Differential and Transfer Case Fluid Change
Discussion in '2.5 Gen Tundras (2014-2021)' started by Squirrely, Jun 11, 2021.
  1. Jun 11, 2023 at 8:41 PM
    #61
    NikNoid
    NikNoid New Member
    TCase_MetalTape.jpg I found this thread really helpful, so thought I'd add this tip. It worked OK for me. Rather than drop the transfer case skid plate, I just used a piece of metal tape to redirect the draining fluid.
    The Dude, OHwendTrd, phabej and 6 others like this.
  2. Jun 11, 2023 at 9:39 PM
    #62
    Aught16TSS
    Aught16TSS New Member
    J
    Tuckasee
    2016 TSS - Magnetic Gray Metallic
    Dual Flowmasters, hidden LEDs in hood bulge, 3.5" lift and Ridge Graps
    NICE!
  3. Jun 12, 2023 at 5:20 AM
    #63
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    smart
  4. Oct 10, 2023 at 6:47 PM
    #64
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
  5. Oct 10, 2023 at 7:18 PM
    #65
    javayankee
    javayankee New Member
    NJ
    2019 DC SR5 TRD Off Road
    TRD RSB, Cat Shield, GCS Trans Cooler, Rago Dash mount, etc
    Spyker[QUOTED] likes this.
  6. Oct 10, 2023 at 7:42 PM
    #66
    belairbrian
    belairbrian New Member
    2016 Crew Max 4x4 TSS
    This is how I get the fluids in. Big for the differentials, small for the transfer case.
    Spyker and RustyShackle323 like this.
  7. Oct 14, 2023 at 7:47 AM
    #67
    Spyker
    rock & roll, much appreciated
  8. Oct 14, 2023 at 7:51 AM
    #68
    Spyker
    According to SparksParts there is a new front diff drain washer, part # 90430-24017, the above is the old part number, but I believe it’s still the same flat copper washer.
    Henry1jg likes this.
  9. Oct 14, 2023 at 10:10 AM
    #69
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Weird, but not surprising that they’d change a part number and create additional SKUs for (presumably) identical items.
    But, yes. You’ll need (3) of one, and (1) of the other for the diff’s. T-case just uses 3/4” pipe plugs. Up to you if you’re comfortable using a couple wraps of Teflon tape or a dab of pipe dope. Some folks have concerns about Teflon in the case, but it won’t happen if you wrap the plugs correctly. …don’t wrap the first thread…
  10. May 11, 2025 at 5:46 PM
    #70
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Will this kit work for my 2019? Thanks. Now have to figure out what fluid. Reading back through all the posts. Forums rock.
    ATV25 likes this.
  11. May 18, 2025 at 7:32 PM
    #71
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Watching. Good info here, need to do mine soon.
