DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Apr 16, 2025 at 3:21 PM
    #3751
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Based strictly on your pictures without any info on offset or lift, definitely.
    …cmon dude
  2. Apr 16, 2025 at 3:28 PM
    #3752
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Seriously cmon bro they fit just like that.
    P.S. my garage is full of parts waiting to be installed. Lol
    Uhhhh....[QUOTED] likes this.
  3. Apr 16, 2025 at 3:52 PM
    #3753
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    lol do it!
  4. Apr 16, 2025 at 4:39 PM
    #3754
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Those Icons look nice!
    Dave8699[QUOTED] likes this.
  5. Apr 22, 2025 at 6:56 PM
    #3755
    rcsbguy
    rcsbguy New Member
    Ordered new wheels. Ready for 37s!
  6. Apr 22, 2025 at 7:25 PM
    #3756
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    New set of 37x12.50R17LT Cooper AT3 XLT to replace the Kanati Trail Hogs.
  7. Apr 23, 2025 at 8:19 AM
    #3757
    HappyDad38
    HappyDad38 New Member
    2014 Black Tundra TSS SC 4x4
    6" BDS Lift Fox Coils and shocks 35x12.5r20 nittos
    That wheel and tire set up is going to look killer man. Hurry up and get them installed and post them pics!
  8. Apr 24, 2025 at 5:15 PM
    #3758
    Dave8699
    Dave8699 Trackrat
    NJ
    Waiting on the DRT kit so I can tackle all my suspension work Front and rear
    WinterWarlock21 likes this.
  9. Apr 25, 2025 at 6:57 AM
    #3759
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Maybe the tires? or may be the suspension he/she has doesn't compress as much?
    I have KO2 37s, they run small, here it is compare to my old 285/75r18 AT3W, the Falken measured 34.9" and KO2 measure 36.3 ish, I also run 17x8.5 et0 and I have almost zero rub when compressed on Bilstein 8112 with Icon billet UCAs.
    Yea, those tires run small, so easiest way to fit 37s.
  10. Apr 25, 2025 at 9:51 AM
    #3760
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    I attached a video for reference, the most rubbing occurred at the rear where the tires would grab the top lip of the bedside fender well opening. If you turn up the volume you’ll be able to hear it.
    Also will quote my build thread here which has some pictures to show rubbing at the top of the inner wheel well as well as some others. Note I do not have bump stop spacers to limit up travel. The tires meeting the inner fender wouldn’t be a problem if the friction didn’t act as a brake and slow the wheels down. Lol.
    I’m glad you aren’t experiencing rubbing issues, but my thought is that you’re not flexing out the truck as you claim you are. But if you are, and aren’t rubbing, it would be great to learn what’s different because as you mentioned so many have had the same experience as me with 0mm offset. I’m running +25mm on my current Tundra but at 35” until I can install 5.29s and figure out the right solution for a spare. There certainly are much more wheel options with 0mm offset.
    Could be a mix of things for sure. Tires could be a bit smaller, or bump stop spacers to limit the travel at full compression where the most rubbing occurs.
    tundra_20 and joonbug like this.
  11. Apr 25, 2025 at 12:49 PM
    #3761
    rcsbguy
    rcsbguy New Member
    Post a picture like this of the side of your truck and I'll photoshop the set in 2 seconds.
    Side note, you can buy these Method 703s in machined that are probably lighter and +35 offset for $254 a pop.
