General Supercharger Thread
  1. May 15, 2025 at 8:20 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    I love when the Detroit Locker in the mustang does that... Means it working and the power is being put to the ground .
    I also thought the new Detroit Locker was spring loaded and didn't make noise or ratchet like the old ones...
    I had an Auburn in my F150 and a Kazuma LSD in my 2002 Tundra.. Had to use the Ford additive and it lasted forever, after I burned out the first one with the Toyota additive and broke the ring and pinion... It didn't work near as well as the Ford additive..
  2. May 15, 2025 at 9:01 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Do share, curious what that looks like?
    I thought my rear was way out of whack but turns out it’s dead on (and has the SDHQ traction bars hopefully keeping it that way).
    The front (total chaos ucas) were definitely off though (toe).
    Mdl[QUOTED] likes this.
  3. May 15, 2025 at 9:22 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Same here. I have the cam brackets welded up but holding off install until I can do it under my lift.
  4. May 15, 2025 at 11:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The cam tabs are pretty thin stamped sheet metal. Sometimes the tabs break off. I noticed my drivers side caster was off when I rotated my tires. Brought it in and he couldn't get it set so had both caster set at 5.5 and I'd like it around 4 ish. You knock off the factory tabs off and weld in new thicker plate/tabs.
    https://www.tundras.com/threads/cam-tabs.56917/page-2
    https://www.chaosfab.com/product/2007-2021-Toyota-Tundra-Lower-Control-Arm-Cam-Tab-Gussets-59870
  5. May 16, 2025 at 12:12 AM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    I have the octogon style cam tabs
  6. May 16, 2025 at 4:40 AM
    centex
    centex New Member
    Geez. That looks more like a horrible design than a clutch issue.
    mustang67408 likes this.
  7. May 16, 2025 at 5:59 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    One slot left for the trans mount
    Mdl and HulkSmurf14 like this.
  8. May 16, 2025 at 7:23 AM
    blenton
    blenton New Member
    I wasn’t too impressed. But to be fair, it was in there for over 100k miles. Though the last half of it was giving me fits. I don’t think it was designed to put up with towing and hauling, but it was the only thing available at the time. And better than open for my use.
    HulkSmurf14, Mdl and bflooks like this.
  9. May 16, 2025 at 10:33 AM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    HP Tuners and PSB-1 Analog AFR signal...yellow wire on PSB to the white wire on MPV Pro-link cable....right?!
  10. May 16, 2025 at 10:37 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Red and Blue are the analog inputs on the pro-link.
    HulkSmurf14[QUOTED] likes this.
  11. May 16, 2025 at 10:38 AM
    HulkSmurf14
    2014 Tundra Limited
    Awesome, thank you...red to the PSB and blue for chassis ground, I assume...? Thank you Bryan!
    Mdl likes this.
  12. May 16, 2025 at 10:40 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Red and Blue are for separate analog devices, black is ground, yellow and orange are for CANbus inputs. You should ground the analog signal to the black wire, use either red or blue for your analog input.
  13. May 16, 2025 at 10:40 AM
    HulkSmurf14
    2014 Tundra Limited
    Badass! Thank you sir!
  14. May 16, 2025 at 10:50 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    You can pull boost from the white wire on the map sensor for the psb1. Then just remember what analog you have on the red and blue. I believe @TurboKits posted a good accurate transforming formula for hpt to read it. @blenton posted a formula too. It's in a past post somewhere.
  15. May 16, 2025 at 10:57 AM
    HulkSmurf14
    2014 Tundra Limited
    Perfect, I got my memories mixed up...I'm just getting things ready for nesr future updates
  16. May 16, 2025 at 11:19 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    2021 White Platinum CrewMax 4WD
    I have installed this kit on my truck, works flawless. (i totally did not f up the stock ones by trying to loosen the wrong side of the cam bolt with my 1/2" impact)
    Wynnded and Mdl[QUOTED] like this.
  17. May 16, 2025 at 11:21 AM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    My extreme valve body showed up, has anyone converted to the max life or do i need to stay with WS? I'm at 71k miles and it's drain and fill time! I want my trans to last with the 2650.
