Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Apr 28, 2025 at 7:00 AM
    #3181
    Ruggybuggy
    Ruggybuggy Seasoned Veteran
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You are going to have to scan it to determine what codes are present. You can’t guess on what the cause may be, you just end up wasting time and money replacing good parts. You can download Techstream on a laptop but will need an interface. Do a search for “Techstream”, lots of info.
    Wynnded likes this.
  2. Apr 28, 2025 at 7:08 AM
    #3182
    2160Tundra
    2160Tundra New Member
    Thank you sir. Is the code reader at Autozone or O'Reilly advanced enough to read a code given that the CEL is not on?
  3. Apr 28, 2025 at 7:23 AM
    #3183
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Are you thinking of going in and getting a free scan? I don’t have any experience with what they are using. Most of the cheap code readers are just reading generic OBD2 information and can’t read manufacturer specific codes.
    Wynnded likes this.
  4. Apr 28, 2025 at 7:25 AM
    #3184
    2160Tundra
    Yes sir that was my initial thought but don't want to waste my time if the generic code readers won't pull up Toyota specific codes. Will probably try it when I get a few free minutes.
  5. Apr 28, 2025 at 7:29 AM
    #3185
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would still go in and have them scan it. Maybe the scanner they are using can pull up manufacture codes. It’s free so what do you have to lose.
    You can download Techstream for free but you will need an interface. Cheapest one that works is around $60.
    Wynnded likes this.
  6. Apr 28, 2025 at 8:59 AM
    #3186
    2160Tundra
    P0302 Cylinder #2 misfire. Oddly enough, I have previously seen this on the internet to be the issue causing VSC OFF/Traction Control with one or two other Tundra owners. Some say the issue was cured while others had lights come back on shortly after replacing coil pack. I'm not sold that this will resolve the issue but will give it a try.
  7. Apr 28, 2025 at 9:57 AM
    #3187
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It might be worth the time to swap the #2 coil to another cylinder to see if the coil might be the issue, or something going on at the cylinder.
  8. Apr 28, 2025 at 10:11 AM
    #3188
    2160Tundra
    …and just had two more show up.
    C1201 and C1310. Engine/EV Control System Malfunction on ECM and HV/EV System Malfunction on ABS Hydraulic Control Assembly.
    Wynnded likes this.
  9. Apr 28, 2025 at 10:15 AM
    #3189
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Might not be the coil. :eek2:
  10. Apr 28, 2025 at 10:16 AM
    #3190
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Clear all the codes and see what comes back. Most are ghost codes that come up. If the P0302 comes back pull the spark plug out and have a look at its condition. If it looks fine, swap the plug with number 4 plug and see if the code follows the plug or stays with the cylinder.
    Don’t assume it’s a coil. Most common reason for misfires are spark plugs.
    Wynnded likes this.
  11. Apr 28, 2025 at 10:44 AM
    #3191
    2160Tundra
    Cleared the codes and all three came back. Misfire on #2 confirmed and replaced coil/plug and that code is gone. Still getting C1201 and C1310.
    Pickup runs fine and I am unable to tell there are any issues when driving at any speed. Apparently, the VSC OFF and tractions control lights have been on for quite some time according to my son.
  12. Apr 28, 2025 at 4:10 PM
    #3192
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Codes starting with C are communication codes. The C1201 and C1301 are both abs related codes. Techstream would tell you if the abs module is online.
    Dont throw out the ignition coil you replaced. There is a chance it was just the spark plug. If you purchased an aftermarket ignition coil you may need the original.
    Wynnded likes this.
  13. Apr 29, 2025 at 1:20 PM
    #3193
    2160Tundra
    Thank you for your time and help. Will look into Techstream for further diagnosis
    Ruggybuggy likes this.
  14. Apr 30, 2025 at 4:15 PM
    #3194
    blackdemon_tt
    blackdemon_tt Battery Slayer
    13 Honda Civic 270k,
    Having some vibration, shaking, issues at 18 to 22mph, 33 and 49mph. I had a pending code for an input turbine sensor which was causing a shake on the passenger side, once replaced, shaking started on the driver side. Don't have any additional codes. I'm going to take it to the tire shop for balancing check, and considering strut replacement since shake becomes most apperanent on rough roads and turning.
    Like the weight shift is upsetting the balance of the vehicle. Haven't purchased anything but considering RA Mevotech front end overhaul with suspension replacement.
    what else would you suggest?