  12. Apr 30, 2025 at 4:28 AM
    #3762
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    After a few years of squeezing 37s onto my truck with Method 701’s and 0 offset, I switched out wheels for something less flashy. I went with the new Nomad Convoy in a 17X8.5” +25 offset. The difference surprised me. Not only do I get fewer “sick bro” comments from dudes at gas stations, but my tires no longer graze what is left of my cab mount. (Not much)
    And, my steering generally feels better.. With the 0 offset of the Methods, when I would hit a pothole or a water bar, I could really feel it coming through the steering wheel. With less offset, I get less feedback to the steering wheel. I know it’s only 25mm on each side, but it feels like there’s less strain on all of the components in the front end. The Bead Grip of the Methods was nice reassurance, but I don’t think I will ever actually need it. I spend a decent amount of time in the backcountry, and 18-19psi is generally the lowest I end up airing down to. IMG_3800.jpg IMG_3801.jpg IMG_6732.jpg IMG_6716.jpg IMG_6625.jpg IMG_6622.jpg
  13. May 8, 2025 at 12:03 PM
    #3763
    Dave8699
    Dave8699 Trackrat
    NJ
    Ok it's that time and I'm going to start installing the goodies I have collected snice December. I did a couple of searches and didn't get a straight answer regarding alignment for 37". I know I read it should max out the castor on the Icon UCA. Does anyone have a spec sheet I can follow or some numbers that I should have the alignment guy hit?
    CaptRussia253 and SAGE63 like this.
  14. May 8, 2025 at 12:42 PM
    #3764
    APalmTree
    APalmTree Sometimes helpful
    Brandon
    SW Washington
    A few... Definitely more than 2
    This is by no means a how to, it is just my experience from installing and messing with all of my own components and watching the professional alignment shops ignore my instructions and undo my work. I have not taken my truck to an actual Offroad shop so that is partially my own fault.
    DO NOT just max out the caster from the UCA. If you leave the LCAs roughly neutral, and then use the UCAs to make the caster higher, you are actually going to pull the tire closer to the cab mount. The place you want to start is by adjusting the LCAs forward, away from the cab mount, then you can use an adjustable UCA (I am not familiar with the ICONs but I think they are fully adjustable for both caster and camber purposes) to set the caster and camber at whatever numbers you want to achieve in theory. Most people tend to throw out "max caster" when they are talking about non-adjustable UCAs, because the only way you can achieve it in that case is by pushing the LCA forward, which is desirable to fit big tires.
    Long story short, with a fully adjustable UCA you should be able to push the tire forward away from the body mount and still be able to achieve perfectly factory alignment specs if that is what you want.
  15. May 8, 2025 at 12:59 PM
    #3765
    Rexr
    Rexr New Member
    Sam
    Bay Area, CA
    2018 MGM SR5 CrewMax
    Build Page https://www.tundras.com/threads/stage-1-of-my-build-complete-37s-are-on.157611/#post-3916395
    I have the Icon Tubular UCA's so unfortunately mine are not adjustable, but this is what I have seen people do with adjustable UCA's.
    To get as much tire clearance make the LCA adjustments in a way that it will push the spindle AS FAR FORWARD as possible! This will obviously screw up your allignment, but then you correct for it by setting the UCA for your desired caster angle. I have not heard of anyone doing it backwards (UCA all the way forward and then use LCA to correct for caster).
    Another thing to consider is that the more you push your tire forward with alignment adjustments the closer that tire will be to top of your fender liner. This means at full suspension flex you will 100% rub against that liner if you are on 37's. I would recommend you get the coastal offroads bumpstop spacers to help prevent this. Yes... you are losing 0.5 inches of uptravel, but it also means that you wont be in risk of doing the accidental fender liner delete mod. Also unless you are driving offroad at high speeds its unlikely you will ever even touch the top 0.5 inch of up travel.
  16. May 8, 2025 at 1:31 PM
    #3766
    Dave8699
    Dave8699 Trackrat
    NJ
    Thank you for the quick replies. I did see some videos that the LCA should be adjusted to where the spindle is forward. Also saw some fancy lock out camber bolts being used. Then use the UCA to fine tweak the alignment.
    I dont hit the trails often so the .5" will not effect me at all.
  17. May 8, 2025 at 1:59 PM
    #3767
    Dave8699
    Dave8699 Trackrat
    NJ
  18. May 16, 2025 at 2:05 PM
    #3768
    rcsbguy
    rcsbguy New Member
    One step closer. Pickup tires tomorrow.
