Suffered a Blowout
Discussion in 'Towing & Hauling' started by bucketlintels02, Oct 6, 2024.
  1. May 17, 2025 at 11:06 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I bet 80% of the folks towing travel trailers are exceeding the speed rating of their trailer tires.
  2. May 18, 2025 at 4:08 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Best of luck on repairs OP, my last one earlier this year got totaled out from some tree damage.
    Picked this up last weekend, 2019 superb shape. Discovered after I got it home the rear axle is bent flat (no curve as designed) and the tires are canted inward. Noticed the interior tires were fairly worn compared to the front set, initially thought the bearings needed adjusted as they were loose but the problem was bigger than that. Got a new axle on order and need to replace asap and set of 4 new tires. Looks to be an easy swap so I'll do it myself, shops are busy and crazy expensive. Right now I'm getting 8ply trailer tires, would like to get 10ply though for the added stability. Thought I'd share, check axles when looking at trailers/campers!
    atc250r and Tunrod like this.
  3. May 18, 2025 at 4:42 AM
    When buying a trailer, check the “payload” rating. The amount of stuff the trailer can handle being loaded into it. Sometimes it’s really low, like under 1000#. That means they chose the bare minimum axle capacity for the trailer. Say the trailer is 6200# dry. Two 3500# axles would work, but only provide 800# of payload or stuff in it. So you’re basically running around fully loaded all the time. Most trailer suspensions are pretty cut rate too, and very few feature shocks. The axles take a beating. Higher payload equals higher rated axles.
  4. May 18, 2025 at 5:20 AM
    I read posts on here all the time “I drive 80 so I don’t get run over”. I usually drive 55-65mph SO I CAN MANUEVER AND STOP when I need to. I’m in the right lane. Go around if you need to drive faster. I’ve never been run over yet. Weird. Not to mention my prior trailer had the 65mph rated tires on it. New one has passenger car tires on it that are rated higher for passenger vehicles. Not sure if it’s the same on a trailer.
  5. May 18, 2025 at 5:32 AM
    Half Assed
    Half Assed me ne frego
    Heartland Florida
    10 crewmax
    Most trailer tires are only rated for about 65mph. And most travel trailers are heavily loaded constantly. It's not like a utility trailer that's empty half the time.
    Go slower. I used to live right off the interstate. Lots of people with blowouts, flats, and bearing issues would park on the end of my street for repair. It was almost always some type of camper.
  6. May 18, 2025 at 6:29 AM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Yep, and it makes sense with smaller trucks like the 1st gens a couple of us in this thread have. I've towed my trailer with a 98 Tacoma, and now my 02 Tundra. The Tacoma was a manual 5-speed. No 5th gear when towing, and if you push higher than about 65-70 in 4th gear, you're running really high rpm. So 65 is about perfect. In the Tundra, no OD when towing, which means 3rd gear, and same issue. 70mph is as fast as I'll go based on the rpm I'm comfortable cruising at.
    I just got Hankook trailer tires for my truck-bed trailer (that often carries my slide-in camper) and I'm interested to see how they do. So far I've only ever used tires from companies I've never heard of before, that only make trailer tires. I went with Hankook hoping they'd be the same quality as Hankook truck tires. We'll see.
  7. May 18, 2025 at 6:51 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Also the last owner did not have the WDH setup right, riding too high in the front. He had a Tundra DC too, ironically. But when I hooked it up to my truck and it was riding heavy on the rear axle. Has two 3500 axles, but one set was taking majority of the weight. That and if they overloaded the trailer probably factors as well for the rear axle bending.
  8. May 18, 2025 at 6:53 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    Trailer tires follow the same speed rating letter chart as car tires do. The Kendas I just installed on my utility trailer are "N" rated which is 87 mph. I'm not saying I tow that fast but just like I don't want to run the tires or axles at or near their weight limit all the time, I don't want to run a tire near it's max speed all the time. When I rebuilt my utility trailer I also upgraded to slightly heavier springs, thicker shackles that have greaseable bolts, and rubberized equalizers which allow the axles to work a little more independently. All of it was overkill for the 2500lb SXS it hauls but it's insurance that I'll have trouble free trips and it's also good to know that if I need to haul something heavier I'll still have plenty of headroom. I pulled it over 1200 miles on its maiden voyage a few weeks ago and it towed like a dream.
