"Clunk" sound after turning engine off
Discussion in '1st Gen Tundras (2000-2006)' started by Jeffwaldo, Jul 12, 2021.
  1. Jul 12, 2021 at 12:47 PM
    Jeffwaldo
    Jeffwaldo [OP] New Member
    Jeff
    2st. Gen Tundra 4x4
    Hello everyone,
    I have a 2006 Tundra 4x4 with 269000 miles. Within the last 5-10k miles I have noticed a fairly significant "clunk" that seems to be coming from underneath the floorboard on the driver's side(Almost as if I can feel it under my feet). The sound resembles a light hammer strike to the frame. It only happens one time but on occasion it happens twice, never more. It only happens when the vehicle has been put into park and the engine has been shut off. It happens 99.9% of the time. Has anyone had a similar issue?
  2. Jul 12, 2021 at 12:55 PM
    Desert Dog
    2001 SR5 AC 2WD 4.7l
    Are you parked on a grade when this happens?
    Have you crawled under it and started pushing and pulling on things and given a visual inspection?
    Any chance you can post some clear images of the undercarriage of where you believe this clunk is coming from from different angles?
  3. Jul 12, 2021 at 12:58 PM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Clunk when off vs clunk when the brake is relieved in P or N?
  4. Jul 12, 2021 at 1:01 PM
    Jeffwaldo
    Jeff
    2st. Gen Tundra 4x4
    Does not seem to matter where or how I'm parked. I have been under a couple of times along with my uncle who is a fairly experienced mechanic. He has yet to hear the sound but did not notice anything when he went under. I will post pics. Thanks
  5. Jul 12, 2021 at 1:01 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    If its driveline, it could be u joints or trans. If its engine, i’d guess it running rich and the extra fuel vapor could ‘pop’ one last time. I know its difficult describing a 3d problem through a 2d forum of pics and texts…
    15whtrd likes this.
  6. Jul 12, 2021 at 1:01 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Checked your engine mounts?
    2mchfun and w666 like this.
  7. Jul 12, 2021 at 1:03 PM
    Jeffwaldo
    Jeff
    2st. Gen Tundra 4x4
    No I have not.
  8. Jul 12, 2021 at 1:04 PM
    Jeffwaldo
    Jeff
    2st. Gen Tundra 4x4
    I will look into this
    Sirfive[QUOTED] likes this.
  9. Jul 12, 2021 at 1:15 PM
    Jeffwaldo
    Jeff
    2st. Gen Tundra 4x4
    I would also like to add that I do have aftermarket "fabtech" coil overs installed, if that helps any.
  10. Jul 12, 2021 at 1:19 PM
    Jeffwaldo
    Jeff
    2st. Gen Tundra 4x4
    I just drove 1/4 mile, parked in my driveway, put in park, set brake, shut engine off and the noise happened roughly 2-3 minutes later then happeneda second time about 2 minutes after that.
  11. Jul 12, 2021 at 1:27 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Like cooling ‘tings’? Running hot?
    Gravy likes this.
  12. Jul 12, 2021 at 1:32 PM
    Desert Dog
    Let's see pix if/when you can. Pix of the coil overs too. May help, may not. Sounds like your best bet is to crawl under it and wait after you shut it off.
  13. Jul 12, 2021 at 2:03 PM
    Jeffwaldo
    Jeff
    2st. Gen Tundra 4x4
    Louder than cooling tings.
  14. Jul 12, 2021 at 2:26 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    I'm beginning to suspect torque converter or something related since you can feel it in the floorboards and happens when you put it in P and shut er down.
    Make sure bellhousing bolts are tight?
    15whtrd and BubbaW like this.
  15. Jul 12, 2021 at 2:57 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Similar thoughts BUT....
    "I just drove 1/4 mile, parked in my driveway, put in park, set brake, shut engine off and the noise happened roughly 2-3 minutes later"
    :monocle:
  16. Jul 12, 2021 at 5:27 PM
    Trans cross member bolts?
  17. Jul 12, 2021 at 6:07 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    In the mining realm we refer to this as a Tommyknocker.
    Desert Dog likes this.
  18. Jul 12, 2021 at 6:15 PM
    Desert Dog
    I considered that too but that would be heard during acceleration and deceleration and over bumps. He states that it only happens when parked. Want to see pix.
  19. Jul 12, 2021 at 6:21 PM
    SouthWestGA
    SouthWestGA New Member
    2007 Tundra CrewMAX and 2014 Nissan NV3500 Passenger
    Fuel pump pressure?
    BubbaW likes this.
  20. Jul 12, 2021 at 6:32 PM
    Desert Dog
    OP, I love a good mystery. How does the truck, ride, handle, steer and run? Anything unusual? Were the coil overs installed in the last 5-10k or did you make any other changes or have any other work done in that time-frame?
  21. Jul 12, 2021 at 6:46 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Axle wrap is a potential cause. Grease the slip joint on the driveshaft and see if it improves. My tacomas use to do this all the time when it was time to grease them
    Glock 40 and Desert Dog like this.
  22. Jul 12, 2021 at 7:05 PM
    SouthWestGA
    Yep i had that on my first Gen too
    Checked and lubed everything
    in the end I was low on trans fluid
    i changed it and added 1/2-1qt extra just as a precaution
    it stopped completely
  23. Apr 22, 2025 at 9:52 AM
    HEM
    HEM New Member
    Was this ever resolved. Be great to hear a solution. Thank you.
  24. Apr 22, 2025 at 9:54 AM
    Clicked on his username and he hasn't been here since fall of 2023...
  25. Apr 24, 2025 at 12:27 PM
    HEM
    HEM New Member
    Well shoot. I'm having the exact same situation as Jeffwaldo described. Loud hammer sound when engine is off. Happens for a few minutes. Way louder than "cool tings", but I have to imagine it has something to do with cooling because it will happen long after the truck has been off. Just started and nothing has been modified recently (one 400-mile-ish trip recently with some light offroading).
    Sounds like I can do a trans drain and fill, and overfill a bit, but I'd rather not if that's not the confirmed solution.
    Can anyone offer any other suggestions or confirm the trans fill?
    Thank you.
  26. Apr 29, 2025 at 8:48 AM
    HEM
    HEM New Member
