  1. May 20, 2025 at 6:54 AM
    Tundra1D6
    Tundra1D6 Well that escalated quickly…
    New TRD vs old stock. Mine broke and I had to go fishing.
  2. May 20, 2025 at 7:29 AM
    Bigblueintahoe
    Bigblueintahoe New Member
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    I feel like mine was on its way to breaking. The trd cap is super high quality
    joseph_womack likes this.
  3. May 20, 2025 at 9:29 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Another good cheap insurance part is the fuel cap. Bad seal can cause CEL
  4. May 20, 2025 at 3:29 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    Hell... I didn't even know I needed a new radiator cap. Damn you guys....
  5. May 20, 2025 at 4:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The TRD cap along with Toyota red coolant(not premixed) will give extra cooling range. Raises boiling point a little bit.
  6. May 20, 2025 at 5:56 PM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    You totally NEED one lol
  7. May 20, 2025 at 6:24 PM
    zeekevin
    zeekevin New Member
    It’s a mandatory replacement item every 100k from what I have seen
    rmeyer7 likes this.
  8. May 20, 2025 at 6:28 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    What a coincidence... I just turned over 100k last Friday.
  9. May 20, 2025 at 6:51 PM
    zeekevin
    zeekevin New Member
    pop the cap off and give it a quick inspection. If anything have one ordered and leave it in the truck when you need it. There’s been other members like myself who chased overheating issues due to a broken radiator cap in the system
    Bigblueintahoe likes this.
  10. May 21, 2025 at 2:03 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    OEM radiator & gas caps, always
    rmeyer7, HulkSmurf14 and OldGuy03 like this.
  11. May 21, 2025 at 9:50 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    Anyone got a Memorial Day sales lead for king fronts probably 2.5 or mayybbbeeee 3.0s
    Just looking for a small savings or maybe no sales tax. Ready to pull the trigger so a Memorial Day savings might push me in the right direction.
    Ryuu and memario1214 like this.
  12. May 21, 2025 at 10:01 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    hmmm maybe @memario1214 ?
  13. May 22, 2025 at 5:14 AM
    koditten
    Kirk
    Midland of the Mitten
    I like.
    Ryuu and OldGuy03 like this.
  14. May 22, 2025 at 9:56 AM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I can hook you up, no sweat! Shoot me a message with what all you're chasing, and we'll put some numbers together for ya! :cool:
    I'll need to know if you still need UCAs, supporting materials for the rear suspension, etc.
    :cheers:
  15. May 25, 2025 at 6:02 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Changed my oil yesterday and transmission fluid and I have a leak. Looks like high engine, rear main seal getting worse?
    Screenshot_20250525_081112_Gallery.jpg Screenshot_20250525_081029_Gallery.jpg Screenshot_20250525_080952_Gallery.jpg
    Tripleconpanna likes this.
  16. May 25, 2025 at 6:33 PM
    koditten
    Kirk
    Are you actually showing pics of a 17 year old engine?
    If yes, then you got nothing to worry about.
    A tiny amount of oil will travel a loooong way.
    You should not lose any sleep over this.
  17. May 25, 2025 at 7:26 PM
    joseph_womack
    Joe
    Louisiana
    By the way it wraps higher up check your valve covers and that side of the block, if it was just at the bottom then I would say rear main but…
    Tripleconpanna and OldGuy03 like this.
  18. May 26, 2025 at 1:19 PM
    EmergencyMaximum
    Nothing, in the past several days...
    TheBeast and OldGuy03 like this.
  19. May 26, 2025 at 5:01 PM
    blackdemon_tt
    17yo and 312k I'm sure I'm good. Lol
    OldGuy03 likes this.
  20. May 26, 2025 at 5:49 PM
    joseph_womack
    Joe
    Louisiana
    Actually second thought; 1. Again probably not rear main because it looks like coming from higher up
    2. when I pulled my trans years ago I thought I had a rear main before but it was actually leaking a little at the back of the upper oil pan, so when I put the new rear main gasket in I added some silicone and that fixed it (so you could have a similar problem and it’s leaking out the side of the bell housing)
  21. May 27, 2025 at 2:16 PM
    TobysTundra
    TobysTundra New Member
    Milwaukee, WI
    Blacked out my dash and column piece on my 2010 RW. Multi step process of sanding, clean, adhesion promoter and then a flat black/texture paint. I like how it turned out. Time will tell how the texture/paint holds up. I think the only drawback might be dirt or spills. If it becomes an issue I just sand and paint with something different.
    Cross posted in Rock Warrior Forum.
  22. May 27, 2025 at 7:24 PM
    coveyrise12
    coveyrise12 New Member
    2012 Tundra Crew Max
    Installed my SOB Fab bumper today. Broke off a piece of the panel below the headlights so I'll have to address that before lighting.
  23. May 27, 2025 at 7:28 PM
    Bigblueintahoe
    Eric
    Glenbrook, NV
    2010 Tundra 4x4
    Looks sooo good!
  24. May 27, 2025 at 7:43 PM
    EmergencyMaximum
    Wait, no TRD red?!!
    Looks good, gang :) I didn't even have to do mine. Work package comes standard with this premium evil darkside color scheme!
  25. May 27, 2025 at 7:45 PM
    EmergencyMaximum
    Put some faux carbon fiber vents for a sportier look!
  26. May 27, 2025 at 7:46 PM
    TobysTundra
    Milwaukee, WI
    If I could afford to convert the cluster to Red LED, I would put in some red accents.
  27. May 27, 2025 at 7:48 PM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax, 07 reg cab
    Flushed the transmission on both trucks from the cooler return line. Ran about 16 quarts through both. The process on the 2010 was easier and less messy than the 2007. One has 273k and the other 213k. Hopefully flushing them won't be a mistake instead of drain and filling...they are both shifting buttery smooth now.
    I swapped the mud terrains off one truck for a set of highway tires yesterday, but i havent driven it until tonight. Now i sounds like i can hear a bad wheel bearing. Dangit. :bananadead:
    joseph_womack and Mdl like this.
  28. May 27, 2025 at 8:23 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    I only have one photo right now, but here's my 12 RW interior paint job. I didn't leave any silver/dark gray. I used some eBay TRD red carbon fiber to accent the rings on the dash cluster and around the base of the shifter. I also painted my shifter knob red. SEM paints and adhesion promoter.
    https://ebay.us/m/a4zq3M
  29. May 27, 2025 at 8:38 PM
    TobysTundra
    Milwaukee, WI
    I couldn't figure how to get rid of this last bit of silver and still keep the dial displays where the dash lights come through. A future project I guess. Eventually I want to replace the climate control nobs with the AJT design ones in black with the red "bolts".
  30. May 27, 2025 at 8:49 PM
    OldGuy03
    Jay
    CO
    12 MGM DC RW
    The climate control knobs were an eBay purchase. The 4x4 knob was from Toyota parts department. If you search around the climate assembly can be had used for $60-$90 and the 4x4 knob can be had for $80 or so.
    Edit:
    eBay black climate assembl https://ebay.us/m/sHCFmY
    eBay blackout shifter knob
    https://ebay.us/m/kSoCDC