  15. Apr 30, 2025 at 7:46 PM
    #3195
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Honda? I’ll take a stab at it. You didn’t say where the shaking is coming from. Is it in the steering, does it shake when you brake and does it shake the whole vehicle. Shaking is always an unbalanced rotating part. That said struts and suspension do not cause shaking. Vibrations and shakes could be from CV axles, brake rotors, rotating powertrain components, tires and rims.
    Wynnded likes this.
  16. Apr 30, 2025 at 7:57 PM
    #3196
    blackdemon_tt
    My bad. Shakes the whole car, sometimes is negligible other times it gets real, but shakes the whole car only on the speeds mentioned. No shaking while braking. Brakes bite hard though.
    So, I'll get the wheels rebalanced then have the axels checked
  17. May 1, 2025 at 6:47 AM
    #3197
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    That where I would start, have the balance checked first. You can check the CV axles yourself. Grab the middle of the CV axle and see if there is any play. A shake in the car from CV axles is most noticeable when accelerating. Tire balance shake shows itself at speeds 55-70mph. Powertrain shakes are at all speeds and are engine speed related and are worse under acceleration. Torque converter shakes are usually clutch lockup related and go away when transmission is in lower gears where lockup doesn’t happen.
  18. May 1, 2025 at 3:55 PM
    #3198
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4
    Anyone have a favorite uv leak tracer fluid?
    Got an odd power steering leak I'd like to trace
    Randy Morton likes this.
  19. May 1, 2025 at 5:00 PM
    #3199
    Randy Morton
    Randy
    Deepinahearta, Texas
    I've had decent luck with this in the past.
    https://www.napaonline.com/en/p/NCB374G
    Wynnded and Nicklovin[QUOTED] like this.
  20. May 15, 2025 at 8:47 PM
    #3200
    phabej
    phabej New Member
    2018 Platnium
    Hello. I just ran a test on my odb2 and saw this. Should I be concern?
    I just bought the truck recently. No check engine lights, no problems driving etc. I'll run a voltage test tomorrow on the battery. But I think it was showing 13.6v on the app
  21. May 16, 2025 at 6:13 AM
    #3201
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    I would clear the codes and see if they come back. The low or high power supply voltage can happen after the truck sits for awhile and get a low voltage when starting. Yaw sensor failure would set a hard code and turn the light on.
    phabej[QUOTED] and Wynnded like this.
  22. May 17, 2025 at 6:25 AM
    #3202
    phabej
    phabej New Member
    2018 Platnium
    Thanks.
    As for the voltage, I tested the battery and alternator. It seems they are both good. 12.4v before starting the engine, 14.06v idling, 13.98v with lights, radio, AC on.
    Hopefully the yaw sensor doesn't pose a expansive repair of it lights up the dash.
  23. May 17, 2025 at 7:42 AM
    #3203
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    How old is your battery? Doing a voltage reading is not a good way to determine a batteries health. The proper way is a load test. When the engine is cranking it can drop the voltage down on an old battery to a point were it can throw codes. The yaw sensor sits behind the steering wheel clock spring (spiral cable) and is easy to change.
    If you know your battery is in good condition, just clear and see if they come back.
  24. May 17, 2025 at 11:49 AM
    #3204
    phabej
    phabej New Member
    2018 Platnium
    I don't know the age of the battery. I just bought the truck a couple weeks ago. It doesn't have a month and date sticker on it either. It's a die hard battery.
    I'll see if I can reset the code with the carista app. That's all I have.
    Thanks.
    Ruggybuggy[QUOTED] likes this.
  25. May 17, 2025 at 2:29 PM
    #3205
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    You could stop in at an Autozone and have them test the battery. The truck isn’t turning on a light so I wouldn’t worry about it. If the yaw sensor was not working it would throw a hard code. If you’re really curious about it, Techstream can read the live data and you can see the yaw sensor.
  26. May 19, 2025 at 1:53 PM
    #3206
    phabej
    phabej New Member
    2018 Platnium
    I was able to reset it. Currently not seeing any new error code reported.
  27. May 19, 2025 at 2:20 PM
    #3207
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    It will probably never come back. Ghost codes.
    Wynnded and phabej[QUOTED] like this.
  28. May 20, 2025 at 6:14 PM
    #3208
    TheBeast
    TheBeast The Beach
    is it good practice to replace the thermostat when doing full coolant flush ? We are talking 2012 truck.
  29. May 20, 2025 at 8:28 PM
    #3209
    Ruggybuggy
    Dave
    NW ON, CANADA
    2016 Tundra OR
    Nope, leave it alone. The thermostats are extremely reliable.
    Wynnded and phabej like this.
