Mystery Bang
Discussion in '1st Gen Tundras (2000-2006)' started by HEM, May 13, 2025.
  1. May 13, 2025 at 2:19 PM
    HEM
    HEM [OP] New Member
    I've got myself a mystery "bang" on my 2006 DC 4x4 Tundra. If I drive the car (can be as short 2 mile drive), and then turn the car off, I get a bang sound a minute or so after the truck is off. Sounds much louder than "cooling tings". Happens every time. Haven't modified anything recently. It's so loud when it happens I can hear it in my house while the truck is parked outside (see photo).For clarification, the truck is off and no CEL when on.
    I attached two videos of the sound (one in the cab, and the other from under the hood[end of video]).
    https://youtube.com/shorts/jg4QaeloZ14?si=dLEHz_rOmVuVB1uh
    https://youtube.com/shorts/DpYnOUscQts?si=u1Mk5N6OWw6BrILz
    There is a thread here that seemed to think it was the cats (can't remove mine in California): https://www.tundras.com/threads/loud-bang.141939/
    And a thread here that seemed to think it was low transmission fluid (I topped off trans fluid to rule out): https://www.tundras.com/threads/clunk-sound-after-turning-engine-off.92037/#post-3913817
    Hoping the expert community can help on this.
    Thank you
  2. May 13, 2025 at 3:21 PM
    Man that's weird. Never heard anything like that. I'm curious to see what other members suspect it might be.
  3. May 13, 2025 at 4:03 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    All I got is it sounds like something metal moving as it cools down and contracts.
  4. May 13, 2025 at 4:08 PM
    Nothing wrong with a good mystery bang. But damn, those penicillin shots hurt.
  5. May 13, 2025 at 4:39 PM
    The Black Mamba
    Snek
    DFW
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Yeah, that's metal contracting as it cools. Check all of your heat shield bolts. Might be loose or missing one. Not abnormal.
    Bought2Pull, FrenchToasty and Fragman like this.
  6. May 13, 2025 at 6:44 PM
    Yota303
    Yota303 -Running on hope and gasoline-
    Washington
    2016 MGM Crewmax 4x4 Limited
    It almost like the sound a starter solenoid makes when you have a close to dead battery with not enough juice to crank over? Coming from driver side top or bottom of engine compartment?
  7. May 13, 2025 at 7:46 PM
    HEM
    HEM [OP] New Member
    Thanks for the replies so far. I think the consensus is right; it sounds like metal contraction. I just don't understand why it's so loud or how it started. I can feel it in the floorboard if I sit in the truck. It's alarming when it happens. I'd like to think that this is normal, but it's not really normal since it just started doing it.
    I can't tell which side it's coming from, and I'd guess bottom. I've been under the truck when it does it and still can't figure out for sure where it's coming from.
    All the heat shields look fine to me. Nothing is loose. I'll take a better look at the bolts this evening.
    Thanks again for the interest so far. Just curious to see if anyone has experienced this and found a solution.
  8. May 13, 2025 at 8:27 PM
    Yota303
    Washington
    Does your truck have a manual transmission and a clutch start cancel button?
  9. May 13, 2025 at 11:51 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    LOL...sounds like an option at the whore house.
  10. May 14, 2025 at 3:17 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    No MT option for the DC
  11. May 14, 2025 at 3:25 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
    Next time you shut it off, crawl underneath and inspect. You’ll probably hear it really well down there and can begin to pinpoint a more accurate component causing the noise.
    BubbaW and Yota303 like this.
  12. May 14, 2025 at 3:25 AM
    Retired...finally
    Something exhaust related. Probably a heat shield. Since it heats and cools quickly it has a lot of surface area but little mass.
    AZBoatHauler likes this.
  13. May 14, 2025 at 5:24 PM
    The echoey reverberation after the sound makes it sound almost like the thing making the noise is full of a liquid.
  14. May 14, 2025 at 6:08 PM
    HEM
    HEM [OP] New Member
    Yes. And it almost sounds spring-loaded.
    For clarification, the sound I'm referring to is at 0:04 in video 1 (IMG 2051) and 0:24 in video 2 (2025 05 13 10 41 45).
    I can imagine just hearing the sound and not poking around to solve the problem is a lot to ask. Pretty much just putting this on the World Wide Web in case someone has experience it and has found a solution. I'll eventually get to the bottom of it and post the solution for the next person.
    Heat shields all look good. Being under the truck does not help me figure out where it's coming from. I will say that the truck has also developed a little "rumble" or vibration at idle at a stop light. Not a miss or combustion related. Kinda feels like the power steering pump is struggling. But not sure that's related (mentioning this because the two kind of started in the last month). Trans mounts look fine.
  15. May 15, 2025 at 2:13 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    The only way you're going to find it is to be under the truck when it happens, so change what you're doing until you find it.
    - Move around to different spots under the truck.
    - Wear thick leather gloves and put your hands on different parts of the exhaust and heat shields to see if you can feel it.
    - Get a 3 foot l length of hose/tubing. Hold one end up to your ear and stick the other end at different locations under the truck.
    BubbaW likes this.
  16. May 16, 2025 at 6:59 AM
    It sounds almost like two different sounds. The one I was referencing was video 1 @4sec mark.
    I'm really curious if maybe the flex plate is cracked, and if, after 1-2 minutes of engine/trans cooling, it's kicking back into shape. Based on what others have experienced with cracked flex plates, there's a rattle while the engine is running. "Sounds like marbles in the engine" is what others described.
    Clearly, with the cracking, the metal had some inherent flex or weakness that contributed to the crack. Here's a pic of what I'm talking about. Imagine, while hot, a crack like that is going to separate, which may not cause a noise if the heatup is gradual. But with a rapid cooldown, it could absolutely make that sound. And the slab of metal at play could lend to some reverberation. This is one example of what it can sond like when the flex plate gets really bad, that one sounds more like scraping, while another person said theirs sounded like "marbles rattling". Worth mentioning, you'll notice inside the truck, the sound is barely audible.
  17. May 16, 2025 at 10:44 AM
    HEM
    HEM [OP] New Member
    Found it. Drivers side cat or heat shield around the cat. Got under the truck again because the last comment about the flex plate had me worried about my wallet.
    My head was right under the cat, and bang, heard it. All the cooling tings go away for a short period right after too. I can even let it ting for awhile, then press my key on the shield and trigger the bang, which I would now call a pop.
    There's some mud crusted on the cat and exhaust pipe. I'll try to clean this off and see if that helps. I'll post a video and a solution when I figure it out just in case the next guy—or gal—comes upon this in the future.
    Thanks for all the help so far.
  18. May 16, 2025 at 11:05 AM
    The Black Mamba
    Snek
    DFW
    Imma keep it stock
  19. May 16, 2025 at 11:26 AM
    HEM
    HEM [OP] New Member
    Yes, thank you. And that's why I reach out to the experts. You guys know your stuff. Now I just need to figure out why it's doing it and how to stop it.
  20. May 16, 2025 at 11:44 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    They charge for house calls
    shifty` likes this.
  21. May 16, 2025 at 11:49 AM
    6pk of good brew, I'm cheap like that :rofl:
  22. May 16, 2025 at 11:53 AM
    Retired...finally
    The whole reason I clicked this thread was thinking you picked up some mystery chick at the bar and took her home for some fun.
    Yota303 likes this.
  23. May 16, 2025 at 12:25 PM
