TSS relocation errors and Possible fixes...thoughts & experiences?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Tundra234, Jan 30, 2023.
  1. Jul 3, 2023 at 10:58 AM
    coTony
    Tony
    Montrose, CO
    Perhaps that could be the problem, the radar has a limited window to focus through. The newer grill has the TSS just behind the plastic (very expensive plastic) piece and has a full window of view to look through. Those older grills have a large gap between the front surface of the TSS to the grill itself then the geometry of plastic grill presents a challenge for the radar to pass through unobstructed.
    Jomax is trying to prevent the incident of paying for legal representation and wants out of any liability. I cannot say I blame him but labeling your product as “off road use only, not intended for street vehicles” would cover your ass but that is just my opinion
  2. Jul 3, 2023 at 11:02 AM
    Tundra234 [OP] New Member
    You mean AJT? Jomax quit making them a couple of years ago. Finding one is pure gold. I got lucky as hell when I found one a few months ago.
  3. Jul 3, 2023 at 11:06 AM
    coTony
    Tony
    Montrose, CO
    I understand they stopped making them in 2020 and no to AJT, I am talking about Jomax sensor kit.
    What is the gap between the front face of the TSS sensor when mounted to the Jomax plate to the first plastic close to it directly in front? I do not have one in front of me but the pic you posted appears to be set in closer to the radiator?
  4. Jul 3, 2023 at 11:07 AM
    The Jomax is very rare. The issue with the AJT is that the cover is too thick, and also the wrong material. I have made some thinner covers from ABS and have a couple of people trying them out.
  5. Jul 3, 2023 at 11:13 AM
    From the front of the cover plate to the back of the grill is about 3.5 inches. I still have an AJT but if I recall, they both sit just about in the same spot.
  6. Jul 3, 2023 at 11:30 AM
    coTony
    Tony
    Montrose, CO
    This is just my opinion...
    The OEM TSS mount is directly behind the cover shield and I am sure there is a small gap between them. The OEM opening in the mounting location is huge, almost reveals the entire sensor but mounted behind the grill for 3.5" of space trying to get a radar beam made to obviously have a wide beam to cover the entire front of the vehicle from side walk to next lane to focus through a small opening before it can spread. Again just my opinion but that just does not seem like a Apples to Apples comparison to the 2 scenarios. Just again in my opinion is not feasible
  7. Jul 3, 2023 at 11:40 AM
    jayk17
    jayk17 New Member
    '18 Platinum
    Any preliminary results worth mentioning? I prefer the older style pro grille much more so I really want to get this to work.
  8. Jul 3, 2023 at 11:41 AM
    Either I'm tired or confused lol. The AJT and the Jomax both mount the sensor in pretty much the same spot on the radiator support if I recall. With the AJT, I started getting errors after about 15 miles following installation. With the Jomax, no errors at all. The Jomax used a specialized material for the cover, and AJT used thick ABS. Even shaving down the AJT doesn't work. What's funny is I believe the OEM emblem/TSS cover has "ABS" stamped on it but the front is a type of glass.
  9. Jul 3, 2023 at 11:47 AM
  10. Jul 3, 2023 at 11:48 AM
    jayk17
    jayk17 New Member
    '18 Platinum
  11. Jul 3, 2023 at 11:56 AM
    coTony
    Tony
    Montrose, CO
  12. Jul 3, 2023 at 12:08 PM
    Makes sense. I can't believe how expensive those things are.
  13. Jul 3, 2023 at 12:11 PM
    coTony
    Tony
    Montrose, CO
    I bought one but was able to use it for the company taxes since the vehicle was being used under the company at the time. Even with that I had a hard time
    :spending:
  14. Jul 4, 2023 at 8:16 AM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    I have tried 3 different brackets, all had problems but the Jomax worked the best for me. Eventually I switched to the 2019+ TRD Pro grill in Sept 2019 and haven't had any more problems.
  15. Dec 11, 2023 at 8:38 PM
    alphaxcrx
    alphaxcrx New Member
    Will
    2019 Quicksand Tundra SR5 4x4 crewmax
    Anyone have a Jomax bracket for sale?
  16. Apr 6, 2024 at 10:22 AM
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    Installed the the ajt bracket today this afternoon drove it around seems to be working fine even with the 19 pro grille doing what it’s all suppose to do originally I have been wanting to install the original 17 pro grille looking to try out a Jomax bracket if anyone has one and remove this 2019 pro version grille I have because it’s cracked and buddy of mine let me have his 2017 pro grille but since I have techstream I can clear all history and pcs history per faults anytime if you don’t then the faults will go away but reappear fyi…
  17. May 16, 2025 at 10:06 AM
    annimossity
    annimossity New Member
    2021 Army Green Tundra SR5
    TRD Pro Grill Painted Bumper Caps Method MR701 18's
    Hey has your AJT bracket been working fine still with your 19 Pro Grill?
  18. May 16, 2025 at 10:14 AM
    The AJT is for the 14-17 and it does not work anyway. The 19 has a mounting location at the bottom of the grille.