  9. May 18, 2025 at 6:55 AM
    J/L/M are the most common ST trailer tire speed ratings. One of my trailers has L (75) and the other with 17.5" wheels has M (81). J is rated at like 62 mph.
    I don't see a problem with safe drivers towing at slower speeds.
    This was shared yesterday from NY with all the storms and high winds. This guy was out taking pictures of his setup. Bet that was "fun" towing in high winds.
  10. May 18, 2025 at 6:58 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    It’s really hard to beat a Goodyear Endurance trailer tire.
    Watch your speed. as mentioned above, trailer tires aren’t made to go 100 mph. I roll with the semis…
    Maintain your pressure! More tires die due to this than a lot of other issues. Low pressure makes heat. Heat kills tires. Use a TPMS system. They’re about the price of one tire these days. Worth it.
    Your trailer likely came with crap tires. Replace them with quality! Yeah, a couple manufacturers use GY Endurance as OEM. Those are good. The rest are shit.
    Your trailer came with tires that barely cover max load on your trailer. If you’re lucky…. You can likely bump up one size and have a much more robust tire. For example, my TT came with 205/75-15 LRC tires. I put on 225/75-15 LRD. 3/4” taller, and about 1/4” wider. Huge improvement for capacity. I made sure I had an extra 3/8” room between top of tire and the floor.
    Did I mention a TPMS???
    Cpl_Punishment and blenton like this.
  11. May 18, 2025 at 6:58 AM
    atc250r
    atc250r New Member
  12. May 18, 2025 at 7:06 AM
    Something I run on all trailers now is Centramatics. Hell, I even run them on my truck. Unfortunately most half tons there just isn't brake clearance.
    These will drop the temperature of a tire and make them last a lot longer. I just showed my neighbor what a 30K plus mile trailer tire looks like with centramatics. He was shocked and said they looked brand new.
    https://centramatic.com/
    Cpl_Punishment likes this.
  13. May 18, 2025 at 8:59 AM
    blenton
    blenton New Member
    My first little single axle enclosed had biased ply tires rated for 62 mph. They wore funny and needed to be replaced after a year. I didn’t know much about trailer tires at the time but never would have guessed that the speed rating was so low. I knew the guy from whom I bought the trailer; he’s always got a hot rod pickup of one sort (tuned diesel, SC tundra, 700 hp 3.5 ecoboost, etc) and doesn’t dawdle driving down the road.
    I got a little education from the tire shop when I brought it in for new tires. They chuckled when I told them I had no idea why they were wearing like that: unbalanced biased ply tires that are barely rated for the trailer, with variable weights and highway speeds…
    Like @Chad D. I try to put over-rated tires on my trailers now. You can usually get a C or D rated tire in the same tire sizes for a negligible price difference. My travel trailer got new shoes in November - including the never been used spare - and I went with D rated tires on 3.5k axles. Same with my 7x16 enclosed the year before. And I always ask specifically about the speed rating if I have to buy tires in a hurry (as opposed to shopping them out ahead of time and knowing the speed rating): 81 mph minimum and keep towing speeds around 65-70 mph. I have them balanced annually as well. This has worked well for me. Blowouts are the worst.
    atc250r likes this.
  14. May 18, 2025 at 12:21 PM
    NWPirate
    Zach
    WA
    *Thinking about my 4 y/o factory TT tires now :anonymous:*
    Looks like a halfway decent tire from the manufacture though.
    Rainier ST 225/75 on 15's, single axle. D load range, the tire is good for 2535lbs.
    I'd like to try an AT truck tire, but I doubt I can find one with that high of a rating. Probably just end up getting the GY Endurance soon.
  15. May 18, 2025 at 12:45 PM
    EmergencyMaximum
    EmergencyMaximum New Member
    Thats probably the problem. Tire needs to be exercised regularly. If she stays in one spot all the time, it "rocks up", turns very hard.
    When I was moving, my trailer tires were under 5yrs old, but very low miles. After driving about 11 mins from home, I pulled over to check on them. They were pretty warm and looked more plasticky than rubbery. It was a very light and under-loaded trailer. I wasn't much worried and was doing short distance careful max mpg speed.
