Lower ball joints/part numbers
Discussion in '1st Gen Tundras (2000-2006)' started by Jasont, Oct 23, 2021.
  1. Mar 25, 2025 at 7:39 AM
    #391
    No clue! But I'd err on the side of caution. I'm curious what the difference is now. If you flip back to the earlier pages of this thread to look at that bolt part number, you'll see another member who had issues with that bolt being too skinny, so clearly there's something going on with bolt hole sizes ...
  2. Mar 25, 2025 at 7:42 AM
    #392
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    @__YG__ if you order the part numbers that seem to match your truck please post pictures of the parts, as well as the part numbers indicated on the box/bag and see if they are the same.
  3. Mar 25, 2025 at 7:56 AM
    #393
    It's also curious because, unless something is wrong in the documentation, I had the numbers taken from the recall doc as:
    • Late '04 - '06
    • Early '02 - '03
    • Early '01 - '02
    If those years are accurate, then '04+ has to be the same joint, I think? Unless they're custom-boxing things based on the VIN at McGeorge? That'd be wild.
    If those year ranges are wrong, I need to update my reply on the 1st page. I did just put a big disclaimer in my 1st reply on this thread to urge folks to look up their part numbers directly.
  4. Mar 25, 2025 at 10:45 AM
    #394
    __YG__
    __YG__ New Member
    2005 V8 4WD Access Cab
    So if I understand correctly, my truck has the same ball joints as the 04 since its an early 05?
  5. Mar 25, 2025 at 11:54 AM
    #395
    That's what I'm thinking. I'd need to run an '04 truck's VIN thru EPC to say with 110% certainy, "yep!"
  6. Mar 25, 2025 at 1:14 PM
    #396
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Mines a later 04 and this is what I just put on from Ourisman if that helps.
    The Black Mamba likes this.
  7. Mar 25, 2025 at 1:37 PM
    #397
    __YG__
    __YG__ New Member
    I cant seem to find the part numbers you sent, I wonder if these are what Im looking for, LH 43340-39595 & RH 43330-39825 ?
    When you look up the part numbers I just mentioned on autoparts.toyota.com the other part numbers are listed as previous versions.
    what are your thoughts?
  8. Mar 25, 2025 at 1:40 PM
    #398
    __YG__
    __YG__ New Member
    Ah, only now seeing this response, so maybe that is what I need as well then
  9. Mar 25, 2025 at 2:37 PM
    #399
    The part numbers in the picture you quoted, those are what the EPC-DATA site gives me when directly inputting your specific VIN, 2005 AC in V8/4WD.
    But the parts Bubba is showing pics of, those are identical to what I ordered for my '06 AC in V8/4WD.
    Which is correct, the one EPC data gives for your truck, or what Bubba ordered for his '04 and I ordered for my '06? Not sure, but you can always check compatibility in the Toyota Parts system by giving your VIN and noting what Toyota says is compatible. Unfortunately ... see the result of that below.
    I would find it VERY strange Toyota would list a recall kit for '04-'06 truck year range specifically, but somehow have different LBJ part numbers for the three of our trucks... Just sayin'.
    But really. You have four part numbers - the ones Bubba and I used, and the ones EPC spit out for your VIN - use the links in this reply to load up one of the part numbers Bubba and I used, then click the "ENTER YOUR VIN" to check compatibility. Is it compatible with your VIN in their system?
    When I did it using your VIN, this is what I saw...
    (But I saw the same with the EPC part numbers too!!! It makes no sense!) :rofl:
  10. Mar 25, 2025 at 3:14 PM
    #400
    __YG__
    __YG__ New Member
    Im beyond confused lol
    This is what I was referring to though
    The parts I was searching for are listed as previous versions under this part. But when I put in my VIN it also says may not fit, although Im not sure how accurate that is.
  11. Mar 25, 2025 at 3:26 PM
    #401
    That's typical. Toyota changes part numbers, i.e. supercessions (or whatever they call it). But I don't see our '06 part numbers in the supercession list.
  12. Mar 25, 2025 at 3:57 PM
    #402
    __YG__
    __YG__ New Member
    The part number at the top is the one bubba used (39595) and the previous versions list the ones you picked out with my vin 39515, 39575
    might be the correct part still not sure though…
  13. Mar 25, 2025 at 6:42 PM
    #403
    Ah. Well. That would explain it then :rofl:
    Yeah, this solves the riddle. I didn't look at the supercessions to realize they were the same part, but one is a future revision. Looks like they were jumping up by 20s on the last three digits of part numbers
    i.e. 495 + 20 = 515, 515 +20 +20 +20 = 575, 575 + 20 = 595.