  18. May 16, 2025 at 11:38 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    People have used maxlife with no issues. I personally stick with AISIN/ Idemitsu /Toyota. I'm currently running AISIN WS.
  19. May 16, 2025 at 12:28 PM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    Weird you can’t see it.
    HulkSmurf14 likes this.
  20. May 16, 2025 at 12:42 PM
    blenton
    blenton New Member
    His wife must have put the kiddie filter on that blocks illicit photos of truck parts.. Probably needs a parental password to access Summit Racing and Jegs, too. :p
    jhrrld, mustang67408 and HulkSmurf14 like this.
  21. May 16, 2025 at 12:44 PM
    blenton
    blenton New Member
    The formula is buried here in the thread somewhere. I can pull it off of my windows machine this weekend and post it.
    Mdl[QUOTED] and HulkSmurf14 like this.
  22. May 16, 2025 at 1:19 PM
    HulkSmurf14
    2014 Tundra Limited
    Sounds like another "first page" adder! Thank you all for the help!
    Mdl likes this.
  23. May 16, 2025 at 2:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Wynnded, blenton, AZTundra and 2 others like this.
  24. May 16, 2025 at 2:37 PM
    jhrrld
    jhrrld ID-Ten-T
    Josh
    OK
    I think I'll go ahead and do MaxLife, easier to source and i'll stick to 30K drain and fills with it.
    I just switched my wife's 2017 QX80 that was having major torque convertor shudder to maxlife from nissan's crappy thin oil and it fixed all the madness, need to trade that crap off before the trans completely dies. Might have put some other fiction modifier voodoo magic in there too that i will not be adding to the tundra.
  25. May 16, 2025 at 3:37 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    And it’s out! Big thanks to @Mcbelen (MCBAutotech in Houston), dude came down to where I'm at and got this thing pulled really quick.
    Got everything plugged and taped off. Inspected the s/c, noticed some odd nicks on the rotor packs, no clue if that's normal but forgot to take pics lol. Got it packaged up and should be shipping it out tomorrow.
    Who do you guys normally use to ship these things? I'm thinking of just using UPS.
  26. May 16, 2025 at 4:23 PM
    blenton
    blenton New Member
    I built a crate, put kaizen foam on the bottom, bolted the manifold to the lower part of the crate, then stuffed it and wrapped the outside with cardboard. 1/2" ply top and bottom, screwed in with #2 Robertson head screws so common-folk that only know how to use peasntly-phillips head screwdrivers couldn't mess with it en route... I thought I had the original box and foam, but ends up I only had the second original box and no foam.
    I used Paypal's ShipStation to ship via UPS. It was $100 less then directly through UPS. With the weight and size, you have to click the 'extra handling' option or you won't get a quote. Insured, it was $140ish. Through UPS website (my UPS account lapsed as I don't ship things much anymore) it was $240ish. Weighed 92 lbs in its crate.
    HulkSmurf14, ZPhilip, Wynnded and 3 others like this.
  27. May 16, 2025 at 4:59 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Tried a WOT shift from 1st to 2nd with the VB. No more mushy shift, the trans feels more poised to handle the torture now.
  28. May 16, 2025 at 5:05 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Same as @blenton , I got one of those plastic totes from home Depot and snugged it up inside and taped the shit out of it. I use Pirate Ship to get packaging slips, just don't go direct through UPS since it's a fortune.
  29. May 16, 2025 at 5:18 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    I looked at ShipStation.com but they don't seem to have an option to get a rate without making an account first.
    Looking at PirateShip, 292.54 for 2-day air, 393.90 for next day air saver through UPS. Shipping options only have $100 carrier liability, do you add the InsureShield?
  30. May 16, 2025 at 5:26 PM
    snivilous
    SW UT
    You should have an option after listing the dimensions of how much to insure it for. I sure as shit wouldn't air ship it but to each their own :rofl:
    HulkSmurf14 and Ryuu[QUOTED] like this.