    Lets see if I can fit 37s (KO2s) with no CMC.
    Ace96, 300BLK, SAGE63 and 7 others like this.
  19. May 20, 2025 at 7:03 AM
    #3769
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    How’s the ride compare going from the 35” Falken to your 37” KO2?
  20. May 20, 2025 at 10:55 AM
    #3770
    Downytide
    GTA
    Better, the KO2s are c-load tires, so they ride very cushy.
  21. May 20, 2025 at 1:52 PM
    #3771
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    Someday I’ll be a member. :fingerscrossed:
  22. May 20, 2025 at 4:43 PM
    #3772
    rcsbguy
    rcsbguy New Member
    Update: “37s” fit and clear normal street driving. I still need an alignment, but I’m not touching cab mount in any area, even on dips. I will pull suspension and set bumps appropriately.
    Wheels: Method 703 +35MM in 17x8.5”
    Tires: KO2 37x12.50r17
    Update after driving and flexing it out: No rub anywhere. Still need to pull suspension to set bumps.
    Ace96, rmiller139, IEsurfer and 10 others like this.
  23. May 20, 2025 at 4:54 PM
    #3773
    COTundra23
    COTundra23 New Member
    man that looks so good! Congrats. I’m shocked it doesn’t rub the BMC but I guess between the kings and 35mm offset, that’s a secret recipe?
  24. May 20, 2025 at 5:04 PM
    #3774
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
  25. May 20, 2025 at 5:05 PM
    #3775
    rcsbguy
    rcsbguy New Member
    I need to cycle with all the suspension out. The lift doesn’t help at all with clearing the tire.
    No stock front bumper means I can max out my rear LCA cam tab and gain the most clearance without rubbing anything. The +35mm offset helps keep the swing of the tire close to original factory settings. And the 37” KO2s run very small, which takes a lot of the pain out of fitting bigger tires.
    COTundra23[QUOTED] likes this.
  26. May 23, 2025 at 1:25 PM
    #3776
    CO.Tundra
    CO.Tundra New Member
    Taylor
    2019 White Tundra
    Coach Builder 1” shim, +2 Shackles. 285/75r18 AT3
    Fresh as of this morning. Method 703 +35, 37x12.5r17 Cooper AT3 XLTs load D. JBA uppers, Pro coilovers with Eibach springs. Deaver mini pack and CB +3’s. Will trim after alignment, has a small BMC. Minimal rubbing prior to alignment. About 1lb lighter than 285/75r17 Toyo AT3’s and pro wheels, dead quiet too. IMG_3039.jpg
  27. May 23, 2025 at 6:27 PM
    #3777
    CasperTheFriendlyTundra
    CasperTheFriendlyTundra New Member
    That looks amazing, perfectly proportional.
  28. Jun 5, 2025 at 8:32 PM
    #3778
    bwillis625
    bwillis625 New Member
    2019 Cement Crewmax TRD Off Road
    What size tire are you running with the new wheels? Lift? BMC? You’re the first Tundra I’ve seen with the Nomad Convoys +25. Looks really good!
  29. Jun 7, 2025 at 4:44 AM
    #3779
    sea_weathered
    Pacific Ocean
    Thanks! These are the Falken Wildpeak AT4w, in 37/12.50r17. I have around 3” of lift front and rear and a deep BMC. I was running a set of Ironman UCA’s, but recently discovered that my upper ball joints were shot after around 75k miles. I haven’t been happy with my alignment with the Ironman UCA’s for quite sometime, so this seemed like a good opportunity to ditch them for a new set from Dirt King. Despite a couple different engineers telling me that I wouldn’t notice any difference, the Dirt King UCA’s corrected my alignment issues and the front end feels much better. Next on the to-do list is polyurethane steering rack bushings.
  30. Jun 7, 2025 at 5:03 AM
    #3780
    COTundra23
    love those nomad wheels. What rear bumper is that?