  14. Mar 25, 2025 at 8:07 PM
    #404
    __YG__
    __YG__ New Member
    Ah true didnt catch that.
    So in conclusion we thinking LH 43340-39595, RH 43330-39825, Bolt 90080-10066 are the correct ones?
    Is that the bolt you used as well @BubbaW ?
  15. Mar 26, 2025 at 3:26 AM
    #405
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Correct
  16. Mar 28, 2025 at 6:46 PM
    #406
    __YG__
    __YG__ New Member
    Update:
    Got the parts and went to install one of the ball joints today, Bolts do not fit...
    From what I can find online it seems like those are the ones that should fit, they are however too small.
    Re-used the old bolts for now would like to figure out the correct bolts and switch those out tho... any other suggestions where I can look up part numbers?
    I remember reading something somewhere about someone else on the forum having issues with the bolt sizing, cant find it though.
  17. Mar 29, 2025 at 4:12 PM
    #407
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    About to order Bj's and bolts for my 2000 Tundra, Don't need the ARP bolts does everything in my cart here work? Making sure I didn't read something wrong in all these ball joint threads.
  18. Mar 29, 2025 at 4:34 PM
    #408
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Yup. Those are the same parts numbers I installed.
    Filthyphil likes this.
  19. Mar 29, 2025 at 5:25 PM
    #409
    Filthyphil
    Phil
    Sweet thanks brotha! Where did you order from?
  20. Mar 29, 2025 at 7:03 PM
    #410
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Filthyphil[QUOTED] likes this.
  21. Mar 30, 2025 at 5:44 AM
    #411
    NickB_01TRD
    KY
    Big bolt is 9010512316 small bolt is 90080-10066 that you ordered.
    @BubbaW are you sure you ordered small bolts previously for your 04?
  22. Mar 30, 2025 at 7:24 AM
    #412
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Couldn't find receipt but this is my entry in the Parts ordered spreadsheet I use for Ourisman purchases. Seems I was mistaken earlier and did use the longer bolts, sorry YG.
  23. May 21, 2025 at 12:29 PM
    #413
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Our Used Car Manager has an 06 DC. He just came to me and said, "What were those things under my truck that you said I should replace?" I made him a parts list.
    Left Lower Ball Joint Assembly: 43340-39595 x1
    Right Lower Ball Joint Assembly: 43340-39825 x1
    Flange Bolts: 90105-12316 x8
  24. Jun 6, 2025 at 7:43 PM
    #414
    Alltimehigh
    Alltimehigh New Member
    I just did my lower ball joints. I've got a late 2004 AC.
    I bought the kit part no. 04006-62134 (kit came with 2 castle nuts and 4 cotter pins)
    And the bolts part no. 90105-12316
    Everything was an exact match.
    Make sure you have a torch nearby when you do them because mine were seized together.
  25. Jun 14, 2025 at 10:51 PM
    #415
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    Since I don't know if anyone installed AM ball joints I'm looking to replace even though front end tech who replaced tie rods said they checked good.
    2006 Limited. 4x4.
    What dealer is that one from?
    Found one at $155 each.
    I'm also trying to get new bolts, dust covers, boots etc.
    I did find, 90080-10066 coming up as flange bolt that appears to be number for the ball joints bolts on mine by dealer website.
    Any idea what the difference is between those part numbers on bolts?
  26. Jun 15, 2025 at 10:19 PM
    #416
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Redoak[QUOTED] likes this.
  27. Jun 19, 2025 at 1:23 PM
    #417
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    It's really pretty frustrating this has to be so complicated. I've been driving on a set of Detroit Axle 10yr warrantee LBJs for the past 5 years and 20k miles. They feel solid, but I'm going to road trip to Flagstaff and back later this summer and just want the piece of mind the OEM LBJs will give me. Anyways, I've got an '05 DC SR5. Do these part numbers look right?
    shifty` and G_unit3000 like this.
  28. Jun 19, 2025 at 1:46 PM
    #418
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    I've got a 2005 DC and saved some cash by getting the LBJ kit from Ourisman Toyota. Here's my receipt. Good call taking care of that repair with factory OEM LBJs. Cotter pins are included with the kit.
    JasonC. and The Black Mamba like this.
  29. Jun 19, 2025 at 2:31 PM
    #419
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    Thanks, Brother. Ordering now. Saved me $100.
    For anyone keeping track, I was $248.25 out the door.
  30. Jun 21, 2025 at 12:44 PM
    #420
    If you’re ordering the kit, note it doesn’t come with the castle nut. If you order the joint assembly, it does.
    If in good shape, I’d be cool with re-using the castle. But I would surely install a fresh cotter, which I’m pretty sure the kit does supply (joint + cotter + boot?) for our later year trucks.
