Coolant leak
Discussion in '3rd Gen Tundras (2022+)' started by TPA, Nov 15, 2022.
  1. Nov 15, 2022 at 7:18 PM
    TPA
    TPA [OP] New Member
    I have a 2022 tundra hybrid 1794 4x4 leaking coolant from in between the transmission and the electric motor didn’t know if anyone else had seen this problem
  2. Nov 15, 2022 at 9:08 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
  3. Jan 21, 2023 at 1:08 PM
    Pete1
    Pete1 New Member
    2022 Tundra 1794 Hybrid
    I have a 2022 Tundra 1794 TRD Off road Hybrid as well. Noticed the coolant leak this AM, pink fluid on garage floor. Running down the hose and coolant level was at low level. Dropped it off at the dealership today and will find out Monday. Absolutely unacceptable in a $70K truck with <10K miles.
    supermike, mayan and Leo's first like this.
  4. Jan 21, 2023 at 1:12 PM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    I had one in my 1 month old 2022 in November at 1300 miles.The service manager said a connecting rod associated with the expansion tank was the culprit. Said it looked like a home made part. Replaced the tank, rod and a hose. Parts took several days so it was out of commission 8 days. 2 months later and issue has not returned. The earliest by far I have ever had an issue with new vehicle. Fingers crossed a one off. Reported to 1-800 Toyo. The guy from Nigera on the other end did not give a damn
    batman900 and MadMaxCanon like this.
  5. Jan 21, 2023 at 3:00 PM
    Pete1
    Pete1 New Member
    Thanks for the input! I was not happy! I’ll share with my service advisor.
  6. Mar 15, 2023 at 9:18 AM
    v8ordie
    v8ordie New Member
    My 2022 failed me at 4400 miles. Coolant had been leaking since I drove it off the lot and no indicator warned me on the dash. Took it to dealer, they told me I had a blown head gasket. Here I am 6 months later in a lemon suit against ol'reliable toyota corp. Good luck to you guys, I really loved the truck.
    supermike, batman900 and Yaboy like this.
  7. Mar 15, 2023 at 10:11 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2025 RAM 3500 6.7L Cummins
    That sucks. Sorry your new truck had problems. Welcome to the forum anyway.
  8. Mar 15, 2023 at 10:23 AM
    KroppDuster
    Here. There. Everywhere.
    Bilstein 5100s
    Curious to hear where it's leaking from. It looks like it's leaking higher up in the system since it's running down the hose. However, it also looks like it's weeping from the top of the hose connection. I wonder if the clamps are just not seated properly at both ends? That's what it looks on my XJ when my clamps came unseated (I hate those cheap pinch-style clamps BTW).
    Could be similar to the recent issues with Tesla's and Hyundai's where they had repairs completed prior to delivery and they were missing bolts during the reassembly process after the repair. Maybe they had to unseat the hose for something and it was reseated correctly.
    On a side note: External coolant leaks are much better than loosing coolant without an external leak. :eek:
  9. Mar 15, 2023 at 10:43 AM
    Fatone
    Fatone New Member
    There have been a lot of QC holds for all manufacturers during the supply chain period. Makes you wonder if there is some "Chuck Newguy here is a bag of parts go fix that try row of vehicles on hold in the back lot" causing quality issues
  10. Sep 20, 2023 at 4:41 PM
    carlosgaleas98
    carlosgaleas98 New Member
    I have a 2022, 1794 4 x 4 Trd the dealer mentioned to me when they did the last oil change they had out cooling leak. They order the part I took it in today and they told me the notice there was another leak coming from the engine base so they’re waiting for manager for Toyota headquarters to take a look at it Hopefully does not turn into a lemon lawsuit
    svcabron likes this.
  11. Sep 27, 2023 at 8:14 PM
    Trddride
    Trddride New Member
    Donny
    Trd for life
    Lights, tires,
    Any updates on these leaks I have a 2023 and I'm going to lay under there and check for leaks now crazy to think 4500 I could have any leaks! But like to know the issues these trucks are getting.
