghosty and Coachbuilder1 like this.
  8. Jan 15, 2024 at 3:19 PM
    #488
    Coachbuilder1
    Salt Lake City UT
    I'd love to help, Feel free to give me a call when its convenient.
  9. Feb 28, 2024 at 8:30 AM
    #489
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Has anyone had any negative issues using this kit? I just purchased the front Pro shims, bump stop extensions, +3 shackle, brake line extenders, and bumper spacers.
    I do actually off-road my truck and just curious.
    I also have a set of Bilstein/Dirt King UCA's collecting dust in the garage. Would I be better off installing them, too? I should be right at 2.5" of lift with the CB shim installed. I gained exactly 1.5" in the front when I added the Fox TRD Pro shocks. Probably going to run 285/75/18 or 35x12.50-18. Considering 305/70-18. Will be mounted on Methods at +25.
    @Coachbuilder1 whats your opinion on adding the UCA? And any other tidbits. I MAY eventually add the steering components, but I will have many stock offset spare wheels, and no wheel spacers installed to use them. So, that's why I didn't do the steering stuff yet, if ever.
  10. Mar 3, 2024 at 4:13 PM
    #490
    TRDfaithful
    TRDfaithful New Member
    Coachbuilder 1" front shims
    Coachbuilder +3 shackles
    Method 701 18x9 +25
    BFG KO2 295/70R18
    Mud flaps removed, front fender liner minor trimming
    Shout out Klean Ridez San Jo
    BurgEER, Ryuu, ackthresher and 5 others like this.
  11. Mar 3, 2024 at 5:06 PM
    #491
    BillyB
    BillyB New Member
    Billy
    AZ
    Nice! I will be putting Bahia Blue Methods on, too! 707's though
  12. Oct 15, 2024 at 7:16 PM
    #492
    GWill
    GWill gods gift to the internet
    Willis
    Don’t know what you’re talking about
    2020 MGM TRD Pro
    Did you end up selling this kit?
  13. Oct 19, 2024 at 2:16 AM
    #493
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Personally, none of those items you listed will affect anything aside from the rake you’ll get adding the +3 shackles. (That’ll be the major thing)
    Aside from that, adding a UCA won’t hurt anything. Just make sure you get an alignment after.
  14. Oct 19, 2024 at 8:04 AM
    #494
    BillyB
    BillyB New Member
    Billy
    AZ
    Old post. But correct, didn't affect anything. Everything works well. Went a bit bigger in tire than I had originally planned. Yokohama was blowing out the 315/70-18 MT's at the time. Of course that required a BMC, bumper cut, etc.
  15. Nov 21, 2024 at 5:12 PM
    #495
    racer714
    racer714 New Member
    2016 trd Pro crewcab desert sand
    I plan on getting this kit, do they still sell the parts anodized red?? I really like that
  16. Nov 21, 2024 at 8:41 PM
    #496
    BillyB
    BillyB New Member
    Billy
    AZ
    I would message him directly @Coachbuilder1
  17. Dec 6, 2024 at 10:03 AM
    #497
    Rockytrdpro
    Rockytrdpro New Member
    Rocky
    2020 black tundra trd pro
    does this work with the rear trd sway bar installed?
  18. Jan 16, 2025 at 3:25 PM
    #498
    mfranzen89
    mfranzen89 New Member
    Mat
    Kansas City
    2021 Tundra TRD Pro LR
    Yesterday was the day. Shim and +3 shackles with Icon tubular delta joint UCA and Method MR314’s. This is how it should have come from the factory.
    just going to say I think the 314’s are super underrated on this truck. Absolutely sick in person.
  19. Jan 16, 2025 at 8:48 PM
    #499
    BillyB
    BillyB New Member
    Billy
    AZ
    Looks great!
    mfranzen89[QUOTED] likes this.
  20. Jan 26, 2025 at 9:08 AM
    #500
    Skoden
    Skoden New Member
    Jared
    Manitoba Canada
    21 mgm pro cm
    A lot of nice trucks in here. Just had a question. I own a 2020 trd sport that has the 5100 bilsteins on top setting with a 1” block in the back. The truck has a stiff ride which I like. I do tow 5-6000lbs occasionally the truck has slight drop but not bad. I’ve now bought a 2021 trd pro. I like the truck however I didn’t realize how soft the fox suspension is it rides really nice I’m just concerned it will sack out when I do haul. It seems the shackles are supposed to help with that. Anyone have experience towing the their pro?
  21. Jan 30, 2025 at 7:57 PM
    #501
    Skoden
    Skoden New Member
    Jared
    Manitoba Canada
    21 mgm pro cm
    Big gulps eh? All good I’ve found many threads here just needed to use the word “squatting” :D
  22. Jan 30, 2025 at 8:49 PM
    #502
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Take a look at...
    https://activesuspension.com/products/toyota-tundra-1999-2020-hd
    Easy install and it fixes the lack of a rear sway bar issue for the most part :thumbsup:
    You'll even notice that while 'unloaded' your turns, braking, etc. are more 'planted' and stable. So far, I'm not seeing any reduction in suspension travel off road, so for me it's a win/win!!
    This thread has some good info/reviews from several members...
    Roadmaster Active suspension review
  23. Jan 31, 2025 at 10:25 AM
    #503
    Skoden
    Skoden New Member
    Jared
    Manitoba Canada
    21 mgm pro cm
    Thanks!
  24. Jan 31, 2025 at 12:41 PM
    #504
    mfranzen89
    Mat
    Kansas City
    When mine was stock, I pulled a trailed a bit for a house project. Loaded probably around the 5-6k mark. It did squat, but overall pulled great.
    Have seen the active suspension system a bunch on here and seems to have good reviews. Have also seen the sumo springs. No experience with either, but reviews seem positive.
    Good luck.
    Skoden[QUOTED] likes this.
  25. Feb 22, 2025 at 7:58 PM
    #505
    Skoden
    Skoden New Member
    Jared
    Manitoba Canada
    21 mgm pro cm
    Just got my lift installed. Shims and +3. Everyone was right in saying the ride is so much smoother. The shackles eat up everything on the road. Well worth it. However now my wife is saying my tires are too small :(
    BurgEER, BillyB and Tripleconpanna like this.
  26. Feb 22, 2025 at 8:11 PM
    #506
    Tripleconpanna
    She's right :thumbsup:
    Then when you put larger tires on, you'll need more powa!!!
    So, the door has been swung open for 5.29s and some boost :muscleflexing:
  27. Feb 22, 2025 at 8:15 PM
    #507
    Skoden
    Skoden New Member
    Jared
    Manitoba Canada
    21 mgm pro cm
    Hahaha. Yes the floodgates may have been unlocked. The problem is these tires are brand new. So may be waiting awhile.
  28. May 8, 2025 at 6:53 AM
    #508
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    Sick Rims! What are they?
  29. May 8, 2025 at 9:33 AM
    #509
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    He said in his post that they are Method 701s (in Bahia Blue):
    greg8765[QUOTED] likes this.
  30. May 22, 2025 at 6:12 PM
    #510
    chrisvuc
    chrisvuc New Member
    2019 TRDPRO
    what running boards?