  12. Nov 27, 2024 at 4:22 AM
    olafman1
    olafman1 New Member
    North Carolina
    2024 TRD Pro
    2024 TRD Pro, just did the break-in oil change at 988 miles, and noticed some coolant, coming from somewhere above. @Fatone do you have the receipt of what was done to repair yours that you would be willing to share?
  13. Nov 27, 2024 at 7:09 AM
    JDAZ
    JDAZ New Member
    NJ
    2022 Lunar Rock TRD Limited
    Chrome Delete, TRD Pro Grill with BD light bar & OEM switch Beatsonic Amp Undercover armor flex cover
    Mine wasn’t new but I found coolant splashed up in the front of the motor because the coolant reservoirs were way overfilled. This obviously doesn’t sound like it applies to the OPs problem but I felt like it was worth mentioning
  14. Nov 27, 2024 at 1:56 PM
    olafman1
    olafman1 New Member
    North Carolina
    2024 TRD Pro
    You have me thinking now. I do have a few platters on the fan shroud which is pretty high up near the coolant reservoir. Do you know were the reservoir overflow is or how it overflows if it were overfilled from the factory/dealer during PDI? I'm used to a short hose near the coolant reservoir that vents/overflows, but the Tundra has what looks like a plug on what could be an overflow right below the cap. If that cap does allow coolant out, it does align with the areas below it with pink crusty residue.
    The engine coolant cap/plug (the left one, not the one circled) is almost directly above where the coolant residue is. Also right under there is the plastic water inlet (16322-F4012) with 3 hoses meeting which is where I first thought it was coming from.
  15. Nov 27, 2024 at 3:22 PM
    JDAZ
    JDAZ New Member
    NJ
    Your coolant looks fine. Looks like it’s right at the low level which if it was hot when you took that picture you would be fine. Much lower than mine was.
  16. Nov 27, 2024 at 4:19 PM
    olafman1
    olafman1 New Member
    North Carolina
    2024 TRD Pro
    That's not a picture from mine, just one I found on the Internet showing the plug I was describing. Mine's higher than that, at the full line for sure. I'll have to check where it is after it fully warms up.
  17. Dec 9, 2024 at 8:33 AM
    olafman1
    olafman1 New Member
    North Carolina
    2024 TRD Pro
    Maybe this will help someone else, or maybe someone can explain how this makes sense.
    Tracking the coolant path upwards I found the highest point I see coolant traces is the engine coolant overflow plug next to the cap that has pink/white residue (shown below). Maybe someone spilled coolant while topping it off during the pre-delivery inspection (hopefully) vs. the overflow needed to be used (air pocket or over pressure). The coolant level is set properly in the reservoir and when at operating temperature, I haven't noticed the level being too high that it would come out the overflow.
    Tundrastruck91 likes this.
  18. Dec 16, 2024 at 10:01 AM
    olafman1
    olafman1 New Member
    North Carolina
    2024 TRD Pro
  19. Mar 22, 2025 at 10:05 AM
    Utah1794SSR
    Utah1794SSR New Member
    Taylor
    2022 Tundra 1794
    23 Sequoia Hybrid. Coolant everywhere. Definitely a high leak point. Reached out to my dealer and waiting to hear back.
    k0diak8o8 likes this.
  20. Apr 1, 2025 at 5:01 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    What was the outcome ?
  21. May 20, 2025 at 6:58 AM
    slcsez2000
    slcsez2000 New Member
    Adding this
    I noticed I had a small leak when changing my oil in my 2024 tundra sr5 at 1,000 miles.
    Wiped it up, noticed again when I changed my oil at 5,000 miles.
    figured I would take it in and let the dealer deal with it when I get the Toyo care 10,000 mile oil change.
    they said it is this 4 way split needing replaced, they ordered the part. Should have my truck back tomorrow.
    just FYI for anyone else.
    Just got my truck back
    Here is what was replaced and notes
    Tundrastruck91 and olafman1 like this.
